Bimo is an open-source bipedal robot built to make bipedal robotics research accessible in a compact, affordable platform. It ships either as a fully assembled SLS Kit (ready to walk out of the box) or as a DIY Kit where you print the parts yourself and assemble the robot.
What you can use it for
Learning and prototyping RL legged locomotion with a real sim-to-real pipeline in Isaac Lab including distillation scripts for RL policy deployment on limited hardware (MCU).
A teaching platform for robotics courses, as it covers RL deployment, computer vision, embedded C++/Python, and control loops in one small robot.
A research base for custom payloads (vision, SLAM, extra compute) thanks to the empty head cavity with M3 mounts and up to 1 kg payload support.
Experimenting on legged locomotion algorithms such as getting Bimo walking immediately with a built-in CPG gait, customizing your own RL policies or designing other control methods.
Main Specifications
| Feature | Spec |
| Height | 45 cm |
| Weight | ~1.6 kg (no payload) |
| Payload | Up to 1 kg head-mounted |
| Actuators | 8 × STS-3215 servos |
| Sensors | BNO08x 9-DOF IMU, 4× TOF sensors, 2× 180° FOV cameras |
| Controller | Custom RP2040-based board, compatible with SBCs |
| Control loop | 20 Hz |
| Compute | Offboard PC, onboard SBC, or fully standalone on RP2040 (distilled RL or CPG) |
Fully Open-Source
CAD files (coming soon), RP2040 firmware, the Isaac Lab training environment, and a Python API are all released under Apache 2.0. There’s also a ROS 2 wrapper around the Python API for anyone who is more used to working with the ROS2 ecosystem.
Current Project Status
v1.1.0 has been published on GitHub: Bimo walks omnidirectionally with a stable CPG gait and sim-to-real works for forward walking with the RL policy. The project is in pre-order status before going into the CE/FCC certification and shipping.
- GitHub: the-bimo-project
- Website: mekion.com
- Discord: Mekion | The Bimo Project
Happy to answer any technical questions here. This is my first serious project and I’d love feedback from people building legged robots and working with ROS2 and RL.
