Hello, would you be interested in building a ROS2 vacuum cleaner robot?
If yes
- Build/develop vs convert existing?
- 3D print vs off-the-shelf?
- Convert existing - root or swap board?
I’d really appreciate your input.
As an example of what I’m doing
- I have connected my vacuum to ROS including /scan, /imu, /cmd_vel, /odom, brushes (main, side), vacuum fan, IR sensors. Open source here GitHub - makerspet/proscenic-m6pro: ROS2 robot description for Proscenic M6 Pro · GitHub
- I have had a consumer vacuum cleaner robot torn down, converted to 3D design to experiment with 3D printing it. Open source here GitHub - remakeai/vacuum_cleaner_teardown: Teardown of a home robot vacuum cleaner equipped with LiDAR · GitHub
