We’re happy to announce 40 new packages and 747 updates to ROS 2 Humble Hawksbill ![]()
This sync was tagged as humble/2026-08-07.
Package Updates for humble
Added Packages [40]:
- ros-humble-autoware-command-gate: 1.9.0-1
- ros-humble-autoware-command-gate-dbgsym: 1.9.0-1
- ros-humble-autoware-core: 1.9.0-1
- ros-humble-autoware-core-localization: 1.9.0-1
- ros-humble-autoware-ndt-scan-matcher: 1.9.0-1
- ros-humble-autoware-ndt-scan-matcher-dbgsym: 1.9.0-1
- ros-humble-bosch-navigator-bridge: 2.1.16-1
- ros-humble-bosch-navigator-bridge-dbgsym: 2.1.16-1
- ros-humble-connection-inspector: 1.0.1-1
- ros-humble-connection-inspector-dbgsym: 1.0.1-1
- ros-humble-crazyflie-description: 1.0.5-1
- ros-humble-etsi-its-ivim-ts-coding: 3.5.0-1
- ros-humble-etsi-its-ivim-ts-coding-dbgsym: 3.5.0-1
- ros-humble-etsi-its-ivim-ts-conversion: 3.5.0-1
- ros-humble-etsi-its-ivim-ts-msgs: 3.5.0-1
- ros-humble-etsi-its-ivim-ts-msgs-dbgsym: 3.5.0-1
- ros-humble-kuka-kl-support: 1.1.2-1
- ros-humble-libbno055-linux: 1.7.2-1
- ros-humble-libbno055-linux-dbgsym: 1.7.2-1
- ros-humble-mapoi: 0.6.0-2
- ros-humble-mapoi-interfaces: 0.6.0-2
- ros-humble-mapoi-interfaces-dbgsym: 0.6.0-2
- ros-humble-mapoi-rviz-plugins: 0.6.0-2
- ros-humble-mapoi-rviz-plugins-dbgsym: 0.6.0-2
- ros-humble-mapoi-server: 0.6.0-2
- ros-humble-mapoi-server-dbgsym: 0.6.0-2
- ros-humble-mapoi-turtlebot3-example: 0.6.0-2
- ros-humble-mapoi-turtlebot3-example-dbgsym: 0.6.0-2
- ros-humble-mapoi-webui: 0.6.0-2
- ros-humble-mp2p-icp-core: 2.12.0-1
- ros-humble-mp2p-icp-core-dbgsym: 2.12.0-1
- ros-humble-mp2p-icp-viz: 2.12.0-1
- ros-humble-mp2p-icp-viz-dbgsym: 2.12.0-1
- ros-humble-nebula: 1.2.0-1
- ros-humble-pointcloud-conversions: 0.0.1-1
- ros-humble-pointcloud-conversions-dbgsym: 0.0.1-1
- ros-humble-ros-snapd-interfaces: 0.0.1-1
- ros-humble-ros-snapd-interfaces-dbgsym: 0.0.1-1
- ros-humble-rplidar-driver: 1.4.1-1
- ros-humble-rplidar-driver-dbgsym: 1.4.1-1
Updated Packages [747]:
- ros-humble-ackermann-steering-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-ackermann-steering-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-actionlib-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-actionlib-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-admittance-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-admittance-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-autoware-adapi-adaptors: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-adapi-adaptors-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-adapi-specs: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-adapi-v1-msgs: 1.9.1-2 → 1.9.2-2
- ros-humble-autoware-adapi-v1-msgs-dbgsym: 1.9.1-2 → 1.9.2-2
- ros-humble-autoware-adapi-version-msgs: 1.9.1-2 → 1.9.2-2
- ros-humble-autoware-adapi-version-msgs-dbgsym: 1.9.1-2 → 1.9.2-2
- ros-humble-autoware-agnocast-wrapper: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-agnocast-wrapper-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-awsim-sensor-kit-description: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-behavior-velocity-planner: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-behavior-velocity-planner-common: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-behavior-velocity-planner-common-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-behavior-velocity-planner-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-behavior-velocity-stop-line-module: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-behavior-velocity-stop-line-module-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-common-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-common-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-component-interface-specs: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-control-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-control-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-core-api: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-core-control: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-core-map: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-core-perception: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-core-planning: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-core-sensing: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-core-vehicle: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-crop-box-filter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-crop-box-filter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-default-adapi: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-default-adapi-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-downsample-filters: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-downsample-filters-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-ekf-localizer: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-ekf-localizer-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-euclidean-cluster-object-detector: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-euclidean-cluster-object-detector-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-geography-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-geography-utils-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-global-parameter-loader: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-gnss-poser: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-gnss-poser-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-ground-filter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-ground-filter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-gyro-odometer: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-gyro-odometer-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-internal-debug-msgs: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-debug-msgs-dbgsym: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-localization-msgs: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-localization-msgs-dbgsym: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-metric-msgs: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-metric-msgs-dbgsym: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-msgs: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-msgs-dbgsym: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-perception-msgs: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-perception-msgs-dbgsym: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-planning-msgs: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-internal-planning-msgs-dbgsym: 1.12.1-1 → 1.15.0-1
