Hey Open Robotics folks ![]()
So I built a small tool called ros2_info.
The idea was simple: what if fastfetch, but for your entire ROS2 environment?
One command → instant snapshot of everything happening in your ROS2 setup.
What it shows:
• ROS2 distro + whether it’s LTS or nearing EOL
• Live nodes, topics, services, and actions
• Auto-detects which DDS middleware you’re running
• All detected colcon workspaces + their build status
• Installed ROS2 packages grouped by category
• System stats (CPU, RAM, Disk)
• Pending ROS2-related apt updates
• A small web dashboard at localhost:8099
Basically the stuff I kept checking with 10 different commands… now in one place ![]()
Works across ROS2 distros: Foxy → Humble → Iron → Jazzy → Rolling
GitHub:
https://github.com/zang7777/ros2_info
Install
cd ~/ros2_ws/src
git clone https://github.com/zang7777/ros2_info.git
cd ~/ros2_ws && colcon build --symlink-install
source install/setup.bash
(best recommended) ros2 run ros2_info ros2_info --interactive
or just
Always fun building little dev tools for the ecosystem ![]()
~"Created by roboticists, for roboticists "
