Stop SSH-ing into robots to find the right rosbag. We built a visual Rolling Buffer for ROS2
Hi everyone,
I’m back with an update on INSAION, the observability platform my co-founder and I are building. Last time, we discussed general fleet monitoring, but today I want to share a specific feature we just released that targets a massive pain point we faced as roboticists: Managing local recordings without filling up the disk.
We’ve all been there: A robot fails in production, you SSH in, navigate to the log directory, and start playing “guess the timestamp” to find the right bag file. It’s tedious, and usually, you either missed the data or the disk is already full.
So, we built a smart Rolling Buffer to solve this.
How it actually works (It’s more than just a loop):
It’s not just a simple circular buffer. We built a storage management system directly into the agent. You allocate a specific amount of storage (e.g., 10GB) and select a policy via the Web UI (no config files!):
  • FIFO: Oldest data gets evicted automatically when the limit is reached.
  • HARD: Recording stops when the limit is reached to preserve exact history.
  • NONE: Standard recording until disk saturation.
The “No-SSH” Workflow:
As you can see in the video attached, we visualized the timeline.
  1. The Timeline: You see exactly where the Incidents (red blocks) happened relative to the Recordings (yellow/green blocks).
  2. Visual correlation: No need to grep logs or match timestamps manually. You can see at a glance if you have data covering the crash.
  3. Selective Sync: You don’t need to upload terabytes of data. You just select the relevant block from the timeline and click “Sync.” The heavy sensor data (Lidar, Images, Costmaps) is then uploaded to the cloud for analysis.
Closing the Loop:
Our goal is to give you the full picture. We start with lightweight telemetry for live monitoring, which triggers alerts. Then, we close the loop by letting you easily grab the high-fidelity, heavy data stored locally—only when you actually need it.
We’re trying to build the tool we wish we had in our previous robotics jobs. I’d love to hear your thoughts on this “smart recording” approach—does this sound like something that would save you time debugging?
I’d love to hear your feedback on it
Check it out at app.insaion.com if you want to dig deeper. It’s free to get started
Cheers!