- ros-humble-autoware-interpolation: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-interpolation-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-kalman-filter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-kalman-filter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-lanelet2-extension: 1.1.0-3 → 1.2.0-1
- ros-humble-autoware-lanelet2-extension-dbgsym: 1.1.0-3 → 1.2.0-1
- ros-humble-autoware-lanelet2-extension-python: 1.1.0-3 → 1.2.0-1
- ros-humble-autoware-lanelet2-extension-python-dbgsym: 1.1.0-3 → 1.2.0-1
- ros-humble-autoware-lanelet2-map-visualizer: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-lanelet2-map-visualizer-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-lanelet2-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-lanelet2-utils-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-localization-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-localization-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-localization-util: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-localization-util-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-map-height-fitter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-map-height-fitter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-map-loader: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-map-loader-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-map-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-map-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-map-projection-loader: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-map-projection-loader-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-marker-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-marker-utils-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-mission-planner: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-mission-planner-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-utils-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-velocity-obstacle-stop-module: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-velocity-obstacle-stop-module-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-velocity-planner: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-velocity-planner-common: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-velocity-planner-common-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-motion-velocity-planner-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-node: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-node-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-object-recognition-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-object-recognition-utils-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-objects-of-interest-marker-interface: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-objects-of-interest-marker-interface-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-osqp-interface: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-osqp-interface-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-path-generator: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-path-generator-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-perception-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-perception-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-perception-objects-converter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-perception-objects-converter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-planning-factor-interface: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-planning-factor-interface-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-planning-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-planning-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-planning-test-manager: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-planning-test-manager-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-planning-topic-converter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-planning-topic-converter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-point-types: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-pose-initializer: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-pose-initializer-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-pyplot: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-qos-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-qp-interface: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-qp-interface-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-route-handler: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-route-handler-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-sample-sensor-kit-description: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-sample-vehicle-description: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-sensing-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-sensing-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-signal-processing: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-signal-processing-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-simple-pure-pursuit: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-simple-pure-pursuit-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-simulation-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-simulation-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-stop-filter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-stop-filter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-system-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-system-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-test-node: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-test-node-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-test-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-test-utils-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-testing: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-trajectory: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