Hi ROS community!
I conduct research on processing an Allan Variance for noise model building and inertial sensors noise simulation.
If you have done noise analysis or, if you would like to do it and you can share with me signals recorded during calibration process I will analyze your data results in return.
I claim the rate speed and the acceleration data of any duration and quantity. I will process bulk data too.
You can also send me your Allan Variance, but raw signals are better because I can check another statistical properties of your data.
Result of my analysis are errors coefficients: Angle Random Walk/Velocity Random Walk, Bias Instability, Rate Random Walk/Random Walk, Quantization Noise, Rate Ramp.
If you consider sending me your raw data please attach:
- sensor type and part number,
- data sampling frequency, if data sampling was uniform or time vector, if not,
- measurement units (deg/s, rad/s or m/s^2, g, etc.),
- your noise coefficients (optional).
If you consider sending me your Allan Variance please attach:
- tau vector,
- any of: confidence intervals, EDFs, size of signal vector (optional),
Do not hesitate to contact me if you need advice how to prepare test.
Thank you in advance ![]()
