Webots and ros_control
ros_control is now a part of the standard Webots ros controller!
Even though our focus is the integration of Webots and ROS 2, we still actively maintain and develop our ROS 1 interface.
We believe that the ros_control integration will accelerate the development and adoption of Webots in projects that depend on controllers such as diff_drive_controller, joint_state_controller, joint_trajectory_controller, and similar.
Some other perks:
  • a robot_description parameter is automatically exposed (and yes, you can edit robot model in Webots and a new URDF is automatically generated), and
  • topics are automatically created for all available sensors.
How to use it?
The new ros controller is included in Webots R2021b available as a part of our nightly builds:
https://github.com/cyberbotics/webots/releases
And a usage example:
https://github.com/cyberbotics/webots_ros/blob/develop/launch/pioneer3at.launch
Want more details?
See relevant PRs:
Thanks for introducing this change, @lukicdarkoo and team!
Dear @lukicdarkoo,
Thanks for you and the team’s excellent work and updates.
Could you kindly let me know what working environment you are using for this work? I tried to install Webots R2021b nightly build (22-4-2021) on my Ubuntu 20.04 + ROS noetic but I got ‘error while loading shared libraries: libboost_system.so.1.65.1’
Best regards,
Rui
That is odd. You got the error after running roslaunch webots_ros pioneer3at.launch? Could you please share the full error log and the list of commands you called?
BTW, I believe ROS Answers are a better place for these kinds of questions:
The webots_ros2 package now comes with ros2_control integration!
Recently, we have introduced a new C++ plugin mechanism to the webots_ros2 package (based on pluginlib). And of course, the first plugin featuring the new mechanism is the webots_ros2_control - ros2_control integration.
We hope that this integration will help you taking advantage of the prebuilt ROS 2 controllers.
You want to use ros2_control and Webots in your next project? You will probably find the following resources useful:
Wow :grinning: The Webots Simulator is a great tool for fast prototyping !!!
