Advice on ROS 2, GLIM and nvblox for Autonomous Drones
Hi everyone!
I’m developing an autonomous quadcopter(small category drone) using PX4, ROS 2 Humble, and a Jetson Orin NX 16 GB, with a Livox Mid-360 LiDAR. I’m planning to use GLIM for odometry, nvblox for 3D mapping, and a custom planner for obstacle avoidance, with PX4 SITL and Gazebo Harmonic for simulation.
Could you please share your insights on whether this setup is suitable for real-time autonomous navigation and suggest any better alternatives or potential integration challenges?
Thanks for your time and guidance!
I’ve tinkered a lot with GLIM, with decent voxel size settings you should be able to get it up and running. I found GLIM had too many knobs to tune and yep the larger your map gets you can expect updates to take a longer time. so I’d suggest you do a similar scale run, check over a rosbag the compute given your Orin configuration is modest.
