[Announcement] Gazebo Event Camera Plugin for ROS 2 Jazzy + Gazebo Harmonic
Hi everyone,
We are happy to share a new event camera simulation plugin for Gazebo Harmonic and ROS 2 Jazzy.
The goal of this project is to provide a practical way to simulate an event camera directly in Gazebo and generate asynchronous brightness-change events from a simulated camera stream.
The plugin currently implements an ESIM-style event generation model, including:
- Log-intensity based event generation
- Positive and negative contrast thresholds
- Multiple threshold crossings between frames
- Sub-frame event timestamp interpolation
- Per-pixel reference intensity
- Refractory-period handling
- Optional contrast-threshold variation
- ROS 2 custom “Event” and “EventArray” messages
- Gazebo Transport protobuf messages
- Configurable camera and event parameters
The current example uses a 128 × 128 camera at 500 Hz and publishes events to:
/event_cam/events
The plugin has been tested with ROS 2 Jazzy and Gazebo Harmonic, and the generated event stream can be directly consumed by ROS 2 nodes for event-based vision and robotics applications.
GitHub
The complete source code, example world, launch files, configuration, custom messages, and documentation are available here:
:link: GitHub:
Demo
We also recorded a short demonstration of the plugin running in Gazebo:
:movie_camera: Video:
I would really appreciate feedback from the Gazebo / ROS community, especially regarding the event-camera model, sensor effects, performance, and possible integration with existing event-based vision workflows.
Future improvements I am considering include additional sensor non-idealities, noise models, bandwidth limitations, and support for more realistic event-camera characteristics.
Hope this is useful for anyone working on event-based vision, visual odometry, SLAM, perception, or robotics simulation.
Thanks!
This work is equally contribution done by Aachal Sharma and Rahul Gupta
Looks great! What performance (RTF) is achievable?
Thanks! The current 128×128 @ 500 Hz configuration runs in real time, but I haven’t yet conducted a systematic RTF benchmark. I’m planning to evaluate RTF across different resolutions and event rates and will share the results.
Wow, I wouldn’t bet gz rendering can be this fast with small resolutions!
Thank you ..once again
Hi! This looks really cool! Out of curiosity, do you have a process for visualizing event data? I’m wondering if this is something we should explore at Foxglove.
Hi! Yes, definitely. Currently, our plugin publishes the generated events directly as a custom ROS 2 EventArray message on /event_cam/events.
We’re interested in exploring a dedicated visualization workflow for these event streams in Foxglove as well. Thanks for the suggestion! :raising_hands:
