I have been following the documentation to make a simple diff drive robot with 2 back wheels and one caster wheel but as seen from the video the robot keeps wobbling up and down
as seen from the video it’s just going up and down not a steady or smooth at all
From searching i found people usually fix it with adding friction to the caster wheel, it didn’t’ fix it for me..
This is the code for the caster wheel
<!-- CASTER -->
<link name="caster_wheel">
<visual>
<geometry>
<sphere radius="${caster_radius}" />
</geometry>
<material name="black" />
<origin xyz="0.0 0.0 0.0" rpy="0.0 0.0 0.0" />
</visual>
<collision>
<geometry>
</geometry>
<surface>
<friction>
<ode>
<mu>0.4</mu>
<mu2>0.4</mu2>
<slip1>1.0</slip1>
<slip2>1.0</slip2>
</ode>
</friction>
</surface>
</collision>
<xacro:solid_sphere_inertial m="${caster_mass}" r="${caster_radius}" />
</link>
<joint name="base_caster_wheel_joint" type="fixed">
<parent link="base_link" />
<child link="caster_wheel" />
<origin xyz="${base_length * 1/4} 0.0 -${caster_radius + base_height / 2}" rpy="0.0 0.0 0.0" />
</joint>
Here is the sphere inertial
<xacro:macro name="solid_sphere_inertial" params="m r">
<inertial>
<mass value="${m}" />
<inertia ixx="${2/3 * m * r * r}" ixy="0.0" ixz="0.0" iyy="${2/3 * m * r * r}" iyz="0.0"
izz="${2/3 * m * r * r}" />
</inertial>
</xacro:macro>
those are my simulated robot dimensions and masses
<xacro:property name="base_length" value="0.6" />
<xacro:property name="base_width" value="0.3" />
<xacro:property name="base_height" value="0.1" />
<xacro:property name="base_mass" value="0.5" />
<xacro:property name="wheel_radius" value="0.07" />
<xacro:property name="wheel_length" value="0.04" />
<xacro:property name="wheel_mass" value="0.1" />
<xacro:property name="caster_radius" value="0.03" />
<xacro:property name="caster_mass" value="0.05" />
This is extra info of my robot base link and wheels, i’m really sorry if i’m missing something obvious there i’m quite new to gazebo and i have been really struggling with this one for a while
<!-- BASE LINKS -->
<link name="base_footprint" />
<link name="base_link">
<visual>
<geometry>
<box size="${base_length} ${base_width} ${base_height}" />
</geometry>
<material name="green" />
<origin xyz="0 0 0" rpy="0.0 0.0 0.0" />
</visual>
<collision>
<geometry>
</geometry>
</collision>
<xacro:box_inertial m="${base_mass}" l="${base_length}" w="${base_width}" h="${base_height}" />
</link>
<joint name="base_footprint_base_link_joint" type="fixed">
<parent link="base_footprint" />
<child link="base_link" />
<origin xyz="0 0.0 ${base_height / 2}" rpy="0.0 0.0 0.0" />
</joint>
<!-- WHEELS -->
<xacro:macro name="wheel" params="prefix direction_sign">
<link name="${prefix}_wheel">
<visual>
<geometry>
<cylinder radius="${wheel_radius}" length="${wheel_length}" />
</geometry>
<origin xyz="0.0 0.0 0.0" rpy="${pi / 2} 0.0 0.0" />
</visual>
<collision>
<geometry>
</geometry>
</collision>
<xacro:cylinder_inertial m="${wheel_mass}" r="${wheel_radius}" l="${wheel_length}" />
</link>
<joint name="base_${prefix}_wheel_joint" type="continuous">
<child link="${prefix}_wheel" />
<axis xyz="0.0 1 0.0" />
<origin
xyz="-${base_length * 1/4} ${direction_sign}${base_width / 2 + wheel_length / 2} ${-base_height / 2}"
</joint>
</xacro:macro>
<xacro:wheel prefix="left" direction_sign="-" />
<xacro:wheel prefix="right" direction_sign="+" />
