KUKA LBRs (iiwa and med) now on RoboStack
Happy to share that drivers for KUKA iiwa and med robots can now conveniently be installed via RoboStack (for Humble and Jazzy) also on macOS :green_apple:. Simply:
pixi init ros-ftw -c robostack-jazzy -c conda-forge
cd ros-ftw
pixi add \
    ros-jazzy-desktop \
    ros-jazzy-lbr-fri-ros2-stack \
    ros-jazzy-med7-moveit-config \
    ros-jazzy-med14-moveit-config \
    ros-jazzy-iiwa7-moveit-config \
    ros-jazzy-iiwa14-moveit-config \
    filelock
Then e.g. launch MoveIt on a mock setup:
pixi run ros2 launch lbr_bringup mock.launch.py
pixi run ros2 launch lbr_bringup move_group.launch.py rviz:=true
Below is a demo, instantiating a blank environment to a hand-guided system on a Mac in under a minute (ros2 launch lbr_bringup hardware.launch.py ctrl:=admittance_controller):
lbr-stack-pixi-ezgif.com-video-to-gif-converter(1)
Currently, only FRI 1.x are distributed (pixi add lbr-fri-client-sdk=1.x to specify), but we will be working on distributing 1.x-3.0.
This incredible work was contributed by Kenichi Maeda, Gary Lvov, Silvio Traversaro, Tobias Fischer, and Dhruv Deepikaben Patel.
RoboStack: github.com/RoboStack
LBR-Stack: github.com/lbr-stack/lbr_fri_ros2_stack
