Pyrobosim: ROS2 enabled 2D mobile robot simulator for behavior prototyping
Hi folks,
I thought I would promote a tool I’ve been working on lately.
pyrobosim is a standalone, open-source version of some old work I did while working on home service robots at MIT. In making it standalone, I made it into a ROS2 package in hopes of tapping into the robotics software ecosystem.
Basically, pyrobosim is a simple point robot simulator where you can build and navigate environments consisting of connected rooms with locations where objects can be picked/placed. It’s intentionally simplified with the goal of prototyping higher-level behaviors. It also has a way to auto-generate worlds into Gazebo, so you can then run these same algorithms on an actual simulated robot with higher-fidelity motion planning and physics.
This is still in its initial stage, but I would appreciate any feedback as this is a project I hope to continue improving and supporting for some time.
GitHub repo: GitHub - sea-bass/pyrobosim: ROS 2 enabled 2D mobile robot simulator for behavior prototyping.
Documentation: PyRoboSim — pyrobosim 4.2.0 documentation
Blog post: Building a Python Toolbox for Robot Behavior – Robotic Sea Bass
Here is an animation of a plan (or action sequence) running in pyrobosim:
pyrobosim_actions_animation
And here are examples of the same world exported to Gazebo classic and Ignition:
Oooh the tools looks nice and easy to use :slight_smile:
