Fusion 360 to ROS 2 URDF โ€“ Updated & Improved!
Hello
Here is the improved Fusion 360 to URDF for ROS 2 project with new enhancements to make it even easier and more robust for your robotics workflows.
:rocket: Whatโ€™s new in this release:
:white_check_mark: ๐—œ๐—บ๐—ฝ๐—ฟ๐—ผ๐˜ƒ๐—ฒ๐—ฑ ๐——๐—ผ๐—ฐ๐˜‚๐—บ๐—ฒ๐—ป๐˜๐—ฎ๐˜๐—ถ๐—ผ๐—ป โ€“ Clearer setup instructions and usage guidelines for developers at all levels.
:white_check_mark: ๐—ฅ๐—ข๐—ฆ ๐Ÿฎ Jazzy ๐—ฆ๐˜‚๐—ฝ๐—ฝ๐—ผ๐—ฟ๐˜ โ€“ Generated ROS 2 URDF package supports ROS Jazzy distribution with new Gazebo Sim.
:white_check_mark: ๐—•๐˜‚๐—ด ๐—™๐—ถ๐˜…๐—ฒ๐˜€ โ€“ Stability improvements and resolved issues from previous versions.
:white_check_mark: ๐—š๐—ฎ๐˜‡๐—ฒ๐—ฏ๐—ผ ๐—ฆ๐—ฒ๐—น๐—ฒ๐—ฐ๐˜๐—ถ๐—ผ๐—ป ๐—ช๐—ถ๐˜‡๐—ฎ๐—ฟ๐—ฑ โ€“ Choose between Gazebo Classic and Gazebo Sim with a simple option, streamlining your simulation setup.
:white_check_mark: ๐—œ๐—ป๐—ฐ๐—น๐˜‚๐—ฑ๐—ฒ๐—ฑ ๐—ป๐—ฒ๐˜„ ๐—ฟ๐—ผ๐—ฏ๐—ผ๐˜ ๐—บ๐—ผ๐—ฑ๐—ฒ๐—น ๐—ฒ๐˜…๐—ฎ๐—บ๐—ฝ๐—น๐—ฒ
Check out the repo and get started with better Fusion 360 to ROS 2 integration today!
:backhand_index_pointing_right: GitHub - runtimerobotics/fusion360-urdf-ros2: A Fusion 360 Script to export URDF for ROS 2, mentioned in the book Mastering ROS 2 for Robotics Programming
Feel free to report issues, suggest enhancements, and contribute new features or bug fixes via pull requests (PRs).
Regards
Lentin Joseph
Hi Lentin,
Thanks for the guidance! I noticed that sometimes the robot spawns twice in Gazebo due to timing and automatic renaming. I made a small fix that delays the spawn slightly and disables renaming to prevent duplicates.
Iโ€™ve opened a pull request with the changes and would appreciate your feedback when you get a chance.
Thanks again for this repo!
I will check it Davis. Thanks for the contribution
Thank you for merging the changes.