-trajectory-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-twist2accel: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-twist2accel-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-utils: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-debug: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-diagnostics: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-diagnostics-dbgsym: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-geometry: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-geometry-dbgsym: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-logging: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-math: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-math-dbgsym: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-pcl: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-rclcpp: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-system: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-system-dbgsym: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-tf: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-uuid: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-visualization: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-utils-visualization-dbgsym: 1.7.2-2 → 1.9.0-1
- ros-humble-autoware-v2x-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-v2x-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-vehicle-info-utils: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-vehicle-info-utils-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-vehicle-msgs: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-vehicle-msgs-dbgsym: 1.12.0-1 → 1.13.0-1
- ros-humble-autoware-vehicle-velocity-converter: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-vehicle-velocity-converter-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-velocity-smoother: 1.8.0-3 → 1.9.0-1
- ros-humble-autoware-velocity-smoother-dbgsym: 1.8.0-3 → 1.9.0-1
- ros-humble-behaviortree-cpp: 4.9.0-1 → 4.9.1-1
- ros-humble-behaviortree-cpp-dbgsym: 4.9.0-1 → 4.9.1-1
- ros-humble-bicycle-steering-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-bicycle-steering-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-bosch-locator-bridge: 2.1.15-1 → 2.1.16-1
- ros-humble-bosch-locator-bridge-dbgsym: 2.1.15-1 → 2.1.16-1
- ros-humble-bosch-locator-bridge-utils: 2.1.15-1 → 2.1.16-1
- ros-humble-bosch-locator-bridge-utils-dbgsym: 2.1.15-1 → 2.1.16-1
- ros-humble-clearpath-generator-gz: 1.3.2-1 → 1.3.3-1
- ros-humble-clearpath-gz: 1.3.2-1 → 1.3.3-1
- ros-humble-clearpath-simulator: 1.3.2-1 → 1.3.3-1
- ros-humble-common-interfaces: 4.9.1-1 → 4.9.2-1
- ros-humble-compass-msgs: 0.3.1-1 → 0.3.5-1
- ros-humble-compass-msgs-dbgsym: 0.3.1-1 → 0.3.5-1
- ros-humble-continental-msgs: 1.1.1-1 → 1.2.0-1
- ros-humble-continental-msgs-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-continental-srvs: 1.1.1-1 → 1.2.0-1
- ros-humble-continental-srvs-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-crazyflie: 1.0.4-1 → 1.0.5-1
- ros-humble-crazyflie-dbgsym: 1.0.4-1 → 1.0.5-1
- ros-humble-crazyflie-examples: 1.0.4-1 → 1.0.5-1
- ros-humble-crazyflie-interfaces: 1.0.4-1 → 1.0.5-1
- ros-humble-crazyflie-interfaces-dbgsym: 1.0.4-1 → 1.0.5-1
- ros-humble-crazyflie-py: 1.0.4-1 → 1.0.5-1
- ros-humble-crazyflie-server-py: 1.0.4-1 → 1.0.5-1
- ros-humble-crazyflie-sim: 1.0.4-1 → 1.0.5-1
- ros-humble-diagnostic-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-diagnostic-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-diff-drive-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-diff-drive-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-effort-controllers: 2.53.1-1 → 2.53.3-1
- ros-humble-effort-controllers-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-etsi-its-cam-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-ts-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-ts-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-ts-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-ts-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cam-ts-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-conversion-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-conversion-srvs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-conversion-srvs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cpm-ts-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cpm-ts-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cpm-ts-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cpm-ts-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-cpm-ts-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-ts-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-ts-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-ts-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-ts-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-denm-ts-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mapem-ts-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mapem-ts-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mapem-ts-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mapem-ts-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mapem-ts-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mcm-uulm-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mcm-uulm-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mcm-uulm-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mcm-uulm-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-mcm-uulm-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-messages: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-msgs-utils: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-primitives-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-rviz-plugins: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-rviz-plugins-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-spatem-ts-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-spatem-ts-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-spatem-ts-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-spatem-ts-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-spatem-ts-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-vam-ts-coding: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-vam-ts-coding-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-vam-ts-conversion: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-vam-ts-msgs: 3.4.0-1 → 3.5.0-1
