Autonomous Rubik's Cube Solver with ROS 2 & Raspberry Pi: Project RS1
Hi everyone!
I wanted to share a personal project I’ve been working on for the past few months: an autonomous robot that solves a Rubik’s Cube, built entirely around the ROS 2 ecosystem. I call it RS1.
The Project & Architecture
The goal was to create a compact, standalone solver running on a Raspberry Pi. I used ROS 2 to orchestrate the entire system, managing the communication between:
  • Computer Vision Node: To scan and map the cube state.
  • Algorithm Node: To compute the solution.
  • Hardware Interface: To control the motors and execute the moves.
It has been a challenging journey—especially coordinating the hardware constraints with real-time processing—but I was incredibly proud to see the project recently reposted by the official Open Robotics page on LinkedIn!
Request for Feedback
While the system is functional, I know there is room for improvement in the code structure and ROS 2 design patterns. I am posting here because I’d love to get feedback from experienced ROS developers on the architecture or suggestions for optimization.
Links & Code
Thanks for checking it out!
I was really impressed with the simplicity and elegance of this project! Reducing such a complex task to three operations that can be completed by hobby servos / steppers is really impressive.
Looking forward to seeing the rest of the code. If you are interested in open sourcing the hardware please reach out.
Are the STL files available for your buils?
