[Other issue]: How to operate multiple TurtleBot3 robots using ROS 2 Humble (#688)
Posted by @shimon46:
Before proceeding, is there an existing issue or discussion for this?
Description
Hello. I’m trying to use Open-RMF to control multiple TurtleBot3 robots.
Could you please explain how to set up the environment using ROS 2 Humble?
Posted by @aaronchongth:
Hi @shimon46 I’ve converted the ticket into a discussion instead of an issue.
Can you describe your setup in more detail? Would only the robots be running ROS 2 Humble, while the host machine is running other ROS 2 distros (e.g. Jazzy)? Or would the host machine also be running ROS 2 Humble?
Take a look at GitHub - open-rmf/free_fleet: A free fleet management system. and give it a try. We will generally encourage updating systems to ROS 2 Jazzy since it has major improvements and is more well tested for Open-RMF. Turtlebot3 now supports ROS 2 Jazzy, TurtleBot3
I am setting up a ROS 2 Humble environment on WSL2, and the TurtleBot3 robots are also using ROS 2 Humble.
By the way, are there any setup instructions available for using Open-RMF and TurtleBot3 with ROS 2 Jazzy?
https://github.com/open-rmf/free_fleet
