Ros2_info — a terminal workspace lens for ROS 2 (TUI + optional local AI)
Hi all,
Sharing a tool I’ve been building: ros2_info — a fastfetch-style ROS 2 workstation dashboard with a full-screen terminal UI. Written in Rust, so it runs headless over SSH and on Pi/Jetson-class hardware without any Electron/webview overhead.
Repo: GitHub - Gaurav-x111/ros2_info: fastfetch for ROS2 — distro info, live nodes, workspaces, web dashboard. One command. Everything you need. · GitHub
It’s not trying to replace your editor or your terminal — it’s trying to replace the five terminals you already have open during bring-up and debugging:
  • Live dashboards — nodes, topics, services, actions, workspace + build status, DDS/domain/sourcing state, all on one screen instead of five.
  • Integrated PTY terminalros2, colcon build, ros2 launch run live alongside everything else, not in a separate window.
  • Multi-tab editor with Neovim keybindings, for when you need to touch a file without leaving the session.
  • Local AI assistant (Ollama, fully offline, opt-in)ai scan / ai fix / ai explain for build errors. Every suggested change is diff-gated before anything is applied, and the tool works exactly the same with this switched off entirely.
    Build-error triage — ai scan / ai fix / ai explain, diff-gated so nothing is applied without review
  • In-TUI chat assistant, plus a standalone AI web chat if you’d rather work outside the terminal
  • Autonomous coding mode — give it a goal, it iterates on the code toward that goal inside the same sandbox + diff-gate rails as everything else (this writes/edits code autonomously, it doesn’t drive the robot at runtime)
  • so i prefer you small model like vibethinker 3b or gemma E2B, E4B
  • ROS 2 graph canvas, git/gh integration, and a namespaced sandbox mode (/sandbox) for experimenting without touching the real graph.
  • In-process plugin API for extending it further.
Honest pitch: you can do all of this with the raw CLI plus your editor of choice — I’m not claiming to be smarter than either. It’s just that during active bring-up and debugging, having graph state, build output, and a terminal in one screen is faster than context-switching across five.
Single static binary, MIT licensed, supports Humble/Jazzy/Iron/Rolling. Feedback and PRs welcome — happy to answer questions.
Nice work — the pty terminal and the plugin API especially. Question: does the collector see nodes/topics across Docker container boundaries? I run ROS 2 systems split over several containers (docker-compose, one subsystem each), and I’m wondering if the dashboards would show the whole system or only what’s reachable in one DDS domain.
this is the 3rd 4th time you’ve posted about the exact same github repo in 3 days. at what point does it become considered “spam” to repeatedly post about the same topic?
why was this comment flagged? lol
i think you have mistaken this project for some one else , at night only i complied tested and checked everything , locally and then i uploaded this version and checked and updated readme , and about 3 to 4 time let me clarify , its 3 rd time and all time i updated , worked and evoloped my project
thank you for your question , and suggestion and i thought yah i can add this so thanks to you i added that features
Run it on the Docker host (where docker is reachable):
ros2_info compose # whole-system table across all containers
ros2_info compose --json # raw JSON (also GET /api/compose for the dashboard)
It docker execs ros2 node/topic list inside each running container and merges them — so the dashboards show the whole system, not just one DDS domain, even when containers are on isolated networks or different ROS_DOMAIN_IDs
again thank you
