URDF Validation + Kinematic Analysis API with Browser-Based Preview (Tested on Robonaut 2)
I’ve been working on a developer-focused URDF validation and analysis API and recently added a browser-based 3D preview layer.
To stress test the pipeline, I used the NASA Robonaut 2 (R2) URDF:
URDF: https://github.com/gkjohnson/nasa-urdf-robots/blob/master/r2_description/robots/r2c6.urdf
Observations
  • URDF passed structural validation (100+ joints, consistent hierarchy)
  • Kinematic analysis produced expected:
    • DOF (~74, computed from non-fixed joints)
    • chain depth (~19)
    • multiple end effectors (hands, fingers, sensors)
  • Tree reconstruction yielded a valid single-root structure (no cycles/orphans)
  • Browser preview correctly reflects:
    • joint origins (xyz / rpy)
    • parent-child relationships
    • joint axis orientation
Pipeline
Upload → Validate → Analyze → Preview
  • No ROS environment required
  • No RViz
  • Validation on server (file deleted after response)
  • 3D is client-side only
Motivation
Most URDF tooling focuses on XML/schema validation.
In practice, failures appear later in:
  • TF tree inconsistencies
  • Incorrect joint transforms
  • Misconfigured DOF
  • Broken kinematic chains
This tool aims to surface those earlier via:
  • structural validation
  • kinematic introspection
  • immediate visual feedback
Live demo
https://roboinfra-dashboard.azurewebsites.net/validator
Feedback request
Would appreciate input from others working with URDF pipelines, especially around:
  • additional validation rules worth enforcing
  • kinematic analysis gaps
  • CI/CD use cases (pre-merge URDF checks, regression detection)
Live test Screen Shots Below,
