ROS2 UWB Localization Framework with Realistic Noise Modeling and Benchmarking
Hi everyone,
I’ve developed a modular ROS2 UWB localization framework designed for both simulation and real-world research.
:wrench: Key Features:
  • Plug-and-play ROS2 package (one-command launch)
  • High-fidelity UWB simulation:
    • Gaussian noise
    • NLOS exponential bias
    • AR(1) multipath correlation
    • clock drift modeling
  • Modular pipeline:
    /uwb/range → preprocessor → trilateration → EKF (robot_localization)
  • Real-time noise injection via ros2 param
  • Dataset recording (ROS bag + CSV)
  • Benchmarking metrics (RMSE, MAE, P95)
  • Error attribution diagnostics
  • RViz visualization and TF integration
:rocket: Quick Start:
git clone GitHub - anandbobba/ros2_uwb_plugin · GitHub
cd ros2_uwb_plugin
chmod +x install_dependencies.sh
./install_dependencies.sh
colcon build
source install/setup.bash
ros2 launch ros2_uwb_research_sim demo.launch.py
:movie_camera: Demo Video:
:open_file_folder: GitHub Repository:
I’d really appreciate feedback, especially from people working on indoor localization, SLAM, or UWB systems.
Thanks!
Update:
I’ve improved the framework with:
  • Plug-and-play dependency installation (rosdep + install script)
  • Added support for real UWB hardware via a generic driver layer
  • Improved documentation and Quick Start workflow
  • Added research diagnostics and plotting tools
The repository is now fully plug-and-play for both simulation and real hardware use.
Would appreciate any feedback!
Can you recommend a cheap uwb system just to experiment?
BU01 is cheapest considerably some 10-12$
Update: The ROS2 UWB Localization Framework now supports dual-UWB-tag yaw estimation for full pose estimation using pure UWB geometry.
New additions include:
  • dual-tag localization pipeline
  • yaw estimation using atan2(dy, dx)
  • EMA-based angular filtering
  • baseline validation for stability
  • RViz heading visualization
  • EKF fusion improvements
  • Humble/Jazzy + Gazebo compatibility updates
  • improved CI/CD and dependency handling
The system now supports:
front tag + rear tag → trilateration → yaw estimation → full pose fusion
Launch:
ros2 launch ros2_uwb_research_sim demo.launch.py dual_tag:=true
GitHub:
https://github.com/anandbobba/ros2_uwb_plugin
Thanks to everyone who provided feedback and suggestions — they significantly improved the architecture and portability of the framework.
