Hi everyone,
I’d like to share our recent work on decentralized multi-agent reinforcement learning (MARL) for multi-robot task assignment and navigation in industrial environments.
Paper: Learning Multi-Agent Task Assignment and Navigation in the Factory: From Simulation to Real Robots
Videos of the real deployment here.
In this work, we investigate how multiple mobile robots can coordinate to service multiple machines, navigate to collect completed parts, and to deliver them to designated storage areas without relying on a centralized execution policy.
We introduce FMAPPO (Feature-fusion Multi-Agent PPO), which combines 2D LiDAR observations with task-specific state information to support joint task assignment and navigation.
Our workflow makes use of high-fidelity simulation using NVIDIA Isaac Sim/Isaac Lab and then deploys directly to physical robot experiments through ROS 2. Beyond evaluating task performance in simulation, we investigate how the policy behaves on real robots, including its sensitivity to command update frequency.
The goal is to better understand the challenges of deploying decentralized RL policies on physical robotic systems, where sensing and control constraints matter alongside learning performance.
I’d be interested in discussing:
Designing realistic simulation environments for multi-robot RL.
Integrating learned policies with ROS 2 and physical robot platforms.
Evaluating sim-to-real transfer and the sensitivity of learned policies to control update frequency.
The implementation is not publicly available yet, but I plan to share the code after the paper is accepted.
If you’re working on similar problems, I’d be glad to exchange ideas!
