Scry — debug your ROS 2 robot from your phone, with an AI assistant
After 6+ years in robotics, the pattern that kept frustrating me was field debugging. When a deployed robot stops doing what it should, whoever is standing next to it is often stuck with a laptop on one knee, several terminals open, ros2 topic echo scrolling past, and logs to tail across a dozen nodes, services, and processes, all while trying to find the cause before it becomes a customer problem.
So I built Scry: an AI-first debugging tool for ROS 2 robots that runs on your phone.
How it works
Scry is two pieces:
  • scry-connect — a small Python server you run on the robot (pip install scry-connect). It uses rclpy, so it’s RMW/middleware-agnostic and works with Fast-DDS, CycloneDDS, Zenoh, and Connext. It exposes the robot’s ROS 2 graph to the phone over your own network (no cloud).
  • The Scry Android app — the thick client. It runs the AI loop, renders results, and talks to the robot.
You ask a question in plain English — “why isn’t the robot moving?” — and the AI inspects topics, nodes, services, parameters, lifecycle, TF, and logs live, then reports the likely root cause. Reads are free; anything that changes the robot (publishing, setting a parameter, calling a service, lifecycle changes) requires explicit on-screen approval first.
What it can do
  • Browse every ROS 2 entity from your phone: topics, nodes, services, actions, lifecycle, parameters, components, TF frames, logs, and processes — each as a searchable list with one-tap detail.
  • Live visualizations: camera, LiDAR, plots, behavior trees, and a top-down 3D scene.
  • Background monitors (e.g. “alert me if /odom drops below 10 Hz”).
  • Multi-robot fleet view.
AI providers
Bring an OpenRouter key for cloud inference (300+ models including Claude, GPT, Gemini, Llama, DeepSeek), or run fully offline against a local Ollama server. Your key, your robot, your network — no telemetry, no cloud backend.
Supported ROS 2 distros: humble, iron, jazzy, kilted, lyrical, rolling.
It’s still early and I’d really value feedback from this community — especially on the tool coverage and where it falls short on real robots.
