I just wanted to share a little proof-of-concept project that I worked on a while ago where I embedded Rust inside of a ROS 2 C++ node using the cxx crate. Admittedly, it’s not the most amazing of demonstrations (I just modified the example publisher), but I think it shows how Rust can be added into projects for those so inclined - at least until the official client library stabilizes.
Additionally, it shows the use of the corrosion crate to allow the Rust code to be built alongside the C++ code, and have all the code be built by colcon build!
Source code is here: GitHub - jhdcs/rust_colcon_experiment: An experiment in integrating Rust in a C++ node via the CXX crate
