I’m happy to share an open-source RViz 2 plugin I have been working on:
rviz_2d_plot_plugin
The plugin provides live 2D plotting directly inside RViz 2 as a screen-space overlay. The goal is to make it easier to monitor ROS 2 topic data, controller signals, odometry-related values, diagnostics, and other runtime signals without leaving the RViz environment.
Some of the current features include:
Runtime discovery of plottable ROS 2 topic fields
Time-series plotting
XY plotting
Multi-series plotting from different topics
Reference lines, limits, setpoints, and tolerance bands
Axis control, auto-scaling, grid, legend, and styling options
QoS configuration
Pause, clear, and history preservation
The plugin is currently supported and tested on ROS 2 Humble. Support for additional ROS 2 distributions is planned and will be released soon.
The project is released under the MIT license.
I would be happy to receive feedback from the ROS community, especially regarding:
API/design improvements
Compatibility with other ROS 2 distributions
Useful plotting features for robotics debugging workflows
Looks quite nice and I learned something new about conditions in the package.xml depends
It does, however, reinvent the wheel a couple of times.
You could’ve used
to extract the numerical values from messages without having to do all the introspection work yourself again (which also requires testing and maintenance work, as this part of ROS tends to change occasionally).
and
allows overlaying any QML or QtWidget UI on top of the RViz 3D scene, including interactive graphs.
This would allow you not only to visualize the data you want to monitor, but also to interact with your robot without leaving RViz.
One reason I’m saying this is that by reinventing the wheel, you risk making the same mistakes that others have already solved.
For example, your plot overlay will render in any camera display added, and it’s not possible to hide it there. You can only disable it to hide it everywhere, but not just for the camera display.
Had the same issue in the hector_rviz_overlay and only recently found a solution to fix that.