- ros-humble-etsi-its-vam-ts-msgs-dbgsym: 3.4.0-1 → 3.5.0-1
- ros-humble-examples-tf2-py: 0.25.20-2 → 0.25.22-1
- ros-humble-fastrtps: 2.6.11-1 → 2.6.12-1
- ros-humble-fastrtps-dbgsym: 2.6.11-1 → 2.6.12-1
- ros-humble-force-torque-sensor-broadcaster: 2.53.1-1 → 2.53.3-1
- ros-humble-force-torque-sensor-broadcaster-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-forward-command-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-forward-command-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-foxglove-bridge: 3.4.2-1 → 3.4.3-2
- ros-humble-foxglove-bridge-dbgsym: 3.4.2-1 → 3.4.3-2
- ros-humble-foxglove-msgs: 3.4.2-1 → 3.4.3-2
- ros-humble-foxglove-msgs-dbgsym: 3.4.2-1 → 3.4.3-2
- ros-humble-fri-configuration-controller: 1.0.0-1 → 1.1.0-1
- ros-humble-fri-configuration-controller-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-fri-state-broadcaster: 1.0.0-1 → 1.1.0-1
- ros-humble-fri-state-broadcaster-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-fusioncore-core: 0.3.1-1 → 0.3.5-1
- ros-humble-fusioncore-datasets: 0.3.1-1 → 0.3.5-1
- ros-humble-fusioncore-gazebo: 0.3.1-1 → 0.3.5-1
- ros-humble-fusioncore-ros: 0.3.1-1 → 0.3.5-1
- ros-humble-fusioncore-ros-dbgsym: 0.3.1-1 → 0.3.5-1
- ros-humble-fusioncore-ublox: 0.3.1-1 → 0.3.5-1
- ros-humble-generate-parameter-library: 0.7.4-1 → 0.7.5-1
- ros-humble-generate-parameter-library-py: 0.7.4-1 → 0.7.5-1
- ros-humble-geometry-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-geometry-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-geometry2: 0.25.20-2 → 0.25.22-1
- ros-humble-gpio-controllers: 2.53.1-1 → 2.53.3-1
- ros-humble-gpio-controllers-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-gps-msgs: 2.1.2-1 → 3.1.0-1
- ros-humble-gps-msgs-dbgsym: 2.1.2-1 → 3.1.0-1
- ros-humble-gps-tools: 2.1.2-1 → 3.1.0-1
- ros-humble-gps-tools-dbgsym: 2.1.2-1 → 3.1.0-1
- ros-humble-gps-umd: 2.1.2-1 → 3.1.0-1
- ros-humble-gpsd-client: 2.1.2-1 → 3.1.0-1
- ros-humble-gpsd-client-dbgsym: 2.1.2-1 → 3.1.0-1
- ros-humble-graph-msgs: 0.2.0-3 → 0.2.1-1
- ros-humble-graph-msgs-dbgsym: 0.2.0-3 → 0.2.1-1
- ros-humble-gripper-controllers: 2.53.1-1 → 2.53.3-1
- ros-humble-gripper-controllers-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-imu-sensor-broadcaster: 2.53.1-1 → 2.53.3-1
- ros-humble-imu-sensor-broadcaster-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-joint-group-impedance-controller: 1.0.0-1 → 1.1.0-1
- ros-humble-joint-group-impedance-controller-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-joint-state-broadcaster: 2.53.1-1 → 2.53.3-1
- ros-humble-joint-state-broadcaster-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-joint-trajectory-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-joint-trajectory-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-kuka-agilus-support: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-control-mode-handler: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-control-mode-handler-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-controllers: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-cybertech-support: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-driver-interfaces: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-driver-interfaces-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-drivers: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-drivers-core: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-drivers-core-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-event-broadcaster: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-event-broadcaster-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-external-control-sdk: 1.4.1-1 → 2.0.0-1
- ros-humble-kuka-external-control-sdk-examples: 1.4.1-1 → 2.0.0-1
- ros-humble-kuka-fortec-support: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-gazebo: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-gazebo-dbgsym: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-iiqka-eac-driver: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-iiqka-eac-driver-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-iontec-support: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-kr-moveit-config: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-kss-message-handler: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-kss-message-handler-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-lbr-iisy-moveit-config: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-lbr-iisy-support: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-lbr-iiwa-moveit-config: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-lbr-iiwa-support: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-mock-hardware-interface: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-mock-hardware-interface-dbgsym: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-quantec-support: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-resources: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-robot-descriptions: 1.0.0-1 → 1.1.2-1
- ros-humble-kuka-rsi-driver: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-rsi-driver-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-rsi-simulator: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-sunrise-fri-driver: 1.0.0-1 → 1.1.0-1
- ros-humble-kuka-sunrise-fri-driver-dbgsym: 1.0.0-1 → 1.1.0-1
- ros-humble-launch-ros: 0.19.13-1 → 0.19.14-1
- ros-humble-launch-testing-ros: 0.19.13-1 → 0.19.14-1
- ros-humble-librealsense2: 2.58.2-1 → 2.58.3-1
- ros-humble-librealsense2-dbgsym: 2.58.2-1 → 2.58.3-1
- ros-humble-mbf-abstract-core: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-abstract-nav: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-abstract-nav-dbgsym: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-msgs: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-msgs-dbgsym: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-simple-core: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-simple-nav: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-simple-nav-dbgsym: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-test-utility: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-test-utility-dbgsym: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-utility: 1.0.5-1 → 1.2.1-1
