Real-time robot dashboards in React without a separate visualization server
If you’ve built an operator UI or ground station in React, you’ve probably hit the same wall I did: the moment you need real-time telemetry visualization, your options are to run Foxglove or Grafana as separate infrastructure and iframe them in, or hand-roll canvas components from scratch. Neither is great when what you actually want is telemetry views that live natively inside the app you’re already building.
So I built Altara: a set of MIT-licensed React components for real-time telemetry, with a one-line rosbridge adapter so you can pipe a sensor_msgs topic straight into a chart, gauge, or attitude indicator.
A minimal example:
tsx
import { AltaraProvider, TimeSeries } from '@altara/core'
import { createRosbridgeAdapter } from '@altara/ros'
const imu = createRosbridgeAdapter({
  url: 'ws://localhost:9090',
  topic: '/imu/data',
  messageType: 'sensor_msgs/Imu',
<AltaraProvider theme="dark">
  <TimeSeries dataSource={imu} height={240} />
</AltaraProvider>
It’s a monorepo of six packages: @altara/core (the base components), @altara/ros (rosbridge adapter with typed factories for common sensor_msgs types), @altara/mqtt, and three domain packages, @altara/aerospace (PFD, HSI, TCAS and other flight instruments), @altara/av (LiDAR point cloud via Three.js, occupancy grid, SLAM map), and @altara/industrial (SCADA-style panels, waterfall spectrogram, alarm annunciator). 41 components total, every one runs in a mockMode so you can build and demo without hardware.
Everything renders to canvas via requestAnimationFrame with the hot path kept out of React, so high-frequency streams don’t cause re-render jank.
It’s early and I’m the only maintainer, so I’m being upfront about that. The architecture is deliberately simple, plain canvas and React, no exotic dependencies, so it’s straightforward to fork and self-maintain if that matters to you.
Website: https://www.usealtara.dev/
Repo: GitHub - JayaSaiKishanChapparam/altara: React components for real-time telemetry dashboards — robotics, aerospace, autonomous vehicles, industrial IoT. PFD, HSI, time-series, gauges, GPS maps, and ROS2/MQTT adapters at 60fps. · GitHub
Live Storybook (all 41 components): @storybook/core - Storybook
Demo: Altara Demo
What are you currently using for in-app telemetry visualization, and where does it fall short? Trying to understand what’s actually missing for people building custom operator interfaces.
May I suggest adding some screenshots to your post?
Ik took me 4 clicks to find how these graphs actually could look:
Very cool stuff!
@Jaya_Sai_Kishan this is the third topic you’ve created about this library in less than a month (the other two are here and here and people responded). This topic here doesn’t seem to add anything new on top of what you’ve already shared. Personally I like what you are building, but too much repetition could be considered spam.
Fair point, @chfritz , and thanks for saying it directly rather than just letting it sit. You’re right that this didn’t add much beyond the earlier posts. I’ll keep future updates to one place instead of new topics.
