Hello,
I would like to share a project we are building and ask for honest feedback from this community.
RoboSim AI is a browser-based ROS 2 and Nav2 robot simulator, with a warehouse digital-twin editor and an assistant that can turn a plain-English description into an editable scene. We recently opened a free Student plan ($0, no credit card): 2 projects, 500 MB storage, 1 live simulation session, 5 CPU and 0.5 GPU simulation hours a month, 25 AI credits, basic ROS 2 environments and a starter robot library (UGV Rover R1, Quadruped X1, Humanoid H2, Aerial Drone D1).
The aim is to let students and club members run a first ROS 2 / Nav2 scene without a local install. It is early. I am especially interested in:
- where a first Nav2 run is confusing or falls short of a real workflow
- whether this would actually help a course or a student club
- what is missing before it is useful day to day
To try it: Sign in · RoboSimAI — please use Continue with Google. Email signup is not reliable at the moment.
Disclosure: I am Dali, COO of RoboSim AI. I will answer questions in this thread.
Thanks,
Dali
COO, RoboSim AI
Hi Dali, thanks for sharing this, and for the disclosure. I tried the demo with the Go2 in the warehouse scene and have some feedback.
What worked well: Live Sim started within about ten seconds and ran smoothly, around 30 to 50 fps and slightly above real time. Setting a goal by clicking on the floor was easy, and the robot started moving right away.
Where I got stuck:
- Obstacle handling. I sent the robot toward a goal past some wooden planks lying on the floor. It ended up on top of one of them instead of planning around it. Are those objects meant to be physical obstacles for the sim, and does the planner see them through the LiDAR and costmap? For a navigation demo, seeing a clean avoid-and-replan run would show the value quickly. If obstacles are not part of the planning loop yet, a note in the UI would save people some confusion.
- Nav2 visibility. After sending a goal I couldn’t see the planned path, the costmaps, the TF tree or the lifecycle state. The only feedback was a “heading there” message. When a first Nav2 run goes wrong it’s usually a frame, initial pose or costmap issue, so surfacing those would help more than adding robots.
- ROS 2 details. Which distro, Nav2 version and simulator are running underneath? Can I export the world, URDF and Nav2 params and launch files to run locally? That would make this a stepping stone to a local setup.
- AI assistant. The Build page asks for an OpenAI API key and says usage is billed to the workspace. Is that expected on the free plan, given the 25 AI credits mentioned above?
- Limits. One live session and 0.5 GPU hours a month would be tight for a class or club. It would help to know how an instructor could set up a group.
Overall this is a good initiative. Making a first ROS 2 and Nav2 run possible from the browser removes a real barrier for newcomers, and the warehouse scene is a nice starting point. Good luck with the next steps.
