How to Build a Robot Arm RL Grasping System in Isaac Lab | NERO Arm
This project presents a reinforcement learning workflow for Embodied AI manipulation built on the Nero robotic arm, SO-ARM101, and NVIDIA Isaac Lab. It establishes a simulation-driven framework for training and evaluating robotic manipulation policies, with a focus on preparing the system for simulation-to-real transfer.
Project Summary
Tech Stack
  • RL training pipeline
  • policy validation process
  • robotic manipulation task configuration
  • simulation-to-real transfer preparation
Key Specifications
  • Programming Language: Python 3.8+
  • Hardware: Nero Robotic Arm https://global.agilex.ai/products/nero
  • Base Framework: SO-ARM101 https://github.com/MuammerBay/isaac_so_arm101
  • Simulation Platform: NVIDIA Isaac Lab
  • Open-source implementation:https://github.com/agilexrobotics/Agilex-College/tree/master/isaac_sim/agx_arm_IsaacLab
1. Project Setup and Environment Preparation
1.1 Install Isaac Lab
Follow the official guide to install Isaac Lab:
:backhand_index_pointing_right: Isaac Lab Pip Installation Guide
We use the pip-based installation method (recommended).
Environment:
  • Conda virtual environment
  • Python development environment
  • NVIDIA Isaac Lab
  • Nero robotic arm project dependencies
1.2 Install the uv Package Manager
This project uses uv as its Python package manager.
As a fast, next-generation tool, uv delivers:
  • Faster package installation
  • Efficient dependency resolution
  • Built-in virtual environment management
Compared to traditional tools like pip, uv streamlines setup and reduces environment issues in Python-based robotics and embodied AI workflows.
First, install uv with a single command:
curl -LsSf https://astral.sh/uv/install.sh | sh
After installation, restart your terminal or run the following command to activate the uv environment:
source $HOME/.cargo/env
1.3 Clone the Repository and Install Dependencies
Next, clone the project repository, enter the project directory, and use uv to install all required dependencies with one command:
git clone https://github.com/smalleha/isaac_so_arm101.git
cd isaac_so_arm101
uv sync
uv will automatically create a virtual environment and install all necessary dependency packages. The entire process usually takes only a few minutes and is significantly faster than traditional pip-based installation workflows.
2. Environment Validation
To validate the setup for tasks, we first verify that the required simulation environments for the Nero robotic arm and Piper are properly registered:
uv run list_envs
The expected output should include Isaac-Nero-Reach-v0 and Isaac-Piper-Reach-v0, confirming that the environments have been installed successfully.
Next, run a simulation test with a zero-action agent to validate environment execution and ensure the robotic control pipeline works as expected:
# Test the Piper environment with a zero-action command
uv run zero_agent --task Isaac-SO-ARM100-Reach-v0
If the simulation window launches and the robotic arm behaves as intended, the environment is confirmed to be ready.
3. Project File Structure
isaac_so_arm101/
β”œβ”€β”€ CITATION.cff                # Citation metadata for academic referencing
β”œβ”€β”€ CONTRIBUTING.md             # Contribution guidelines (PR process, standards)
β”œβ”€β”€ CONTRIBUTORS.md             # List of project contributors
β”œβ”€β”€ LICENSE                     # BSD-3-Clause open-source license
β”œβ”€β”€ README.md                   # Main project documentation (setup, tasks, usage)
β”œβ”€β”€ pyproject.toml              # Python project metadata (dependencies, build config)
β”œβ”€β”€ uv.lock                     # Dependency lockfile for reproducible environments
└── src/
    └── isaac_so_arm101/
        β”œβ”€β”€ __init__.py          # Python package initialization
        β”œβ”€β”€ robots/              # Robot models: SO-ARM100/101 simulation configs
        β”œβ”€β”€ scripts/             # Executable scripts: training, testing, playback
        β”œβ”€β”€ tasks/               # RL task definitions (reach, lift)
        └── ui_extension_example.py  # Omniverse UI extension example
This directory structure provides a clear overview of the project organization, making it easy to extend with new use cases such as Nero robotic arm example.
