Nayantra – Natural Language Fleet Control via LLM + Open-RMF + MCP
TL;DR: Nayantra is an open-source framework that lets you command autonomous robot fleets in plain English. An LLM communicates with Open-RMF through the Model Context Protocol (MCP), routing a single natural language prompt all the way down to Nav2 on real hardware or in NVIDIA Isaac Sim. The full pipeline also runs locally on a laptop in stub mode, no GPU, no RMF cluster required.
Motivation: Controlling a robot fleet today typically requires writing dispatcher code, manually constructing task requests, and deeply understanding Open-RMF’s API surface. I wanted to explore whether a large language model, given the right tools, could act as a natural-language interface on top of RMF, letting operators or developers issue commands the way they’d describe them to a colleague.
What Nayantra does:
  • Accepts free-form English commands (e.g. “Send robot A to delivery point 3 and put robot B on standby”)
  • An LLM parses intent and calls Open-RMF APIs via MCP tool calls
  • Tasks are dispatched through Open-RMF and executed by Nav2 on real robots or inside Isaac Sim
  • Stub mode lets you run and test the entire pipeline locally with no infrastructure
Current status: This is an early open-source release. The stub mode works end-to-end and is the easiest way to get started. Real-robot and Isaac Sim integration is functional but still maturing.
Repo: GitHub - shashankbr27/nayantra: An open-source framework that connects large language models to autonomous robot fleets via the Model Context Protocol (MCP) and Open-RMF. Drives NVIDIA Isaac Sim or real Nav2 robots; a built-in stub mode runs the full pipeline on a laptop. · GitHub
I’d love feedback from folks with deeper Open-RMF and Nav2 experience, especially around task API design, edge cases in fleet dispatch, and ideas for extending the MCP tool surface. Issues, PRs, and blunt criticism all welcome.
Thanks for sharing this @shashank_br !
I think this is an excellent ecosystem addition for Open-RMF. If you have any feedback on how the Open-RMF APIs can better accommodate integrating into an MCP server, we’re happy to hear about it.
If you’d like to present on your work, this could be a great topic for the Interoperability Special Interest Group that we hold once per month. Feel free to message me directly if you’d like to be added to the agenda.
Hi @grey,
Following up on the Interoperability SIG offer. I’d love to be added to the next agenda. A 10-15 min walkthrough of Nayantra (architecture, planner, MCP tool surface, Isaac Sim bridge, demo) with ~10 min Q&A would be a comfortable slot. Could also do shorter if the agenda’s tight.
My time zone is IST (UTC+5:30); I can be flexible for the usual SIG slot. Let me know what dates are open and what format you’d prefer (slides, live demo, or both).
Thanks again for the invite!
