ROS RTABMAP error 2 make -j4
Hello
I am trying to get my kinect working with rtabmap to show the mapping in real time but when I’m trying to install rtabmap according to the instructions given here , I am getting bunch of error while running make -j4
here is the list of error
d4sys@d4sys:~/rtabmap/build$ make
[  4%] Built target rtabmap_utilite
[  4%] Built target res_tool
[  4%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OptimizerG2O.cpp.o
In file included from /opt/ros/indigo/include/g2o/types/sba/types_sba.h:30:0,
                 from /home/d4sys/rtabmap/corelib/src/OptimizerG2O.cpp:55:
/opt/ros/indigo/include/g2o/core/base_vertex.h:62:67: warning: ‘Eigen::AlignedBit’ is deprecated (declared at /usr/local/include/eigen3/Eigen/src/Core/util/Constants.h:162) [-Wdeprecated-declarations]
     typedef Map<Matrix<double, D, D>, Matrix<double,D,D>::Flags & AlignedBit ? Aligned : Unaligned >  HessianBlockType;
In file included from /opt/ros/indigo/include/g2o/types/sba/types_sba.h:31:0,
/opt/ros/indigo/include/g2o/core/base_binary_edge.h:59:75: warning: ‘Eigen::AlignedBit’ is deprecated (declared at /usr/local/include/eigen3/Eigen/src/Core/util/Constants.h:162) [-Wdeprecated-declarations]
       typedef Map<Matrix<double, Di, Dj>, Matrix<double, Di, Dj>::Flags & AlignedBit ? Aligned : Unaligned > HessianBlockType;
/opt/ros/indigo/include/g2o/core/base_binary_edge.h:60:75: warning: ‘Eigen::AlignedBit’ is deprecated (declared at /usr/local/include/eigen3/Eigen/src/Core/util/Constants.h:162) [-Wdeprecated-declarations]
       typedef Map<Matrix<double, Dj, Di>, Matrix<double, Dj, Di>::Flags & AlignedBit ? Aligned : Unaligned > HessianBlockTransposedType;
In file included from /opt/ros/indigo/include/g2o/types/sba/types_sba.h:32:0,
/opt/ros/indigo/include/g2o/core/base_multi_edge.h:69:47: warning: ‘Eigen::AlignedBit’ is deprecated (declared at /usr/local/include/eigen3/Eigen/src/Core/util/Constants.h:162) [-Wdeprecated-declarations]
       typedef Map<MatrixXd, MatrixXd::Flags & AlignedBit ? Aligned : Unaligned > HessianBlockType;
In file included from /usr/local/include/eigen3/Eigen/Core:366:0,
                 from /home/d4sys/rtabmap/corelib/src/../include/rtabmap/core/Transform.h:34,
                 from /home/d4sys/rtabmap/corelib/src/../include/rtabmap/core/Link.h:33,
                 from /home/d4sys/rtabmap/corelib/src/../include/rtabmap/core/Optimizer.h:35,
                 from /home/d4sys/rtabmap/corelib/src/../include/rtabmap/core/OptimizerG2O.h:33,
                 from /home/d4sys/rtabmap/corelib/src/OptimizerG2O.cpp:36:
/usr/local/include/eigen3/Eigen/src/Core/AssignEvaluator.h: In instantiation of ‘void Eigen::internal::call_assignment_no_alias(Dst&, const Src&, const Func&) [with Dst = Eigen::Matrix<int, -1, 1>; Src = Eigen::Matrix<long int, -1, 1, 0, -1, 1>; Func = Eigen::internal::assign_op<int, long int>]’:
/usr/local/include/eigen3/Eigen/src/Core/AssignEvaluator.h:804:42:   required from ‘void Eigen::internal::call_assignment(Dst&, const Src&, const Func&, typename Eigen::internal::enable_if<(! Eigen::internal::evaluator_assume_aliasing<Src>::value), void*>::type) [with Dst = Eigen::Matrix<int, -1, 1>; Src = Eigen::Matrix<long int, -1, 1, 0, -1, 1>; Func = Eigen::internal::assign_op<int, long int>; typename Eigen::internal::enable_if<(! Eigen::internal::evaluator_assume_aliasing<Src>::value), void*>::type = void*]’
/usr/local/include/eigen3/Eigen/src/Core/AssignEvaluator.h:782:93:   required from ‘void Eigen::internal::call_assignment(Dst&, const Src&) [with Dst = Eigen::Matrix<int, -1, 1>; Src = Eigen::Matrix<long int, -1, 1, 0, -1, 1>]’
/usr/local/include/eigen3/Eigen/src/Core/PlainObjectBase.h:714:65:   required from ‘Derived& Eigen::PlainObjectBase<Derived>::_set(const Eigen::DenseBase<OtherDerived>&) [with OtherDerived = Eigen::Matrix<long int, -1, 1, 0, -1, 1>; Derived = Eigen::Matrix<int, -1, 1>]’
/usr/local/include/eigen3/Eigen/src/Core/Matrix.h:225:30:   required from ‘Eigen::Matrix<_Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols>& Eigen::Matrix<_Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols>::operator=(const Eigen::DenseBase<OtherDerived>&) [with OtherDerived = Eigen::Matrix<long int, -1, 1, 0, -1, 1>; _Scalar = int; int _Rows = -1; int _Cols = 1; int _Options = 0; int _MaxRows = -1; int _MaxCols = 1]’
/usr/local/include/eigen3/Eigen/src/Core/PermutationMatrix.h:365:17:   required from ‘Eigen::PermutationMatrix<SizeAtCompileTime, MaxSizeAtCompileTime, IndexType>& Eigen::PermutationMatrix<SizeAtCompileTime, MaxSizeAtCompileTime, IndexType>::operator=(const Eigen::PermutationBase<OtherDerived>&) [with Other = Eigen::PermutationMatrix<-1, -1, long int>; int SizeAtCompileTime = -1; int MaxSizeAtCompileTime = -1; _StorageIndex = int]’