4. Download the URDF Model
This project uses the Nero URDF model from the agx_arm_urdf repository. After cloning the repository,
copy the nero directory into the robots folder of the isaac_so_arm101 project:
git clone https://github.com/agilexrobotics/agx_arm_urdf.git
cd agx_arm_urdf/
cp -r nero/ isaac_so_arm101/robots
Once the model has been copied, modify nero_description.urdf to make it compatible with Isaac Lab. Since the original URDF uses ROS-style package paths, these references must be converted to relative paths so that the link and mesh files can be correctly resolved. The base_link configuration is shown below as an example.
Before Edit
    <link name="base_link">
        <inertial>
            <origin xyz="-0.00319465997 -0.00005467608 0.04321758463" rpy="0 0 0"/>
            <mass value="1.06458435"/>
            <inertia ixx="0.00102659855152" ixy="0.00000186219753" ixz="-0.00000295298037" iyy="0.00114399299508" iyz="-0.00000078763492" izz="0.00090872933022"/>
        </inertial>
        <visual>
            <origin xyz="0 0 0" rpy="0 0 0"/>
            <geometry>
                <mesh filename="package://agx_arm_description/agx_arm_urdf/nero/meshes/dae/base_link.dae"/>
            </geometry>
        </visual>
        <collision>
            <geometry>
                <mesh filename="package://agx_arm_description/agx_arm_urdf/nero/meshes/base_link.stl"/>
            </geometry>
        </collision>
    </link>
After Edit
        <inertial>
        </inertial>
        <visual>
            <geometry>
                <mesh filename="../meshes/dae/base_link.dae"/>
            </geometry>
        </visual>
        <collision>
            <geometry>
                <mesh filename="../meshes/base_link.stl"/>
            </geometry>
        </collision>
    </link>
5.Configuring Isaac Lab Files
Step 1.Importing the URDF Model
After modifying the URDF file, you need to write a Python script to import the URDF model and configure the robotic arm’s motor properties, including stiffness, damping, and other relevant parameters.
This script is typically placed at:
src/isaac_so_arm101/robots/nero/nero.py
The content of this file is shown below:
from pathlib import Path
import isaaclab.sim as sim_utils
from isaaclab.actuators import ImplicitActuatorCfg
from isaaclab.assets.articulation import ArticulationCfg
TEMPLATE_ASSETS_DATA_DIR = Path(__file__).resolve().parent
# Configuration
NERO_CFG = ArticulationCfg(
    spawn=sim_utils.UrdfFileCfg(
        fix_base=True,
        replace_cylinders_with_capsules=True,
        asset_path=f"{TEMPLATE_ASSETS_DATA_DIR}/urdf/nero_gripper.urdf",
        activate_contact_sensors=False,  # Disable contact sensors until capsule collision implementation is complete
        rigid_props=sim_utils.RigidBodyPropertiesCfg(
            disable_gravity=False,
            max_depenetration_velocity=5.0,
        articulation_props=sim_utils.ArticulationRootPropertiesCfg(
            enabled_self_collisions=True,
            solver_position_iteration_count=8,
            solver_velocity_iteration_count=0,
        joint_drive=sim_utils.UrdfConverterCfg.JointDriveCfg(
            gains=sim_utils.UrdfConverterCfg.JointDriveCfg.PDGainsCfg(stiffness=0, damping=0)
    init_state=ArticulationCfg.InitialStateCfg(
        rot=(1.0, 0.0, 0.0, 0.0),
        joint_pos={
            "joint1": 0.0,
            "joint2": 0.0,
            "joint3": 0.0,
            "joint4": 2.0,
            "joint5": 0.0,
            "joint6": 0.0,
            "joint7": 0.0,
            "gripper_joint1": 0.05,
            "gripper_joint2": -0.05
        # Set initial joint velocities to zero
        joint_vel={".*": 0.0},
    actuators={
        "arm": ImplicitActuatorCfg(
            joint_names_expr=["joint.*"],
            effort_limit=25.0,  # Moderate effort limit to prevent instantaneous impact shocks
            velocity_limit=1.5,
            # Stiffness: Optimized for the lightweight Piper robotic arm; prioritizes stability over maximum rigidity
            stiffness={
                "joint1": 200.0,
                "joint2": 170.0,
                "joint3": 120.0,
                "joint4": 80.0,
                "joint5": 50.0,
                "joint6": 20.0,
                "joint7": 10.0
            # Damping: Critical damping strategy with ratio set to approximately 10%
            damping={
                "joint1": 100.0,
                "joint2": 60.0,
                "joint3": 70.0,
                "joint4": 24.0,
                "joint5": 20.0,
                "joint6": 10.0,
                "joint7": 5,
        "gripper": ImplicitActuatorCfg(
            joint_names_expr=["gripper_joint1","gripper_joint2"],
            effort_limit_sim=22,  # Increased from 1.9 to 2.5 for stronger grip
            velocity_limit_sim=1.5,
            stiffness=800.0,  # Increased from 25.0 to 60.0 for more reliable closing
            damping=20.0,  # Increased from 10.0 to 20.0 for stability
    soft_joint_pos_limit_factor=0.9,
Next, create an init.py file to initialize the directory as a Python module.
