Webots Demo 7: Testing a Supervisory Gate Pattern on TIAGo (QERRA-v2 Classical)
Hi everyone,
Following up on my previous posts on deterministic safety reflexes (Demo 6) and Layer 3 ranking rules, I wanted to share the latest simulation milestone from QERRA-v2 Classical: Webots Demo 7 (Supervisory Gate & Authority Separation).
The Motivation
In ROS 2 mobile bases, we typically route planner commands through twist_mux or nav2_collision_monitor, with watchdog timeouts on cmd_vel.
In Demo 7, I wanted to explore a stricter, isolated architectural pattern inspired by classical Simplex and doer-checker designs:
  • The high-level planner is treated as an untrusted proposer running as a separate OS process over non-blocking UDP.
  • The Supervisory Gate (the Webots controller) is the sole owner of the wheel motor joint handles. The default command is always zero velocity.
  • When a hazard occurs or deliberation fails, the gate clamps the motors, latches, and enforces a formal recovery contract before allowing any motion to resume.
The Scenario: Hospital Corridor Transit
I set up an illustrative healthcare logistics corridor in Webots (R2025a) with a PAL Robotics TIAGo base:
  • TIAGo cruises down the corridor at a proposed speed of 2.0 rad/s (~0.196 m/s).
  • An obstacle (a platform cart) sits in the active swept path at X = 2.8m.
  • The gate continuously evaluates forward Hokuyo lidar ranges (240° FOV, 667 samples) filtered across a 0.64m corridor matching the base width plus margin.
What the Gate Implements:
  1. Process-Level Isolation:
    The proposer runs in an external Python process communicating via non-blocking localhost UDP. It holds zero Webots actuator handles and has no direct path to the motors.
  2. Kinematic Stopping Envelope:
    The gate computes an envelope each tick:
    d_stop = ceil(v² / (2 * a_design)) + margin
    At 2.0 rad/s with a_design = 0.5 m/s² and a 300 mm margin, d_stop is 339 mm. If clearance falls below this, the gate overrides the proposer and commands 0.0 rad/s within a single 32 ms simulation tick.
  3. Recovery Contract & Latch:
    After a trip, the gate latches in TRIPPED. It requires a continuous 1.0s dwell of clear readings before an operator reset can be accepted. If an operator attempts a reset while the obstacle is still in front of the robot, the reset is rejected and logged (RESET_REJECTED_HAZARD), holding 0.0 rad/s.
  4. Tamper-Evident Flight Recorder:
    Every single tick appends a canonical JSON line to gate_audit.jsonl, chained with a SHA-256 hash of the preceding record for offline verification.
What the Run Shows (RUN_1791713619, n=1):
  • Startup Latch: The gate boots in TRIPPED, runs the 1.0s clear dwell, and enters AWAITING_RESET.
  • Edge-Triggered Reset: An operator reset (Key R) is accepted at t = 4.38s, transitioning to RUN at 2.0 rad/s.
  • Gate Intervention: At t = 31.52s, corridor clearance breaches the 339 mm threshold. The gate cuts velocity to 0.0 rad/s in that exact 32 ms tick.
    • Trip reading: 337 mm
    • Standstill reading: 301 mm (the robot coasted about 36 mm in simulation physics before reaching complete rest).
    • Collision: None observed; the cart was not displaced.
  • Recovery Guard: While parked in front of the cart at t = 34s, an operator reset was attempted. The gate evaluated the active hazard and rejected the reset (RESET_REJECTED_HAZARD: 1), keeping motors locked.
  • Cryptographic Seal: 1,485 discrete control cycles verified with zero discrepancies (verify_log.py, Head seal: ae37ae62227c4fdca51233b7e4189607898ae2c27eca5bf0847414d1f0d4c191).
Observations, Gaps & Non-Claims:
  • Unexplained Startup Slip: From t = 5.76s to 14.40s, wheel encoders recorded 2.0 rad/s while lidar distance stayed flat (~3818 mm). The wheels were turning in simulation, but the base did not translate for about 9 seconds before steady translation began. The exact physics cause in Webots is unconfirmed; logging ground-truth poses is my next diagnostic step.
  • Smoke-Test Mode: In this baseline run, the obstacle cart was placed via supervisor script at t = 3.5s. Full dynamic obstacle injection via an independent supervisor robot is scheduled next.
  • Placeholder Parameters: a_design (0.5 m/s²) and the 300 mm margin are uncalibrated placeholders. At 0.196 m/s, the braking term is only about 39 mm, so the 300 mm margin dominates. Empirical deceleration calibration against ground truth is needed.
  • Scope Boundary: This is an open-source research prototype on a non-RTOS host (Windows 11). It does not claim SIL/PL certification under IEC 61508 or ISO 13849-1, and software process isolation does not replace a physical emergency stop relay.
