OpenClawPi: AgileX Robotics Skill Set Library
OpenClawPi is a modular skill set repository focused on the rapid integration and reuse of core robot functions. Covering key scenarios such as robotic arm control, grasping, visual perception, and voice interaction, it provides out-of-the-box skill components for secondary robot development and application deployment.
I. Quick Start
OpenClaw Deployment
Visit the OpenClaw official website: https://openclaw.ai/
Execute the one-click installation command:
curl -fsSL https://openclaw.ai/install.sh | bash
Next, configure OpenClaw:
Select ‘YES’
Select ‘QuickStart’
Select ‘Update values’
Select your provider (recommended: free options like Qwen, OpenRouter, or Ollama)
Select the company model you wish to use.
Select a default model.
Select the APP you will connect to OpenClaw.
Select a web search provider.
Select skills (not required for now).
Check all Hook options.
Select ‘restart’.
Select ‘Web UI’.
1. Clone the Project
git clone https://github.com/vanstrong12138/OpenClawPi.git
2. Prompt the Agent to Learn Skills
Using the vision skill as an example:
User: Please learn vl_vision_skill
Skill Modules Overview
| Module Name | Description | Core Dependencies |
agx-arm-codegen |
Robotic arm code generation tool; automatically generates trajectory planning and joint control code. Supports custom path templates. | pyAgxArm |
grab_skill |
Robot grasping skill, including gripper control, target pose calibration, and grasping strategies (single-point/adaptive). | pyAgxArm |
vl_vision_skill |
Visual perception skill, supporting object detection, visual positioning, and image segmentation. | SAM3, Qwen3-VL |
voice_skill |
Voice interaction skill, supporting voice command recognition, voice feedback, and custom command set configuration. | cosyvoice |
II. GrabGen - Pose Generation and Grasping
This article demonstrates the identification, segmentation, pose generation, and grasping of arbitrary objects using SAM3 and pose generation tools.
Repositories
- GraspGen: https://github.com/vanstrong12138/GraspGen
- Agilex-College: https://github.com/agilexrobotics/Agilex-College/tree/master
Hardware Requirements
- x86 Desktop Platform
- NVIDIA GPU with at least 16GB VRAM
- Intel RealSense Camera
Project Deployment Environment
- OS: Ubuntu 24.04
- Middleware: ROS Jazzy
- GPU: RTX 5090
- NVIDIA Driver: Version 570.195.03
- CUDA: Version 12.8
- Install NVIDIA Graphics Driver
sudo apt update
sudo apt upgrade
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
sudo apt install nvidia-driver-570
# Restart
reboot
- Install CUDA Toolkit 12.8
Go to the NVIDIA Official Website to download the CUDA runfile.
Execute the installation command:
wget https://developer.download.nvidia.com/compute/cuda/12.8.1/local_installers/cuda_12.8.1_570.124.06_linux.run
sudo sh cuda_12.8.1_570.124.06_linux.run
- During installation, uncheck the first option (“driver”) since the driver was installed in the previous step.
- Add Environment Variables
echo 'export PATH=/usr/local/cuda-12.8/bin:$PATH' >> ~/.bashrc
echo 'export LD_LIBRARY_PATH=/usr/local/cuda-12.8/lib64:$LD_LIBRARY_PATH' >> ~/.bashrc
source ~/.bashrc
- Verify Installation
Executenvcc -Vto check CUDA information.
nvcc -V
- Install cuDNN
Download the cuDNN tar file from the NVIDIA Official Website. After extracting, copy the files.
Execute the following commands to copy cuDNN to the CUDA directory:
sudo cp cuda/include/cudnn*.h /usr/local/cuda/include
sudo cp cuda/lib/libcudnn* /usr/local/cuda/lib64
sudo chmod a+r /usr/local/cuda/include/cudnn*.h /usr/local/cuda/lib64/libcudnn*
- Install TensorRT
Download the TensorRT tar file from the NVIDIA Official Website.
- Extract and move TensorRT to the
/usr/localdirectory:
# Extract
tar -xvf TensorRT-10.16.0.72.Linux.x86_64-gnu.cuda-12.9.tar.gz
# Enter directory
cd TensorRT-10.16.0.72.Linux.x86_64-gnu.cuda-12.9/
# Move to /usr/local
sudo mv TensorRT-10.16.0.72/ /usr/local/
- Test TensorRT Installation:
# Enter MNIST sample directory
cd /usr/local/TensorRT-10.16.0.72/samples/sampleOnnxMNIST
# Compile
make
# Run the executable found in bin
cd /usr/local/TensorRT-10.16.0.72/bin
./sample_onnx_mnist
SAM3 Deployment
- Python: 3.12 or higher
- PyTorch: 2.7 or higher
- CUDA: Compatible GPU with CUDA 12.6 or higher
- Create Conda Virtual Environment
conda create -n sam3 python=3.12
conda deactivate
conda activate sam3
- Install PyTorch and Dependencies
# For 50-series GPUs, CUDA 12.8 and Torch 2.8 are recommended
# Downgrade numpy to <1.23 if necessary
pip install torch==2.8.0 torchvision==0.23.0 torchaudio==2.8.0 --index-url https://download.pytorch.org/whl/cu128
cd sam3
pip install -e .
- Model Download
- Submit the form to gain download access on HuggingFace: https://huggingface.co/facebook/sam3
- Or search via local mirror sites.
Robotic Arm Driver Deployment
The project outputs target_pose (end-effector pose), which can be manually adapted for different robotic arms.
- Example: PiPER Robotic Arm
pip install python-can
git clone https://github.com/agilexrobotics/pyAgxArm.git
cd pyAgxArm
pip install .
Cloning
Clone this project to your local machine:
cd YOUR_PATH
git clone -b ros2_jazzy_version https://github.com/AgilexRobotics/GraspGen.git
Running the Project
- Grasping Node
python YOUR_PATH/sam3/realsense-sam.py --prompt "Target Object Name in English"
- Grasping Task Execution Controls
A = Zero-force mode (Master arm) | D = Normal mode + Record pose | S = Return to home
X = Replay pose | Q = Open gripper | E = Close gripper | P = Pointcloud/Grasp
T = Change prompt | G = Issue grasp command | Esc = Exit
- Automatic Grasping Task
python YOUR_PATH/sam3/realsense-sam.py --prompt "Target Object Name" --auto
