To the Turtlebot3 burger, waffle and waffle_pi models. I forked the Turtlebot3 GitHub repository and edited the urdf and sdf files on the humble-devel branch. As long as you install the velodyne_simulator with:
sudo apt install ros-humble-velodyne-simulator
In your ROS2 /opt/ros/humble/share directory, it should work correctly. Currently, there is no mesh that is available to be displayed in Gazebo, but the PointCloud2 points are still collected and are published to the topic:
/velodyne_points
Here is the repository, let me know if you have any questions:
Thanks for including the velodyne simulator with ROS2 Humble. I am able to run the launch file and see the physical Velodyne model on the robot with the laser scan but i can’t see /velodyne points or the Point Cloud 2 Points. May i ask if i can ask you some questions?
ROS Discourse is for news and general interest discussions. Robotics Stack Exchange provides a Q&A site which can be filtered by tags to make sure the relevant people can find and/or answer the question, and not overload everyone with hundreds of posts.
Hello, sorry I am seeing this so late. If you still have some questions I can try to help you, try to private DM me or reach out to me at this email address, shawnsinanan21@gmail.com.