Step 2.Create Task Configuration Files
In the tasks/lift directory, create the following files:
  • nero_joint_pos_env_cfg.py
  • nero_lift_env_cfg.py
The nero_joint_pos_env_cfg.py file defines the environment configuration for joint position control, including the controllable joints, the robot end-effector link, and the basic task parameters.
# Copyright (c) 2024-2025, Muammer Bay (LycheeAI), Louis Le Lay
# All rights reserved.
# SPDX-License-Identifier: BSD-3-Clause
# Copyright (c) 2022-2025, The Isaac Lab Project Developers.
import isaaclab_tasks.manager_based.manipulation.lift.mdp as mdp
from isaaclab.assets import RigidObjectCfg
# from isaaclab.managers NotImplementedError
from isaaclab.sensors.frame_transformer.frame_transformer_cfg import (
    FrameTransformerCfg,
    OffsetCfg,
from isaaclab.sim.schemas.schemas_cfg import RigidBodyPropertiesCfg
from isaaclab.sim.spawners.from_files.from_files_cfg import UsdFileCfg
from isaaclab.utils import configclass
from isaaclab.utils.assets import ISAAC_NUCLEUS_DIR
from isaac_so_arm101.robots import SO_ARM100_CFG, SO_ARM101_CFG  # noqa: F401
# from isaac_so_arm101.tasks.lift.lift_env_cfg import LiftEnvCfg
from isaac_so_arm101.tasks.lift.nero_lift_env_cfg import LiftEnvCfg
from isaaclab.markers.config import FRAME_MARKER_CFG  # isort: skip
# from isaac_so_arm101.robots.piper_description.piper import PIPER_CFG
from isaac_so_arm101.robots.nero_description.nero import NERO_CFG
@configclass
class NeroLiftCubeEnvCfg(LiftEnvCfg):
    def __post_init__(self):
        # post init of parent
        super().__post_init__()
        # Set so arm as robot
        self.scene.robot = NERO_CFG.replace(prim_path="{ENV_REGEX_NS}/Robot")
        # override actions
        self.actions.arm_action = mdp.JointPositionActionCfg(
            asset_name="robot",
            joint_names=["joint1", "joint2", "joint3", "joint4", "joint5", "joint6","joint7" ],
            scale=0.5,
            use_default_offset=True,
        self.actions.gripper_action = mdp.BinaryJointPositionActionCfg(
            asset_name="robot",
            joint_names=["gripper_joint1","gripper_joint2"],
            open_command_expr={"gripper_joint2": -0.05,"gripper_joint1":0.05},
            close_command_expr={"gripper_joint2": -0.001,"gripper_joint1":0.0},
        # Set the body name for the end effector
        self.commands.object_pose.body_name = ["gripper_base"]
        # Set Cube as object
        self.scene.object = RigidObjectCfg(
            prim_path="{ENV_REGEX_NS}/Object",
            init_state=RigidObjectCfg.InitialStateCfg(pos=[0.2, 0.0, 0.015], rot=[1, 0, 0, 0]),
            spawn=UsdFileCfg(
                usd_path=f"{ISAAC_NUCLEUS_DIR}/Props/Blocks/DexCube/dex_cube_instanceable.usd",
                scale=(0.5, 0.5, 0.5),
                rigid_props=RigidBodyPropertiesCfg(
                    solver_position_iteration_count=16,
                    solver_velocity_iteration_count=1,
                    max_angular_velocity=1000.0,
                    max_linear_velocity=1000.0,
        # Listens to the required transforms
        marker_cfg = FRAME_MARKER_CFG.copy()
        marker_cfg.markers["frame"].scale = (0.05, 0.05, 0.05)
        marker_cfg.prim_path = "/Visuals/FrameTransformer"
        self.scene.ee_frame = FrameTransformerCfg(
            prim_path="{ENV_REGEX_NS}/Robot/base_link",
            debug_vis=True,
            visualizer_cfg=marker_cfg,
            target_frames=[
                FrameTransformerCfg.FrameCfg(
                    prim_path="{ENV_REGEX_NS}/Robot/gripper_base",
                    name="end_effector",
                    offset=OffsetCfg(
                        pos=[0.0, 0.0, 0.125],
@configclass
class NeroLiftCubeEnvCfg_PLAY(NeroLiftCubeEnvCfg):
        # make a smaller scene for play
        self.scene.num_envs = 50
        self.scene.env_spacing = 2.5
        # disable randomization for play
        self.observations.policy.enable_corruption = False
The nero_lift_env_cfg.py file provides the base environment configuration for the lifting task. It specifies the task reward, penalties, policy setup, target point position, and block position, which together define the behavior and objective of the environment.
