SDF2MAP → Generate ROS 2D Maps Directly from GzSim Worlds
SDF2MAP — SDF to Occupancy Map Converter
SDF2MAP is a lightweight desktop tool that converts Gazebo SDF / World files into 2D occupancy grid maps compatible with the ROS navigation stack.
It automates generating .pgm and .yaml maps directly from simulation environments — eliminating the need for manual map creation.
  • Quickly test navigation and localization algorithms using GzSim maps.
  • Extract 2D map layers at specific heights to match your robot’s LIDAR sensor placement.
  • Seamlessly handle worlds generated by PyRoboSim.
Download & Run:
Get the latest release and instructions from GitHub:
