Plot tool for visualization
Hi all!
I would like to let you know that I created a new plotting tool in rust + gtk-rs. This tool can plot large sets of data, and also can gather data from ROS2. The idea was to build a PC application which can handle a big influx of data without coming to a halt. As such, it is not a browser based tool, but GTK based. The data can be send into the tool via a simple TCP/IP protocol.
Sourcecode is located here: GitHub - windelbouwman/lognplot: Plotting and logging of real-time data for desktop.
To log all ROS2 signals in your system, you can use the ros2 adapter script: lognplot/adapters/ros2_adapter.py at master · windelbouwman/lognplot · GitHub
I’m aware that this might directly compete with the rqt tool, which is pretty good, but this might also be a handy companion tool to debug your robots.
I’m curious to your feedback!
Regards,
Windel
Are you aware of plotjuggler? It will support ROS2 soon
Yes, I’m aware, and I think it is a very good initiative (by you ;)) .
I listed it here: GitHub - windelbouwman/lognplot: Plotting and logging of real-time data for desktop.
I wanted to try to build a plot tool for a long time, also I wanted to experiment with a data structure which supports partial data selection when zooming and panning.
Building this kind of tools is a lot of fun in my opinion :wink:
Great work!
Well, it is a more interesting challenge than it may seem.
Btw, I can 100% affirm your story here https://www.plotjuggler.io/about
Did you already consider HDF5 as a dataformat to export data? I think this could be a good format to exchange data after experiments are finished. It would be great to have some defined HDF5 schema for robotic experiments.
