Requesting feedback: new for-loop action for ROS 2 launch files to repeat entities
tl;dr I’m looking for feedback from ROS 2 users on this new for-loop action for launch (XML/YAML/Python), which can repeat entities N times based on the value of a launch argument, and provides an index that can be used for substitutions: Add ForEach action to repeat entities using iteration-specific values by christophebedard · Pull Request #802 · ros2/launch · GitHub. Please post comments about the implementation on the PR and general comments about the solution here.
Being able to repeat entities (e.g., nodes) N times based on the value of a launch argument is a pretty commonly-requested feature. Example: ros2/launch#499 and [poll] Interest in ros2 launch action to support for-loops (e.g. IncludeNLaunchDescriptions())?. Some current solutions/workarounds include:
  1. OpaqueFunction: Launch Loop Support? [Feature Request] · Issue #499 · ros2/launch · GitHub
  2. Recursion: GitHub - MetroRobots/rosetta_launch: A guide to understanding launch files in ROS 1 and ROS 2
While these work, they involve some boilerplate code that has to be repeated in each launch file, and they make launch files more complex.
I’m proposing a new ForLoop action (ros2/launch#802), which also supports substituting the index value, e.g., $(index i) in XML or YAML. Examples:
XML
<launch>
    <arg name="num_robots" default="2" />
    <for len="$(var num_robots)" name="i" >
        <node pkg="test_tracetools" exec="test_ping" namespace="/pingpong_$(index i)" output="screen" />
        <node pkg="test_tracetools" exec="test_pong" namespace="/pingpong_$(index i)" output="screen" />
    </for>
</launch>
YAML
launch:
    - arg:
        default: '2'
    - for:
        len: $(var num_robots)
        children:
            - node:
                pkg: test_tracetools
                exec: test_ping
                namespace: /pingpong_$(index i)
                output: screen
            - node:
                exec: test_pong
                output: screen
Python
import launch
import launch_ros
def for_i(i: int):
    return [
        launch_ros.actions.Node(
            package='test_tracetools',
            executable='test_ping',
            output='screen',
            namespace=['/pingpong_', str(i)],
            executable='test_pong',
            output='screen',
    return launch.LaunchDescription([
        launch.actions.DeclareLaunchArgument('num_robots', default_value='2'),
        launch.actions.ForLoop(launch.substitutions.LaunchConfiguration('num_robots'), function=for_i),
We discussed this a few months ago in a PMC meeting and I already got some feedback from some users, but I thought I’d post here to get more feedback from other ROS 2 launch users.
This is so great!
I’d be happy for Nav2 to be one of the first users of this once its merged into rolling here!
Great to hear that you would find this useful!
Note that the action only accepts a length value (N). The generated index values then go from 0 to N-1 (== range()). It looks like cloned_multi_tb3_simulation_launch.py does something a bit more complex: it expects a list of dicts as a launch arg string (parsed by ParseMultiRobotPose) and then iterates through the list. Unless I’m missing something, you could probably somehow leverage the ForLoop action for this, but it may not reduce the launch file code that much.
I’m wondering if there’s another loop mechanism that could be more useful in practice, e.g., iterate over something more complex than just [0, N-1].
Got it! I think most naturally it would be a for-each loop, so perhaps that’s not quite what we have now in Nav2 :confused:
Thanks for the feedback. I think that makes a lot of sense; I generalized it into a ForEach action to make it more flexible and much more powerful. It can now iterate over sets of parameters. It’s basically a string list of YAML structures/dictionaries, similar to what Nav2’s ParseMultiRobotPose does.
See the updated PR: Add ForEach action to repeat entities using iteration-specific values by christophebedard · Pull Request #802 · ros2/launch · GitHub.
Examples:
XML
<launch>
    <arg name="robots" default="{name: 'robotA', id: 1};{name: 'robotB', id: 2}" />
    <for_each values="$(var robots)" >
        <log message="'$(for-var name)' id=$(for-var id)" />
    </for_each>
</launch>
YAML
launch:
    - arg:
        default: "{name: 'robotA', id: 1};{name: 'robotB', id: 2}"
    - for_each:
        values: $(var robots)
        children:
            - log:
                message: "'$(for-var name)' id=$(for-var id)"
Python
import launch
def for_each(id: int, name: str):
    return [
        launch.actions.LogInfo(msg=f"'{name}' id={id}"),
            'robots', default_value="{name: 'robotA', id: 1};{name: 'robotB', id: 2}"),
        launch.actions.ForEach(launch.substitutions.LaunchConfiguration('robots'), function=for_each),
Default values are also supported, which I see is useful from looking at ParseMultiRobotPose. In Python, just set a default value for the corresponding callback function parameter. When using one of the frontends, provide an optional default value to the substitution: $(for-var name 'default').