- ros-humble-mbf-utility-dbgsym: 1.0.5-1 → 1.2.1-1
- ros-humble-mecanum-drive-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-mecanum-drive-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-message-filters: 4.3.18-1 → 4.3.19-1
- ros-humble-message-filters-dbgsym: 4.3.18-1 → 4.3.19-1
- ros-humble-message-tf-frame-transformer: 1.1.3-1 → 1.1.3-2
- ros-humble-message-tf-frame-transformer-dbgsym: 1.1.3-1 → 1.1.3-2
- ros-humble-mola: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-bridge-ros2: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-bridge-ros2-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-demos: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-imu-preintegration: 1.16.1-1 → 1.17.1-1
- ros-humble-mola-imu-preintegration-dbgsym: 1.16.1-1 → 1.17.1-1
- ros-humble-mola-input-lidar-bin-dataset: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-input-lidar-bin-dataset-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-input-rawlog: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-input-rawlog-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-input-rosbag1: 0.2.0-1 → 0.3.0-1
- ros-humble-mola-input-rosbag1-dbgsym: 0.2.0-1 → 0.3.0-1
- ros-humble-mola-input-rosbag2: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-input-rosbag2-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-input-video: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-input-video-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-kernel: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-kernel-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-launcher: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-launcher-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-lidar-odometry: 2.2.1-1 → 3.0.0-1
- ros-humble-mola-lidar-odometry-dbgsym: 2.2.1-1 → 3.0.0-1
- ros-humble-mola-metric-maps: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-metric-maps-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-msgs: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-msgs-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-pose-list: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-pose-list-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-relocalization: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-relocalization-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-traj-tools: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-traj-tools-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-viz: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-viz-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-viz-imgui: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-viz-imgui-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-yaml: 2.9.0-1 → 3.0.0-1
- ros-humble-mola-yaml-dbgsym: 2.9.0-1 → 3.0.0-1
- ros-humble-motion-capture-tracking: 1.0.6-1 → 1.0.9-1
- ros-humble-motion-capture-tracking-dbgsym: 1.0.6-1 → 1.0.9-1
- ros-humble-motion-capture-tracking-interfaces: 1.0.6-1 → 1.0.9-1
- ros-humble-motion-capture-tracking-interfaces-dbgsym: 1.0.6-1 → 1.0.9-1
- ros-humble-move-base-flex: 1.0.5-1 → 1.2.1-1
- ros-humble-moveit-visual-tools: 4.1.2-1 → 4.2.0-1
- ros-humble-moveit-visual-tools-dbgsym: 4.1.2-1 → 4.2.0-1
- ros-humble-mp2p-icp: 2.10.3-1 → 2.12.0-1
- ros-humble-mqtt-client: 2.4.1-2 → 2.5.0-1
- ros-humble-mqtt-client-dbgsym: 2.4.1-2 → 2.5.0-1
- ros-humble-mqtt-client-interfaces: 2.4.1-2 → 2.5.0-1
- ros-humble-mqtt-client-interfaces-dbgsym: 2.4.1-2 → 2.5.0-1
- ros-humble-mrpt-apps: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-apps-cli: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-apps-cli-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-apps-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-apps-gui: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-apps-gui-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-bayes: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-bayes-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-common: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-comms: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-comms-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-config: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-config-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-containers: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-containers-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-core: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-core-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-data: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-examples-cpp: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-examples-cpp-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-expr: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-expr-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-graphs: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-graphs-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-graphslam: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-graphslam-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-gui: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-gui-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-hwdrivers: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-hwdrivers-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-img: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-img-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-imgui: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-imgui-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-io: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-io-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-kinematics: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-kinematics-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-libapps: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libapps-cli: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-libapps-cli-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-libapps-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libapps-gui: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