ROS 2 Visualization Tools for Architecture
Hello everyone,
I was wondering what kind of visualizations tools do you use or are aware to see the architecture of a ROS 2 system?
For instance, if you would like to see the connections between nodes and topics (e.g., I know that rqt can show that), visualize messages flow, parameters, or even documentation.
Thank you!
Paulo
I’ve worked on a tool for visualizing the flow of messages* between nodes over time (and more):
(* and support for service requests/replies was just merged: ros2/ros2_tracing#145, eclipse-tracecompass-incubator/org.eclipse.tracecompass.incubator#127)
I guess you need tools like rqt_graph?
ros2/ros_network_viz (github.com)
Introducing ros2_graph - General - ROS Discourse
ROS diagram tools - ROS Projects - ROS Discourse
New visualization for ROS 2 systems: Call for datasets - General - ROS Discourse
iwatake2222/dear_ros_node_viewer: Dear RosNodeViewer: Visualize ROS2 Node Graph (github.com)
there are also many other TUI/CLI Tools rather than GUI that can help you inspect the runtime arch of ros2 system.
Late to this thread but I built something that directly addresses this.
ros2grapher statically analyzes your Python and C++ source files and
generates an interactive graph of nodes, topics and services without
needing a running system. It also uses AI to resolve dynamic topic names.
GitHub: GitHub - Supull/ros2grapher: Scan your ROS2 workspace and visualize node topology as an interactive graph. No running system needed. · GitHub
Interesting work. One gap I’ve seen is that most tools don’t catch semantic issues like Xacro residue, broken references, or invalid prefixes.
While testing models like NASA Robonaut 2 and KUKA iiwa, I noticed these issues still exist in real repos.
Built something to validate beyond syntax:
