Multi-Robot Fleet Management System using ROS2, Nav2, and Gazebo
I am developing a multi-robot fleet management system in a simulated warehouse environment using ROS2 (Humble) and Gazebo. The system is designed to study scalable coordination and task allocation across multiple autonomous mobile robots operating in a structured environment.
The architecture follows a distributed approach where each robot is implemented as an independent agent node responsible for navigation, execution, and state reporting. A centralized fleet manager node handles global task allocation and coordination. Communication is implemented using ROS2 topics, services, and action interfaces to enable asynchronous and real-time interaction between components.
Navigation is implemented using the Nav2 stack, integrating localization, global and local path planning, and obstacle avoidance. LiDAR-based perception is used for environmental awareness and safe navigation within the simulated warehouse.
The system supports dynamic task allocation, where robots receive pick-and-deliver tasks, compute feasible paths, and execute them while continuously publishing execution status. A typical workflow involves a robot navigating to a shelf location, performing a simulated pickup, and delivering the item to a designated drop-off point.
This project focuses on understanding distributed robotic system design, inter-node communication, and multi-robot coordination challenges such as scalability and synchronization. Future work includes implementing conflict resolution strategies, fleet-level optimization, and extending the system toward real-world deployment.
Great work, Arjun. This is a strong project, and I’d love to contribute and help port the simulation to the latest Gazebo sim if possible. We can also discuss ways to expand the project if you’re interested.
This is very impressive. I would also love to contribute to the project as well!
