SO-ARM-Moce: An Improved Open-Source Educational Robotic Arm (Higher Payload, Larger Workspace, ROS-Compatible) – Seeking Community Feedback
Hi everyone,
We are preparing to open-source an improved version of the SO-ARM101 robotic arm, called SO-ARM-Moce, and would greatly appreciate feedback from the robotics community before the official release in March.
GitHub:
https://github.com/wanhaoniu/SO-ARM-Moce
What is SO-ARM-Moce?
SO-ARM-Moce is a cost-effective robotic arm (~$400–450 target range) designed for education, research prototyping, and maker development.
Compared to SO-ARM101:
  • Increased payload (up to ~1.5 kg)
  • Enlarged reachable workspace
  • Two key servo joints upgraded to geared reducer modules
  • Maintains ~1 mm repeatability
  • Python + ROS control support
  • Compatible with SO-ARM101 ecosystem, with additional Moce extensions
Why we are posting here
Before open-sourcing hardware files and full documentation, we want feedback on:
  1. ROS integration expectations – What interfaces would you expect (ros_control, MoveIt configs, URDF/Xacro structure)?
  2. Developer tooling – CLI, GUI, calibration tools?
  3. Research usage – What would make this arm more suitable for benchmarking or academic work?
We are particularly interested in suggestions on:
  • Standard ROS package structure
  • Simulation support (Gazebo / Isaac / MuJoCo)
  • Best practices for releasing hardware + firmware + control stack together
Looking forward to your thoughts and technical suggestions.
What’s with that weird fist? Is it going to punch you in the face when you make a mistake? Maybe it should be called SO-ARM-Pavlov :smile:
Haha :grinning_face_with_smiling_eyes: it actually highlights the comparison with SOARM101, which had relatively low torque and payload.
The new front module is designed to significantly improve strength and load capacity — it punches weight limits, not people!
Hi Wanhao,
I want to reproduce MomoAgent this summer.
Is there a preliminary BOM available, especially for bearings, screws, shafts and servo models?