-libapps-gui-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-libbase: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libbase-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libgui: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libgui-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libhwdrivers: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libhwdrivers-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libmaps: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libmaps-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libmath: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libmath-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libnav: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libnav-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libobs: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libobs-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libopengl: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libopengl-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libposes: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libposes-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libslam: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libslam-dbgsym: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-libtclap: 2.15.18-1 → 2.15.20-1
- ros-humble-mrpt-maps: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-maps-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-math: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-math-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-nav: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-nav-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-obs: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-obs-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-opengl: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-opengl-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-path-planning: 1.0.0-1 → 1.0.1-1
- ros-humble-mrpt-path-planning-dbgsym: 1.0.0-1 → 1.0.1-1
- ros-humble-mrpt-poses: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-poses-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-random: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-random-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-rtti: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-rtti-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-serialization: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-serialization-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-slam: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-slam-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-system: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-system-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-tfest: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-tfest-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-topography: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-topography-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-typemeta: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-viz: 3.0.4-1 → 3.1.2-1
- ros-humble-mrpt-viz-dbgsym: 3.0.4-1 → 3.1.2-1
- ros-humble-mujoco-vendor: 0.0.8-2 → 0.0.9-1
- ros-humble-mvsim: 1.3.0-1 → 1.4.0-1
- ros-humble-mvsim-dbgsym: 1.3.0-1 → 1.4.0-1
- ros-humble-nanoflann: 1.10.1-1 → 1.11.0-1
- ros-humble-nav-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-nav-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-nebula-continental: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-continental-common: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-continental-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-continental-decoders: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-continental-decoders-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-continental-hw-interfaces: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-continental-hw-interfaces-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-core-common: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-core-common-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-core-decoders: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-core-hw-interfaces: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-core-ros: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-core-ros-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-hesai: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-hesai-common: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-hesai-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-hesai-decoders: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-hesai-decoders-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-hesai-hw-interfaces: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-hesai-hw-interfaces-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-msgs: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-msgs-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-robosense: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-robosense-common: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-robosense-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-robosense-decoders: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-robosense-decoders-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-robosense-hw-interfaces: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-robosense-hw-interfaces-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-sample: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-sample-common: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-sample-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-sample-decoders: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-sample-decoders-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-sample-hw-interfaces: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-sample-hw-interfaces-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne-common: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne-common-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne-decoders: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne-decoders-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne-hw-interfaces: 1.1.1-1 → 1.2.0-1
