MuJoCo Simulation and ROS2 Control Workflow | Piper Robotic Arm for Embodied AI
This project is a MuJoCo-based simulation foundation for the Piper robotic arm. It is designed to provide a general-purpose MuJoCo simulation environment for the Piper arm, with support for robot control testing and simulation workflow development.
Project has already completed
- the launch of the C++ based simulation environment
- control testing of the simulated robot using a test ROS 2 control plugin
Recommended Environment
- Operating System: Ubuntu 22.04 or compatible Linux distribution
- ROS Version: ROS 2 Humble
- Compiler: C++17 or later
Reference & Resources
- Reference Project:
https://github.com/unitreerobotics/unitree_mujoco - PiPER robotic arm platform:
https://global.agilex.ai/products/piper
The following sections provide step-by-step guidance for building the current version of the Piper MuJoCo simulation environment and using the ROS 2 test plugin to control the robot in simulation.
1.Project File Structure
agilex@agilex-Bellator-N176B:~/project/agilex_arm_mujoco$ tree -L 3
βββ agilex_arm
β βββ agilex_piper
β βββ assets
β βββ piper_body.xml
β βββ piper.xml
β βββ scene.xml
βββ images
βββ README_EN.md
βββ readme.md
βββ simulate
βββ CMakeLists.txt
βββ config.yaml
βββ mujoco
β βββ bin
β βββ include
β βββ lib
β βββ model
β βββ sample
β βββ simulate
β βββ THIRD_PARTY_NOTICES
βββ src
βββ lodepng
βββ main.cc
βββ param.h
βββ plugin_manager.cc
βββ plugin_manager.h
βββ ros2_control_plugin.cc
βββ ros2_control_plugin.h
βββ sim_plugin.h
2.Project Setup & Build
2.1 Build the agilex_arm_mujoco Project
The build process for the agilex_arm_mujoco project follows the same workflow as the unitree_mujoco project.
This section provides a step-by-step guide to setting up the simulation base, including optional instructions for enabling the ROS 2 control plugin.
Step 1.Clone the Repository
First, create a working directory and clone the project repository:
mkdir agilex_arm && cd agilex_arm
git clone https://github.com/yanyuze1/agilex_arm_mujoco.git
By default, the project includes MuJoCo 3.3.0 for ROS 2 control testing.
If you want to use a different MuJoCo version, download and replace it manually before building.
Step 2. Two Build Modes
The agilex_arm_mujoco project supports two build modes:
- Option 1: Build without the ROS 2 plugin
- Option 2: Build with the ROS 2 plugin enabled
Choose the mode based on your development needs.
Option 1: Without the ROS 2 Plugin
- Step 1: Edit
agilex_mujoco/simulate/CMakeLists.txt, change the default enabled ros2 plugin mode toOFF
# from
option(AGILEX_ENABLE_ROS2_CONTROL "Build ROS2 control plugin" ON)
# change to
option(AGILEX_ENABLE_ROS2_CONTROL "Build ROS2 control plugin" OFF)
- Step 2: Build the Project. After editing the file, build the simulation base:
cd agilex_arm_mujoco/simulate
mkdir build && cd build
cmake ..
make -j4
Option 2: With the ROS 2 Plugin Enabled
If you want to test robot control through the ROS 2 plugin, keep the default configuration and build the required ROS 2 dependencies first.
- Step 1: Clone the Dependency Workspace
Create or enter theagilex_armdirectory and clone the repository:
cd agilex_arm
git clone https://github.com/yanyuze1/agilex_ws.git
- Step 2: Build ROS 2 Dependencies
Build the required packages in the ROS 2 workspace:
cd agilex_ws
colcon build --symlink-install --packages-up-to mujoco_ros2_control agilex_piper_mujoco
source install/setup.bash
- Step 3: Build the Simulation Base
After the dependency build is complete, compile the simulation project:
cd agilex_mujoco/simulate
cmake ..
make -j4
2.2 Run the agilex_arm_mujoco Project
The agilex_arm_mujoco project provides two runtime modes:
- Start the simulation base only
- Start the simulation base with the ROS 2 plugin enabled
Choose the mode according to your development and testing needs.
2.2.1 Start the Simulation Base Only
If you only want to launch the simulation environment without ROS 2 integration, use the following command:
./agilex_mujoco -h
./agilex_mujoco -r piper -s scene.xml
./agilex_mujoco -r piper -s scene.xml -p ros2_control
After successful execution, the MuJoCo simulation environment will launch automatically, displaying the Piper robotic arm in the MuJoCo simulation scene.
2.2.2 Start the Simulation Base with the ROS 2 Plugin Enabled
If you only want to launch the simulation environment with ROS 2 integration, use the following command:
cd agilex_ws
ros2 launch agilex_piper_mujoco bringup_agilex_mujoco_cartesian_motion_controller.launch.py agilex_mujoco_exec:=/home/agilex/project/piper/agilex_mujoco/simulate/build/agilex_mujoco # The current project uses absolute paths. Please modify them according to your own local path.
When the launch is successful, a MuJoCo simulation window will open and display the Piper robotic arm in the simulation environment.
Once the environment is fully loaded, you can start sending ROS 2 control commands.
Usage Situation
1. Send a Target End-Effector Pose
Use the following command to publish a target pose for the end effector:
ros2 topic pub --once /agilex_piper_cartesian_motion_controller/target_frame \
geometry_msgs/msg/PoseStamped "{
header: {frame_id: 'base_link'},
pose: {
position: {x: 0.2, y: 0.0, z: 0.2},
orientation: {x: 0.0, y: 1.0, z: 0.0, w: 0.0}
2. Control the Gripper
# Open the Gripper
ros2 topic pub --once /agilex_piper_gripper_position_controller/commands \
std_msgs/msg/Float64MultiArray "{data: [0.035, -0.035]}"
# Close the Gripper
std_msgs/msg/Float64MultiArray "{data: [0.0, 0.0]}"
3. Check the Robot State
To view the current end-effector pose, use:
ros2 topic echo /agilex_piper_cartesian_motion_controller/current_pose
3.Afterword
This project is built upon and integrated from several open-source repositories. The main credit goes to the original authors and the open-source community.
We would like to sincerely thank the open-source community for making these technologies accessible through shared code and practical experience.
MuJoCo + ROS2 Robotic Manipulation FAQ
1. Why use MuJoCo for the Piper robotic arm instead of Gazebo or Isaac Sim?
MuJoCo provides a lightweight and high-performance physics simulation workflow, making it ideal for rapid robotics prototyping, control validation, and future reinforcement learning research. Compared with heavier simulators, it can run efficiently on more accessible hardware.
2. Can this simulation workflow be transferred to a real Piper robotic arm?
Yes. The ROS2 control architecture is designed to align simulation and real hardware interfaces, making future sim-to-real deployment more practical.
3. Why build a custom MuJoCo + ROS2 workflow instead of using existing robotics simulators?
This project focuses on providing a simpler and more flexible robotics development workflow with lower hardware requirements and easier customization for developers and researchers.
4. Is this MuJoCo robotic arm project suitable for reinforcement learning (RL)?
Yes. The simulation framework can serve as a foundation for reinforcement learning workflows such as PPO training, imitation learning, grasping policy development, and sim-to-real robotic manipulation research.
5. How does ROS2 Control work with MuJoCo simulation?
The project integrates ROS2 Control plugins into the MuJoCo simulation environment, allowing developers to send ROS2 motion commands directly to the simulated robotic arm and receive real-time robot state feedback.
Still Have Question?
If you encounter any issues with environment installation, parameter configuration, or RL training, feel free to leave your questions for further discussion.