/opt/ros/indigo/include/g2o/solvers/eigen/linear_solver_eigen.h:66:18:   required from ‘void g2o::LinearSolverEigen<MatrixType>::CholeskyDecomposition::analyzePatternWithPermutation(g2o::LinearSolverEigen<MatrixType>::SparseMatrix&, const PermutationMatrix&) [with MatrixType = Eigen::Matrix<double, 6, 6>; g2o::LinearSolverEigen<MatrixType>::SparseMatrix = Eigen::SparseMatrix<double, 0>; g2o::LinearSolverEigen<MatrixType>::PermutationMatrix = Eigen::PermutationMatrix<-1, -1, long int>]’
/opt/ros/indigo/include/g2o/solvers/eigen/linear_solver_eigen.h:193:9:   required from ‘void g2o::LinearSolverEigen<MatrixType>::computeSymbolicDecomposition(const g2o::SparseBlockMatrix<MatrixType>&) [with MatrixType = Eigen::Matrix<double, 6, 6>]’
/opt/ros/indigo/include/g2o/solvers/eigen/linear_solver_eigen.h:98:39:   required from ‘bool g2o::LinearSolverEigen<MatrixType>::solve(const g2o::SparseBlockMatrix<MatrixType>&, double*, double*) [with MatrixType = Eigen::Matrix<double, 6, 6>]’
/home/d4sys/rtabmap/corelib/src/OptimizerG2O.cpp:1456:1:   required from here
/usr/local/include/eigen3/Eigen/src/Core/util/StaticAssert.h:33:40: error: static assertion failed: YOU_MIXED_DIFFERENT_NUMERIC_TYPES__YOU_NEED_TO_USE_THE_CAST_METHOD_OF_MATRIXBASE_TO_CAST_NUMERIC_TYPES_EXPLICITLY
     #define EIGEN_STATIC_ASSERT(X,MSG) static_assert(X,#MSG);
/usr/local/include/eigen3/Eigen/src/Core/util/XprHelper.h:816:3: note: in expansion of macro ‘EIGEN_STATIC_ASSERT’
   EIGEN_STATIC_ASSERT((Eigen::internal::has_ReturnType<ScalarBinaryOpTraits<LHS, RHS,BINOP> >::value), \
/usr/local/include/eigen3/Eigen/src/Core/AssignEvaluator.h:834:3: note: in expansion of macro ‘EIGEN_CHECK_BINARY_COMPATIBILIY’
   EIGEN_CHECK_BINARY_COMPATIBILIY(Func,typename ActualDstTypeCleaned::Scalar,typename Src::Scalar);
^Cmake[2]: *** [corelib/src/CMakeFiles/rtabmap_core.dir/OptimizerG2O.cpp.o] Interrupt
make[1]: *** [corelib/src/CMakeFiles/rtabmap_core.dir/all] Interrupt
make: *** [all] Interrupt
d4sys@d4sys:~/rtabmap/build$ make -j4
[  5%] Built target imagesJoiner
[  5%] Built target extractObject
[  5%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OptimizerG2O.cpp.o
[  6%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryMono.cpp.o
[  6%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryF2F.cpp.o
[  6%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryFovis.cpp.o
[  7%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryViso2.cpp.o
[  7%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryDVO.cpp.o
[  8%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryOkvis.cpp.o
[  8%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryORBSLAM2.cpp.o
[  8%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryLOAM.cpp.o
[  9%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OdometryMSCKF.cpp.o
/usr/local/include/eigen3/Eigen/src/Core/AssignEvaluator.h:804:42:   required from ‘void Ei        gen::internal::call_assignment(Dst&, const Src&, const Func&, typename Eigen::internal::enable_if<(! Eigen::internal::evaluator_assume_aliasing<Src>::value), void*>::type) [with Dst = Eigen::Matrix<int, -1, 1>; Src = Eigen::Matrix<long int, -1, 1, 0, -1, 1>; Func = Eigen::internal::assign_op<int, long int>; typename Eigen::internal::enable_if<(! Eigen::internal::evaluator_assume_aliasing<Src>::value), void*>::type = void*]’
/usr/local/include/eige    n3/Eigen/src/Core/util/StaticAssert.h:33:40: error: static assertion failed: YOU_MIXED_DIFFERENT_NUMERIC_TYPES__YOU_NEED_TO_USE_THE_CAST_METHOD_OF_MATRIXBASE_TO_CAST_NUMERIC_TYPES_EXPLICITLY
[  9%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/IMUThread.cpp.o
[ 10%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/Stereo.cpp.o
[ 10%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/StereoDense.cpp.o
[ 10%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/StereoCameraModel.cpp.o
[ 11%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/OccupancyGrid.cpp.o
[ 11%] Building CXX object corelib/src/CMakeFiles/rtabmap_core.dir/GainCompensator.cpp.o
make[2]: *** [corelib/src/CMakeFiles/rtabmap_core.dir/OptimizerG2O.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [corelib/src/CMakeFiles/rtabmap_core.dir/all] Error 2
make: *** [all] Error 2
Kindly help me with this problem
Thanks
Thanks for your question. However we ask that you please ask questions on http://answers.ros.org following our support guidelines: Support - ROS Wiki
ROS Discourse is for news and general interest discussions. ROS Answers provides a forum which can be filtered by tags to make sure the relevant people can find and/or answer the question, and not overload everyone with hundreds of posts.
If you’d like you can reply with a link to your answers.ros.org question, but in the future please start there.