- ros-humble-nebula-velodyne-hw-interfaces-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-pandar-msgs: 1.1.1-1 → 1.2.0-1
- ros-humble-pandar-msgs-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-parameter-traits: 0.7.4-1 → 0.7.5-1
- ros-humble-pid-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-pid-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-pose-broadcaster: 2.53.1-1 → 2.53.3-1
- ros-humble-pose-broadcaster-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-position-controllers: 2.53.1-1 → 2.53.3-1
- ros-humble-position-controllers-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-proxsuite: 0.6.5-1 → 0.7.3-1
- ros-humble-py-trees: 2.4.0-1 → 2.5.0-1
- ros-humble-py-trees-js: 0.6.6-1 → 0.6.7-1
- ros-humble-py-trees-ros: 2.4.0-1 → 2.5.0-1
- ros-humble-py-trees-ros-interfaces: 2.1.1-1 → 2.1.2-1
- ros-humble-py-trees-ros-interfaces-dbgsym: 2.1.1-1 → 2.1.2-1
- ros-humble-py-trees-ros-tutorials: 2.4.0-1 → 2.5.0-1
- ros-humble-py-trees-ros-viewer: 0.2.5-1 → 0.3.0-1
- ros-humble-range-sensor-broadcaster: 2.53.1-1 → 2.53.3-1
- ros-humble-range-sensor-broadcaster-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-rcpputils: 2.4.6-1 → 2.4.7-1
- ros-humble-rcpputils-dbgsym: 2.4.6-1 → 2.4.7-1
- ros-humble-rcutils: 5.1.8-1 → 5.1.9-1
- ros-humble-rcutils-dbgsym: 5.1.8-1 → 5.1.9-1
- ros-humble-realsense2-camera: 4.58.2-1 → 4.58.3-1
- ros-humble-realsense2-camera-dbgsym: 4.58.2-1 → 4.58.3-1
- ros-humble-realsense2-camera-msgs: 4.58.2-1 → 4.58.3-1
- ros-humble-realsense2-camera-msgs-dbgsym: 4.58.2-1 → 4.58.3-1
- ros-humble-realsense2-description: 4.58.2-1 → 4.58.3-1
- ros-humble-rig-reconfigure: 1.6.0-1 → 1.6.1-1
- ros-humble-rig-reconfigure-dbgsym: 1.6.0-1 → 1.6.1-1
- ros-humble-rko-lio: 0.3.0-1 → 0.3.2-1
- ros-humble-rko-lio-dbgsym: 0.3.0-1 → 0.3.2-1
- ros-humble-rmw: 6.1.2-1 → 6.1.3-1
- ros-humble-rmw-dbgsym: 6.1.2-1 → 6.1.3-1
- ros-humble-rmw-desert: 1.0.5-1 → 1.0.6-1
- ros-humble-rmw-desert-dbgsym: 1.0.5-1 → 1.0.6-1
- ros-humble-rmw-implementation-cmake: 6.1.2-1 → 6.1.3-1
- ros-humble-rmw-zenoh-cpp: 0.1.8-1 → 0.1.9-1
- ros-humble-rmw-zenoh-cpp-dbgsym: 0.1.8-1 → 0.1.9-1
- ros-humble-robosense-msgs: 1.1.1-1 → 1.2.0-1
- ros-humble-robosense-msgs-dbgsym: 1.1.1-1 → 1.2.0-1
- ros-humble-ros2-controllers: 2.53.1-1 → 2.53.3-1
- ros-humble-ros2-controllers-test-nodes: 2.53.1-1 → 2.53.3-1
- ros-humble-ros2action: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2cli: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2cli-test-interfaces: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2cli-test-interfaces-dbgsym: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2component: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2doctor: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2interface: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2launch: 0.19.13-1 → 0.19.14-1
- ros-humble-ros2lifecycle: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2lifecycle-test-fixtures: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2lifecycle-test-fixtures-dbgsym: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2multicast: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2node: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2param: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2pkg: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2run: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2service: 0.18.18-1 → 0.18.19-1
- ros-humble-ros2topic: 0.18.18-1 → 0.18.19-1
- ros-humble-rqt-joint-trajectory-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-rqt-msg: 1.2.0-1 → 1.2.1-1
- ros-humble-rqt-tf-tree: 1.1.0-1 → 1.1.1-1
- ros-humble-rviz-2d-overlay-msgs: 1.4.0-1 → 1.4.2-1
- ros-humble-rviz-2d-overlay-msgs-dbgsym: 1.4.0-1 → 1.4.2-1
- ros-humble-rviz-2d-overlay-plugins: 1.4.0-1 → 1.4.2-1
- ros-humble-rviz-2d-overlay-plugins-dbgsym: 1.4.0-1 → 1.4.2-1
- ros-humble-rviz-assimp-vendor: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-common: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-common-dbgsym: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-default-plugins: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-default-plugins-dbgsym: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-mbf-plugins: 1.0.5-1 → 1.2.1-1
- ros-humble-rviz-mbf-plugins-dbgsym: 1.0.5-1 → 1.2.1-1
- ros-humble-rviz-ogre-vendor: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-ogre-vendor-dbgsym: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-rendering: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-rendering-dbgsym: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-rendering-tests: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-visual-testing-framework: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz-visual-tools: 4.1.4-1 → 4.2.0-1
- ros-humble-rviz-visual-tools-dbgsym: 4.1.4-1 → 4.2.0-1
- ros-humble-rviz2: 11.2.27-1 → 11.2.28-1
- ros-humble-rviz2-dbgsym: 11.2.27-1 → 11.2.28-1
- ros-humble-sbg-driver: 3.3.2-1 → 3.4.0-1
- ros-humble-sbg-driver-dbgsym: 3.3.2-1 → 3.4.0-1
- ros-humble-scan-2d-merger: 2.0.0-3 → 2.1.0-2
- ros-humble-scan-2d-merger-dbgsym: 2.0.0-3 → 2.1.0-2
- ros-humble-sensor-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-sensor-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-sensor-msgs-py: 4.9.1-1 → 4.9.2-1
- ros-humble-septentrio-gnss-driver: 1.4.7-2 → 1.4.8-1
- ros-humble-septentrio-gnss-driver-dbgsym: 1.4.7-2 → 1.4.8-1
- ros-humble-shape-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-shape-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-std-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-std-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-std-srvs: 4.9.1-1 → 4.9.2-1
- ros-humble-std-srvs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-steering-controllers-library: 2.53.1-1 → 2.53.3-1
- ros-humble-steering-controllers-library-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-stereo-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-stereo-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-swri-console: 2.1.3-1 → 2.1.4-1
- ros-humble-swri-console-dbgsym: 2.1.3-1 → 2.1.4-1
- ros-humble-sync-tooling-msgs: 0.2.10-1 → 0.2.11-1
- ros-humble-sync-tooling-msgs-dbgsym: 0.2.10-1 → 0.2.11-1
- ros-humble-tecgihan-driver: 0.1.2-1 → 0.3.0-1
