ROS 2 Inspector — Static Architecture Analysis and Visualization for ROS 2 Workspaces
Hi everyone,
I’ve been working on an open-source project called ROS 2 Inspector, aimed at making it easier to understand the architecture of an unfamiliar or large ROS 2 workspace before running it.
The idea came from a problem I’ve repeatedly found interesting in ROS 2 projects:
When documentation is incomplete or outdated, understanding a workspace often means combining source-code inspection, launch-file analysis, grep/search, runtime tools such as rqt_graph, and a lot of manual exploration.
ROS 2 Inspector tries to automate part of that first architectural pass.
For example:
ros2inspector scan .
This scans the workspace from source and produces a compact summary of the discovered ROS 2 packages together with health signals that can help identify areas worth reviewing more closely.
The output can be exported as:
  • table
  • JSON
  • YAML
For a more visual exploration:
ros2inspector viz
This generates a self-contained interactive visualization of the discovered ROS 2 architecture, allowing you to explore nodes, topics, services, actions, and their relationships.
There are also commands for inspecting nodes and connections, generating dependency and communication graphs, auditing connectivity, and validating architectural policies.
Some examples:
ros2inspector nodes --show-connections
ros2inspector graph comms --format mermaid
ros2inspector audit
ros2inspector validate --policy ros2inspector_policy.yaml
The analyzer currently handles supported patterns in Python, C++, ROS interfaces, and launch files.
One important point: ROS 2 Inspector is based on static analysis.
It is not intended to replace runtime tools.
Dynamic names, plugins, conditional behavior, runtime remappings, DDS/network behavior, and other aspects of the effective ROS 2 topology can only be fully understood with runtime evidence.
I see the two approaches as complementary:
Static analysis:
What architecture can we infer from the workspace before launching it?
Runtime inspection:
What architecture actually exists when the system is running?
The project is still in its early releases, so there is a lot of room for improvement, optimization, and broader ROS 2 pattern support.
That is also why I’d really like feedback from people working with real ROS 2 systems.
In particular:
What information would you want to see when opening an unfamiliar ROS 2 workspace for the first time?
And for the visualization:
What would make an architecture graph genuinely useful on a large ROS 2 system rather than just becoming another unreadable graph?
If you have a non-confidential ROS 2 workspace, I’d also be very interested in cases where the analyzer misses something, interprets something incorrectly, or where you think runtime/static information should be connected differently.
GitHub:
Website / documentation:
LinkedIn post:
Thanks, and I’d be very interested to hear how others approach this problem.
I would highly recommend getting connected with the ROSGraph working group (@emersonknapp is the chair) where they are thinking about ways to add determinism to how ROS graphs are declared, launched, executed, and validated.
I would like to caution you:
that C++ parser is likely to fall apart upon first contact with any reasonably complex codebase (the only real C++ parser is a compiler, and even then that’s not always the case)
and parsing templates, well, good luck.
what if the topic name is created by joining strings together? or what about topic remapping? or node name remapping? or inheritting from an external type that inherits from rclcpp::Node?
and that’s without even getting into any complex C++ language features.
what does this code do when it encounters something like
template<type T>
class MyNode : public rclcpp::Node {
public:
    MyNode() : Node("my_node") {
        publisher = this->create_publisher<T>("my_topic", 10);
    rclcpp::Publisher<T>::SharedPtr publisher;
int main() {
    auto my_node = MyNode<std_msgs::msg::String>();
I could come up with a dozen more ways that any reasonably large ros codebase would cause this to explode
static analysis will literally never catch all of these things, you just have to read the code & run it
and also, for f in root.rglob("*"): is quite funny. I have a ros project which pulls in a bunch of external repositories using cmake’s FetchContent. one of those repositories is maplibre. the repository is like 7 gigabytes. you do not want to just recursively glob everything.
Thanks for the detailed feedback — these are fair points, and exactly the kind of edge cases we want to start testing against.
This is currently v0.1.0, an alpha/first release, so ROS 2 Inspector is not intended to claim complete semantic understanding of arbitrary C++ codebases yet.
A small clarification: the C++ side is not based on regex parsing. It currently uses tree-sitter-cpp to build a syntax tree, then extracts ROS 2 constructs such as publishers, subscriptions, services, clients, actions, and directly inherited rclcpp::Node classes.
That said, I agree with the larger point: parsing C++ syntax and understanding C++ semantics are very different problems.
Things like indirect inheritance, templates whose concrete types are only known at instantiation, aliases, macros, generated names, helper/wrapper APIs, component composition, etc. can absolutely defeat a source-only heuristic approach.
For example, with:
template<typename T>
public:
Tree-sitter can parse the structure, but the current analyzer does not yet trace MyNode<std_msgs::msg::String> back to the template parameter and resolve T semantically. That is one of the cases we want to improve.
Topic remapping is already partially supported through ROS 2 launch files, including namespaces and literal remapping rules, but this is also not complete. Dynamic launch substitutions, command-line ROS arguments, node-name remapping, more complex deployment configurations, etc. need more work.
The recursive traversal point is also valid. Workspace discovery already excludes normal build, install, log, .git, virtual environments, etc., but some package-level analysis still recursively walks package contents. Vendored or generated source trees can therefore become expensive, so improving traversal/pruning is high on the optimization list.
The long-term direction is not to pretend static analysis can recover every possible runtime configuration. Instead, I want the tool to distinguish clearly between:
  • things known statically with high confidence,
  • things inferred heuristically,
  • unresolved/dynamic constructs,
  • and eventually runtime-observed information.
For the next releases I’m looking at better C++ semantic resolution, stronger handling of dynamic constructs, configurable scan exclusions, more adversarial/real-world test workspaces, and potentially an optional Clang/compile-database backend for deeper C++ analysis.
So yes — there are definitely cases today where v0.1.0 will miss information. That’s expected for the alpha release, and feedback/examples like these are useful because they help define exactly where the next iterations should improve.
If you have a public ROS 2 workspace that you think is particularly good at breaking this kind of analysis, I’d genuinely be interested in adding it, or a reduced version of it, to the test set.
I never claimed it was. it will still fall apart upon first contact with anything reasonably complex. the only good C++ parser is a compiler. unless you are using clang, you are likely not parsing it correctly.
the best thing to do is to just run it and open up rqt
