EpisodeVault: open source tool to debug why your LeRobot model regressed
Been building with LeRobot v3 and kept hitting the same wall: retrain a policy, it gets worse, no clear idea why. DVC tells you files changed. MLflow tells you which run. Nobody tells you which tasks dropped or which episodes degraded between dataset versions.
Built a small open source library to fill that gap.
Four commands
episodevault track ./my_dataset
episodevault commit -m "added kitchen episodes"
episodevault diff v1.0 v2.0
episodevault blame model_v3
What the diff looks like
Ran this against two real LeRobot datasets:
Dataset diff: v1.0 → v2.0
Episodes added:    +0
Episodes removed:  -7
Distribution shift:
  factory_pick        2 → 6   ↑ 200%  ⚠️
  kitchen_grasp       4 → 1   ↓ 75%   ⚠️
Quality metrics:
  avg episode length:    3.7s → 3.0s  ↓
  success_rate:          0.88 → 0.38  ↓
  camera_sync_score:     1.00 → 1.00  →
Likely regression cause:
  'kitchen_grasp' episodes dropped 75% (4 → 1). Restore from prior
  version if this task is in your eval benchmark.
The blame command
One line in your training script:
import episodevault as ev
ev.log_training_run(model_version="model_v3", dataset_version="v2.0")
Then later:
Traces the model back to the exact dataset version that trained it and shows the diff automatically.
Compatibility
Tested against four real datasets from the Hub:
Robot Dataset Episodes Frames Parse time
aloha aloha_static_pro_pencil 25 8,750 0.35s
aloha aloha_mobile_shrimp 18 67,500 0.38s
so100 svla_so100_stacking 56 22,956 0.63s
aloha aloha_mobile_cabinet 85 127,500 2.73s
Install
pip install episodevault
Python 3.10+. Works on any local LeRobot v3 dataset.
GitHub: Rohan-Prabhakar/EpisodeVault
If you have a dataset where this breaks or gives a wrong regression hint, open an issue, that’s the most useful feedback right now.
Update: just shipped cloud-native storage support (S3, GCS, Azure).
EpisodeVault now reads metadata directly from cloud object storage via fsspec, so you don’t have to download terabytes of video just to diff your dataset. You can run:
episodevault track s3://my-bucket/lerobot-v1
episodevault commit s3://my-bucket/lerobot-v1 -m “initial snapshot”
episodevault diff v1.0 v2.0 s3://my-bucket/lerobot-v1 --html audit.html
It only pulls the tiny Parquet manifests over the network. Raw sensor data stays in the bucket. Works with AWS S3, Google Cloud Storage, and Azure Blob. Also added a full test suite covering the cloud code paths using fsspec’s memory filesystem.