- ros-humble-tf2: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-bullet: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-dbgsym: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-eigen: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-eigen-kdl: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-eigen-kdl-dbgsym: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-geometry-msgs: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-kdl: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-msgs: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-msgs-dbgsym: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-py: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-py-dbgsym: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-ros: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-ros-dbgsym: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-ros-py: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-sensor-msgs: 0.25.20-2 → 0.25.22-1
- ros-humble-tf2-tools: 0.25.20-2 → 0.25.22-1
- ros-humble-toppra: 0.6.8-1 → 0.6.9-1
- ros-humble-toppra-dbgsym: 0.6.8-1 → 0.6.9-1
- ros-humble-trajectory-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-trajectory-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-tricycle-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-tricycle-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-tricycle-steering-controller: 2.53.1-1 → 2.53.3-1
- ros-humble-tricycle-steering-controller-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-ur: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-bringup: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-calibration: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-calibration-dbgsym: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-client-library: 2.13.0-1 → 2.14.0-1
- ros-humble-ur-client-library-dbgsym: 2.13.0-1 → 2.14.0-1
- ros-humble-ur-controllers: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-controllers-dbgsym: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-dashboard-msgs: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-dashboard-msgs-dbgsym: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-description: 2.11.0-1 → 2.13.0-1
- ros-humble-ur-moveit-config: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-msgs: 2.5.0-1 → 2.6.0-1
- ros-humble-ur-msgs-dbgsym: 2.5.0-1 → 2.6.0-1
- ros-humble-ur-robot-driver: 2.13.2-1 → 2.14.0-1
- ros-humble-ur-robot-driver-dbgsym: 2.13.2-1 → 2.14.0-1
- ros-humble-velocity-controllers: 2.53.1-1 → 2.53.3-1
- ros-humble-velocity-controllers-dbgsym: 2.53.1-1 → 2.53.3-1
- ros-humble-visualization-msgs: 4.9.1-1 → 4.9.2-1
- ros-humble-visualization-msgs-dbgsym: 4.9.1-1 → 4.9.2-1
- ros-humble-warehouse-ros: 2.0.5-1 → 2.0.7-1
- ros-humble-warehouse-ros-dbgsym: 2.0.5-1 → 2.0.7-1
- ros-humble-warehouse-ros-sqlite: 1.0.8-1 → 1.0.9-1
- ros-humble-warehouse-ros-sqlite-dbgsym: 1.0.8-1 → 1.0.9-1
- ros-humble-wireless-msgs: 1.1.5-2 → 1.1.6-1
- ros-humble-wireless-msgs-dbgsym: 1.1.5-2 → 1.1.6-1
- ros-humble-wireless-watcher: 1.1.5-2 → 1.1.6-1
- ros-humble-wireless-watcher-dbgsym: 1.1.5-2 → 1.1.6-1
- ros-humble-yasmin: 5.0.0-1 → 6.1.0-1
- ros-humble-yasmin-dbgsym: 5.0.0-1 → 6.1.0-1
- ros-humble-yasmin-msgs: 5.0.0-1 → 6.0.0-1
- ros-humble-yasmin-msgs-dbgsym: 5.0.0-1 → 6.0.0-1
- ros-humble-yasmin-pcl: 5.0.0-1 → 6.1.0-1
- ros-humble-yasmin-pcl-dbgsym: 5.0.0-1 → 6.1.0-1
- ros-humble-yasmin-ros: 5.0.0-1 → 6.1.0-1
- ros-humble-yasmin-ros-dbgsym: 5.0.0-1 → 6.1.0-1
- ros-humble-zenoh-cpp-vendor: 0.1.8-1 → 0.1.9-1
- ros-humble-zenoh-cpp-vendor-dbgsym: 0.1.8-1 → 0.1.9-1
- ros-humble-zenoh-security-tools: 0.1.8-1 → 0.1.9-1
- ros-humble-zenoh-security-tools-dbgsym: 0.1.8-1 → 0.1.9-1
Removed Packages [23]:
- ros-humble-autoware-utils-logging-dbgsym
- ros-humble-franka-gripper
- ros-humble-franka-gripper-dbgsym
- ros-humble-iiqka-moveit-example
- ros-humble-iiqka-moveit-example-dbgsym
- ros-humble-kinematics-interface-pinocchio
- ros-humble-kinematics-interface-pinocchio-dbgsym
- ros-humble-linear-feedback-controller
- ros-humble-linear-feedback-controller-dbgsym
- ros-humble-linear-feedback-controller-msgs
- ros-humble-linear-feedback-controller-msgs-dbgsym
- ros-humble-mp2p-icp-dbgsym
- ros-humble-ply-utils
- ros-humble-ply-utils-dbgsym
- ros-humble-yasmin-cli
- ros-humble-yasmin-demos
- ros-humble-yasmin-demos-dbgsym
- ros-humble-yasmin-editor
- ros-humble-yasmin-factory
- ros-humble-yasmin-factory-dbgsym
- ros-humble-yasmin-plugins-manager
- ros-humble-yasmin-viewer
- ros-humble-yasmin-viewer-dbgsym
- “Adam Dabrowski”
- “Aditya Pande”
- “Alejandro Hernanadez”
- “Alexander Mock”
- “Ali Pahlevani”
- “Aron Svastits”
- “Audrow Nash”
- “Autoware”
- “Bence Magyar”
- “Berkay Karaman”
- “Chittaranjan Swaminathan”
- “Chris Lalancette”
- “Daniel Stonier”
- “Dave Coleman”
- “David Wong”
- “Davide Costa”
- “Davide Faconti”
- “Ethan Gao”
- “Felix Exner”
- “Foxglove”
- “Fumiya Watanabe”
- “G.A. vd. Hoorn”
- “Geoffrey Biggs”
- “Gergely Kovacs”
- “Hung Pham”
- “Isaac I.Y. Saito”
- “Ivan Paunovic”
- “Jacob Perron”
- “Jean-Pierre Busch”
- “Jian Kang”
- “Jose Luis Blanco-Claraco”
- “Jose-Luis Blanco-Claraco”
- “Junya Sasaki”
- “Justin Carpentier”
- “Kosuke Takeuchi”
- “Kyoichi Sugahara”
- “Lennart Reiher”
- “Luis Camero”
- “M. Fatih Cırıt”
- “Mamoru Sobue”
- “Manan Kharwar”
- “Masahiro Sakamoto”
- “Max Schmeller”
- “Maxime CLEMENT”
- “Maxime Clement”
- “Meher Malladi”
- “Mete Fatih Cırıt”
- “Miguel Ángel González Santamarta”
- “Mike Lautman”
- “Mitsuhiro Sakamoto”
- “MoveIt Release Team”
- “Piotr Jaroszek”
- “Raul Sanchez Mateos”
- “Roni Kreinin”
- “Ryohsuke Mitsudome”
- “SBG Systems”
- “Sai Kishor Kothakota”
- “Satoshi OTA”
- “Satoshi Ota”
- “Shigeru Wakida”
- “Shunsuke Kimura”
- “Southwest Research Institute”
- “Taiki Tanaka”
- “Takagi, Isamu”
- “Takahiro Ishikawa-Aso”
- “Takamasa Horibe”
- “Takayuki Murooka”
- “Takumi Odashima”
- “Team Spatzenhirn”
- “Temkei Kem”
- “Ubuntu Robotics”
- “Wolfgang Hönig”
- “Xingang Liu”
- “Yadunund”
- “Yamato Ando”
- “Yoshi Ri”
- “Yuki Takagi”
- “Yukihiro Saito”
- “Yukinari Hisaki”
- “Zulfaqar Azmi”
- “amc-nu”
- “bmagyar”
- “frozenreboot”
- “lazytatzv”
- “li9i”
- “mitsudome-r”
- “xingang liu”
- Fabian Koenig
- LibRealSense ROS Team
- Maik Knof
- Miguel Ángel González Santamarta
- Stefan Laible
- Tibor Dome