from dataclasses import MISSING
# from . import mdp
import isaac_so_arm101.tasks.lift.mdp as mdp
from isaaclab.assets import (
    ArticulationCfg,
    AssetBaseCfg,
    DeformableObjectCfg,
    RigidObjectCfg,
from isaaclab.envs import ManagerBasedRLEnvCfg
from isaaclab.managers import CurriculumTermCfg as CurrTerm
from isaaclab.managers import EventTermCfg as EventTerm
from isaaclab.managers import ObservationGroupCfg as ObsGroup
from isaaclab.managers import ObservationTermCfg as ObsTerm
from isaaclab.managers import RewardTermCfg as RewTerm
from isaaclab.managers import SceneEntityCfg
from isaaclab.managers import TerminationTermCfg as DoneTerm
from isaaclab.scene import InteractiveSceneCfg
from isaaclab.sensors.frame_transformer.frame_transformer_cfg import FrameTransformerCfg
from isaaclab.sim.spawners.from_files.from_files_cfg import GroundPlaneCfg, UsdFileCfg
# from isaaclab.utils.offset import OffsetCfg
# from isaaclab.utils.noise import AdditiveUniformNoiseCfg as Unoise
# from isaaclab.utils.visualizer import FRAME_MARKER_CFG
# from isaaclab.utils.assets import RigidBodyPropertiesCfg
# Scene definition
@configclass
class ObjectTableSceneCfg(InteractiveSceneCfg):
    """Configuration for the lift scene with a robot and a object.
    This is the abstract base implementation, the exact scene is defined in the derived classes
    which need to set the target object, robot and end-effector frames
    # robots: will be populated by agent env cfg
    robot: ArticulationCfg = MISSING
    # end-effector sensor: will be populated by agent env cfg
    ee_frame: FrameTransformerCfg = MISSING
    # target object: will be populated by agent env cfg
    object: RigidObjectCfg | DeformableObjectCfg = MISSING
    # Table
    table = AssetBaseCfg(
        prim_path="{ENV_REGEX_NS}/Table",
        init_state=AssetBaseCfg.InitialStateCfg(pos=[0.5, 0, 0], rot=[0.707, 0, 0, 0.707]),
        spawn=UsdFileCfg(usd_path=f"{ISAAC_NUCLEUS_DIR}/Props/Mounts/SeattleLabTable/table_instanceable.usd"),
    # plane
    plane = AssetBaseCfg(
        prim_path="/World/GroundPlane",
        init_state=AssetBaseCfg.InitialStateCfg(pos=[0, 0, -1.05]),
        spawn=GroundPlaneCfg(),
    # lights
    light = AssetBaseCfg(
        prim_path="/World/light",
        spawn=sim_utils.DomeLightCfg(color=(0.75, 0.75, 0.75), intensity=3000.0),
# MDP settings
@configclass
class CommandsCfg:
    """Command terms for the MDP."""
    object_pose = mdp.UniformPoseCommandCfg(
        asset_name="robot",
        body_name=MISSING,  # will be set by agent env cfg
        resampling_time_range=(5.0, 5.0),
        debug_vis=True,
        ranges=mdp.UniformPoseCommandCfg.Ranges(
            pos_x=(0.3, 0.35),
            pos_y=(-0.2, 0.2),
            pos_z=(0.2, 0.35),
            roll=(0.0, 0.0),
            pitch=(0.0, 0.0),
            yaw=(0.0, 0.0),
@configclass
class ActionsCfg:
    """Action specifications for the MDP."""
    arm_action: mdp.JointPositionActionCfg | mdp.DifferentialInverseKinematicsActionCfg = MISSING
    gripper_action: mdp.BinaryJointPositionActionCfg = MISSING
@configclass
class ObservationsCfg:
    """Observation specifications for the MDP."""