Video & Links
Video (YouTube):
Repository: GitHub - marunigno-ship-it/QERRA-v2-classical: Three-layer deterministic safety & ethical execution guard for autonomous robots (ROS 2 & Behavior Trees). Sub-ms physical reflex (QERRA-HSR) + moral filter (SEMEV-12) + values ranker (THRIVE). Fully auditable. · GitHub
Licensing:
  • Layer 1 (QERRA-HSR physical reflex): Permissive Apache-2.0 (standard library only, designed for standalone reuse).
  • Core Framework: Dual-licensed under AGPL-3.0 / commercial licensing (COMMERCIAL-LICENSE.md).
I would welcome any genuine feedback! :blush:
  1. Is this supervisory pattern useful beyond what nav2_collision_monitor + cmd_vel timeouts already provide?
  2. Does the latch-plus-dwell-plus-operator-reset recovery contract match how you handle physical holds in shared spaces?
Transparency note: Post drafted with AI engineering assistance in line with QERRA open development disclosure. All architecture, code, and simulation runs were executed locally
Following up on the Demo 7 baseline posted above, I have completed a code-hardening pass on main (v2.1.0) to address architectural coupling and packaging gaps.
Here is what was refactored and verified:
1. Pure Standard-Library Gate Core (gate/gate_core.py)
In the original Demo 7 baseline, gate_core.py routed hazard checks through hsr.qerra_hsr.evaluate_hsr using hardcoded dummy inputs (distress=0.0, persons=2). This introduced an artificial cross-layer dependency and root logging side-effects into what was supposed to be a pure function.
  • Decoupling: Stripped the hsr import entirely. Obstacle hazard classification is now evaluated directly in gate_core.py as hazard = (min_range <= d_stop).
  • Zero External Dependencies: gate_core.py uses strictly the Python standard library (no ROS, no numpy, no external packages).
  • AST Enforcement: Added an automated unit test (test_gate_core_imports_stdlib_only in tests/test_gate_core.py) that parses the module using Python’s ast package and fails in CI if any non-standard-library module is referenced.
2. Packaging and Controller Portability
  • Package Registration: Updated setup.py and package.xml (v2.1.0). In earlier commits, gate was omitted from packages and verify_log from py_modules. Both are now registered members of the qerra_core package.
  • Portable Project Root Discovery: Removed hardcoded local developer path fallbacks in controllers/tiago_supervisory_gate/tiago_supervisory_gate.py. The controller now resolves the repository root dynamically by walking upward looking for gate/.
3. Automated CI Pipeline (110 Tests Passing)
Upgraded GitHub Actions CI (.github/workflows/tests.yml) on ubuntu-latest with a CPU-only PyTorch index to run all test suites across the repository:
  • 75 Supervisory Gate tests (tests/test_gate_*.py: core state machine, non-blocking IPC buffers, corridor filtering, UDP link, and flight recorder mutation tampering).
  • 20 QERRA-HSR tests (hsr/: 3-vector reflex logic, clock-injected hysteresis, and Property HSR-5 recovery contracts).
  • 15 SEMEV-12 benchmark cases (tests/test_cases.py: multi-anchor sentence embeddings, negation guards, and safety-override patterns).
4. Technical Disclosures & Known Boundaries
In line with open documentation, the following empirical boundaries remain documented in CURRENT_ARCHITECTURE.md and SAFETY_CONCEPT.md v0.3:
  • Evidence baseline: The physical stopping evidence (
    d_stop = 339 mm
    , trip at 337 mm, standstill at 301 mm, 36 mm coasting) rests on the single simulation run RUN_1791713619 on a non-RTOS host (Windows 11).
  • Commanded vs. Measured velocity:
    d_stop
    currently computes braking bounds from the proposer’s commanded speed, not measured wheel encoder odometry.
  • Sensor boundary: Lidar scans returning all +inf are parsed as clear open space. Sensor blinding or disconnection emitting infinity is not isolated from a clear corridor.
  • Log schema detail: While gate_core.step() returns obstacle_breach, gate_log.py does not yet persist it to the JSONL lines (which record hsr_status: null in v0.3).
REPOSITORY : GitHub - marunigno-ship-it/QERRA-v2-classical: Three-layer deterministic safety & ethical execution guard for autonomous robots (ROS 2 & Behavior Trees). Sub-ms physical reflex (QERRA-HSR) + moral filter (SEMEV-12) + values ranker (THRIVE). Fully auditable. · GitHub
Feedback and technical critique on the stopping envelope math or the recovery state machine are welcome. :blush:
Transparency note: Post drafted with AI engineering assistance. All architecture, code, and simulation runs were executed locally.
