Hi all, your friendly neighborhood navigator here.
As part of the 2021 ROS Developers Day https://www.theconstructsim.com/ros-developers-day-2021/ I prepared some demonstrations of capabilities in Nav2. To make it more approachable, I created a generic python3 BasicNavigator object to do interact with the Nav2 stack to make these demos more straight forward.
I decided along the way this is something that would likely gain a great amount of reuse for other users, so I’ve created the new nav2_python_commander package in Nav2 containing python3 methods to do most everything with Nav2 in order to build basic applications (goToPose(), changeMap(), setInitialPose(), followWaypoints(), etc). The README.md file contains a great deal of context, demos, examples, and the API provided. There are also some example tasks like security, picking, and inspection to show-case how the API makes building basic POCs fast and simple.
I am, however, not primarily a python3 developer. I would appreciate if community members could take a look at the PR below and leave a review to make sure I’m best using the Python3 capabilities / tools / styling so more pythonic users don’t eye-roll me later
. If you have a few minutes and are a python3 developer, please leave me a review.
https://github.com/ros-planning/navigation2/pull/2411
An example application to go to a pose:
def main():
rclpy.init()
navigator = BasicNavigator()
# Set our demo's initial pose
initial_pose = PoseStamped()
initial_pose.header.frame_id = 'map'
initial_pose.header.stamp = navigator.get_clock().now().to_msg()
initial_pose.pose.position.x = 3.45
initial_pose.pose.position.y = 2.15
initial_pose.pose.orientation.z = 1.0
initial_pose.pose.orientation.w = 0.0
navigator.setInitialPose(initial_pose)
# Wait for navigation to fully activate, since autostarting nav2
navigator.waitUntilNav2Active()
# Go to our demos first goal pose
goal_pose = PoseStamped()
goal_pose.header.frame_id = 'map'
goal_pose.header.stamp = navigator.get_clock().now().to_msg()
goal_pose.pose.position.x = -2.0
goal_pose.pose.position.y = -0.5
goal_pose.pose.orientation.w = 1.0
navigator.goToPose(goal_pose)
while not navigator.isNavComplete():
# Do something with the feedback
feedback = navigator.getFeedback()
# Some navigation timeout to demo cancellation
if Duration.from_msg(feedback.navigation_time) > Duration(seconds=600.0):
navigator.cancelNav()
# Do something depending on the return code
result = navigator.getResult()
if result == NavigationResult.SUCCEEDED:
print('Goal succeeded!')
elif result == NavigationResult.CANCELED:
print('Goal was canceled!')
elif result == NavigationResult.FAILED:
print('Goal failed!')
navigator.lifecycleShutdown()
I hope to have this merged in and ready for use by the end of the month! If there’s any functions missing, please also drop me a note in the PR and I’ll make sure to add it. I think this is a pretty exhaustive look at the available actions / services in Nav2.
Happy pythoning,
Steve
