Migrating ros2/launch ROS specific packages to ros2/launch_ros
Hi everyone!
Just as an FYI, in order to integrate Apex.AI contributions to launch testing, and to enable its use in lower layers of the ROS 2 stack, ROS specific packages are being moved out of the ros2/launch repository and into the brand new ros2/launch_ros repository.
If you’re maintaining a source checkout for development on master, please update your workspace using the latest ros2.repos file.
Thanks for the heads up, @hidmic. You say the packages “are being moved,” but are they in fact already moved, and thus using the latest ros2.repos file as of now will get the rename?
@kyrofa just moved with remove ROS specific launch packages which were moved to ros2/launch_ros by wjwwood · Pull Request #211 · ros2/launch · GitHub and remove ros-agnostic packages which should not be imported from launch by wjwwood · Pull Request #1 · ros2/launch_ros · GitHub, and yes, using the latest ros2.repos will get the rename.
