Hi ROS Community,
I updated for my work a ros2 control composable hardware interface plugin for the robotiq ft 300 sensor.
In order to use it for manual guidance ( i don’t know if i can share that node too) and to test the new chained admittance controller.
It can be found in my github : https://github.com/panagelak/robotiq_ft_sensor_driver
Additional features include “fake_mode” in order to test the integration without access to physical hardware and the ability to add force data in the measurements from a subscriber.
Please note that most of the code is from the ros1 repo : GitHub - ros-industrial-attic/robotiq: Robotiq packages (http://wiki.ros.org/robotiq)
so i tried to keep all the licenses and original maintainers since it is a physical driver and can cause harm, use with caution : )
let me know what you think
Cheers,
Panagiotis Angelakis