    @configclass
    class PolicyCfg(ObsGroup):
        """Observations for policy group."""
        joint_pos = ObsTerm(func=mdp.joint_pos_rel)
        joint_vel = ObsTerm(func=mdp.joint_vel_rel)
        object_position = ObsTerm(func=mdp.object_position_in_robot_root_frame)
        target_object_position = ObsTerm(func=mdp.generated_commands, params={"command_name": "object_pose"})
        actions = ObsTerm(func=mdp.last_action)
            self.enable_corruption = True
            self.concatenate_terms = True
    # observation groups
    policy: PolicyCfg = PolicyCfg()
@configclass
class EventCfg:
    """Configuration for events."""
    reset_all = EventTerm(func=mdp.reset_scene_to_default, mode="reset")
    reset_object_position = EventTerm(
        func=mdp.reset_root_state_uniform,
        mode="reset",
        params={
            "pose_range": {"x": (0.1, 0.2), "y": (-0.1, 0.2), "z": (0.0, 0.0)},
            "velocity_range": {},
            "asset_cfg": SceneEntityCfg("object", body_names="Object"),
@configclass
class RewardsCfg:
    """Reward terms for the MDP."""
    reaching_object = RewTerm(func=mdp.object_ee_distance, params={"std": 0.05}, weight=1.0)
    lifting_object = RewTerm(func=mdp.object_is_lifted, params={"minimal_height": 0.025}, weight=15.0)
    object_goal_tracking = RewTerm(
        func=mdp.object_goal_distance,
        params={"std": 0.3, "minimal_height": 0.025, "command_name": "object_pose"},
        weight=16.0,
    object_goal_tracking_fine_grained = RewTerm(
        params={"std": 0.05, "minimal_height": 0.025, "command_name": "object_pose"},
        weight=5.0,
    # action penalty
    action_rate = RewTerm(func=mdp.action_rate_l2, weight=-1e-4)
    joint_vel = RewTerm(
        func=mdp.joint_vel_l2,
        weight=-1e-4,
        params={"asset_cfg": SceneEntityCfg("robot")},
@configclass
class TerminationsCfg:
    """Termination terms for the MDP."""
    time_out = DoneTerm(func=mdp.time_out, time_out=True)
    object_dropping = DoneTerm(
        func=mdp.root_height_below_minimum, params={"minimum_height": -0.05, "asset_cfg": SceneEntityCfg("object")}
@configclass
class CurriculumCfg:
    """Curriculum terms for the MDP."""
    action_rate = CurrTerm(
        func=mdp.modify_reward_weight, params={"term_name": "action_rate", "weight": -1e-1, "num_steps": 10000}
    joint_vel = CurrTerm(
        func=mdp.modify_reward_weight, params={"term_name": "joint_vel", "weight": -1e-1, "num_steps": 10000}
# Environment configuration
@configclass
class LiftEnvCfg(ManagerBasedRLEnvCfg):
    """Configuration for the lifting environment."""
    # Scene settings
    scene: ObjectTableSceneCfg = ObjectTableSceneCfg(num_envs=4096, env_spacing=2.5)
    # Basic settings
    observations: ObservationsCfg = ObservationsCfg()
    actions: ActionsCfg = ActionsCfg()
    commands: CommandsCfg = CommandsCfg()
    # MDP settings
    rewards: RewardsCfg = RewardsCfg()
    terminations: TerminationsCfg = TerminationsCfg()
    events: EventCfg = EventCfg()
    curriculum: CurriculumCfg = CurriculumCfg()
        """Post initialization."""
