Hi everyone!
Like many of us, I appreciate the power and flexibility of ROS 2, but I’ve always found the amount of manual boilerplate to be a bottleneck for rapid development. Keeping track of all the configuration details making sure CMakeLists.txt and package.xml are perfectly synced, or manually wiring launch files and topic connections takes a significant amount of time. I wanted to find a way to automate this infrastructure setup so I could focus purely on writing the actual robotics logic.
To solve this, I started building ROS 2 Blueprint Studio a visual node-based editor (inspired by Unreal Engine Blueprints) designed to take the routine off your shoulders.
Under the Hood (Architecture) I tried to avoid any “black magic” and stick entirely to standard ROS 2 practices:
1. Code Generation & Build System The studio doesn’t compile the code itself; it acts as a smart templating engine. Creating a standard node generates a base C++ template. If you duplicate a node (from the palette or canvas), it creates an independent file with a new name and copied code. Modifying the copy doesn’t break the parent. For the actual build, it relies on standard colcon build under the hood.
2. File Watcher & Dependency Tree To build the dependency tree, I wrote a custom FileWatcher. Before building, it scans the files to check for includes and node communication. For performance, it only parses files that have been modified. (I realize this might theoretically cause “phantom connections” on massive graphs, so I plan to add a forced full-rebuild mode in the future).
3. Topic Routing (Two Approaches) Node linking currently works in two modes:
Hardcoded (Bottom-Up): If publisher and subscriber topic names are explicitly hardcoded in your C++ or Python files, the UI detects this and automatically draws a visual “locked” wire between them.
Visual (Top-Down): You can define the topic name only on the publisher, drag a visual wire to a subscriber, and the FileWatcher will find a special placeholder in the subscriber’s code and automatically replace it with the publisher’s topic name. (Full disclosure: the visual routing is still a bit unstable and not recommended for huge projects yet, but I’m refining it).
4. Runtime Environment (Docker) I chose Docker (osrf/ros:humble-desktop) as the execution environment. Why?
Setting up ROS 2 natively on Windows is a special kind of pain.
It provides painless deployment and saves you from dependency hell when migrating to future ROS versions.
You can send your project folder to someone who doesn’t even have ROS installed, and their system will build and run your entire architecture in just a few clicks.
The Ask: Roast My Architecture The project is currently in early alpha. Honestly, my biggest doubts right now are around the core architecture and the automated build system (package and launch file generation).
I would be incredibly grateful if experienced ROS architects could take a look at the repo, point out my blind spots, and give me some harsh architectural critique. I’d much rather rebuild the foundation now than drag architectural flaws into a full release.
Source code here: GitHub - NeiroEvgen/ros2-blueprint-studio · GitHub
Any feedback is highly appreciated!