        # general settings
        self.decimation = 2
        self.episode_length_s = 5.0
        self.viewer.eye = (2.5, 2.5, 1.5)
        # simulation settings
        self.sim.dt = 0.01  # 100Hz
        self.sim.render_interval = self.decimation
        self.sim.physx.bounce_threshold_velocity = 0.2
        self.sim.physx.bounce_threshold_velocity = 0.01
        self.sim.physx.gpu_found_lost_aggregate_pairs_capacity = 1024 * 1024 * 4
        self.sim.physx.gpu_total_aggregate_pairs_capacity = 16 * 1024
        self.sim.physx.friction_correlation_distance = 0.00625
Then, the nero reach task needs to be registered in src/isaac_so_arm101/tasks/reach/__init__.py
import gymnasium as gym
from . import agents
# Register Gym environments.
gym.register(
    id="Isaac-SO-ARM100-Lift-Cube-v0",
    entry_point="isaaclab.envs:ManagerBasedRLEnv",
    kwargs={
        "env_cfg_entry_point": f"{__name__}.joint_pos_env_cfg:SoArm100LiftCubeEnvCfg",
        "rsl_rl_cfg_entry_point": f"{agents.__name__}.rsl_rl_ppo_cfg:LiftCubePPORunnerCfg",
    disable_env_checker=True,
gym.register(
    id="Isaac-SO-ARM100-Lift-Cube-Play-v0",
    kwargs={
        "env_cfg_entry_point": f"{__name__}.joint_pos_env_cfg:SoArm100LiftCubeEnvCfg_PLAY",
gym.register(
    id="Isaac-SO-ARM101-Lift-Cube-v0",
    kwargs={
        "env_cfg_entry_point": f"{__name__}.joint_pos_env_cfg:SoArm101LiftCubeEnvCfg",
gym.register(
    id="Isaac-SO-ARM101-Lift-Cube-Play-v0",
    kwargs={
        "env_cfg_entry_point": f"{__name__}.joint_pos_env_cfg:SoArm101LiftCubeEnvCfg_PLAY",
gym.register(
    id="Isaac-Nero-Lift-Cube-v0",
    kwargs={
        "env_cfg_entry_point": f"{__name__}.nero_joint_pos_env_cfg:NeroLiftCubeEnvCfg",
        "rl_games_cfg_entry_point": f"{agents.__name__}:rl_games_ppo_cfg.yaml",
6. An Isaac Lab Training and Evaluation Pipeline
First, activate the Conda environment:
conda activate env_isaaclab
Then switch to the project directory:
cd isaac_so_arm101
Start training the Isaac-Nero-Lift-Cube-v0 task in headless mode to reduce GPU and display overhead:
uv run train --task Isaac-Nero-Lift-Cube-v0 --headless
If your hardware is strong enough, you can also run training with visualization enabled to observe the learning process directly:
This task is trained for 1,000 iterations. Once training is finished, use the following command to evaluate the learned policy:
uv run play --task Isaac-Nero-Lift-Cube-v0
nerorl (2)
7. Summary
Key outcomes of this work include:
  • URDF Model Integration
  • Reproducible RL Training Pipeline
  • Environment Validation
The workflow can also be extended to more complex manipulation scenarios, including multi-object grasping and obstacle avoidance, with the Nero robotic arm serving as the deployment target for simulation-to-real transfer.
:speech_balloon: FAQ
What is inverse kinematics in robotics?
Inverse kinematics (IK) calculates the required joint angles for a robotic arm to reach a target position and orientation.
How does ROS2 help with robot arm control?
ROS2 provides communication, motion control, and integration tools for robotic manipulators, including MoveIt2 and RViz.
What is the difference between FK and IK?
Forward kinematics calculates the end-effector position from joint angles, while inverse kinematics calculates joint angles from a target pose.
Why use MoveIt2 for robot arms?
MoveIt2 simplifies robot arm motion planning, collision checking, and trajectory execution in ROS2 environments.
Can this IK solver run on a real robot arm?
Yes. The parametric IK solver can be deployed on physical robot arms after proper calibration and controller integration.
Does NERO Arm support Gazebo simulation?
Yes. The NERO Arm can be simulated in Gazebo and visualized in RViz for testing and development.
:waving_hand: Still Have Question?
If you encounter any issues with environment installation, parameter configuration, or RL training, feel free to leave your questions for further discussion.
Hi
is the arm correctly aligning to the goal orientation ? In the test video, its seems like its is reaching to the position but not the orientation ?
Hi! Good catch.
You’re correct, the reward function in this demo only optimizes for end-effector position, with no explicit orientation reward or penalty.
Hope this is helpful to you!
