Hi everyone,
I’m currently working with a Baxter robot system and ran into an issue after recovering access to the internal PC. I’d really appreciate any guidance from those who have dealt with similar setups.
Background
Platform: Baxter robot
Internal PC: Dell OptiPlex 7010
OS: Baxter RSDK system (Ubuntu-based), but also has a Gentoo layer
ROS: Indigo
The robot had been unused for several years. Initially:
BIOS was locked (password protected)
Could not access GRUB or boot from USB
SSH password was unknown
I managed to:
Reset BIOS password (via PSWD jumper)
Boot from a Live USB
Reset the
ruserpassword via chroot -
Successfully SSH into the robot
Current Status
SSH into Baxter works (
ruserlogin OK) -
Network connection is working (can ping and communicate)
System boots into a Gentoo console login
I can log into the Gentoo environment
I cannot access or see the RSDK (Ubuntu-based) GUI environment
ROS tools are accessible after sourcing environment (in some contexts)
Problem
The RSDK GUI does not start automatically on boot.
Instead of the normal Baxter interface, the system:
Boots into a Gentoo console
Requires manual login
Does not launch the Baxter runtime or GUI
Does not appear to transition into the RSDK (Ubuntu) environment
What I’ve tried
Logged in via SSH and locally
Verified system access through Gentoo console
Sourced ROS:
source /opt/ros/indigo/setup.bash -
Tried enabling the robot manually:
rosrun baxter_tools enable_robot.py -e -
Attempted:
rostopic list
However:
It seems the Baxter runtime is not being launched
The system may not be switching from Gentoo → RSDK layer
Startup scripts/services may be broken or missing
Questions
What is responsible for transitioning from the Gentoo layer into the RSDK (Ubuntu) environment?
What service or script launches the Baxter GUI on boot?
Is there a manual way to trigger the RSDK environment from the Gentoo console?
Could this be a broken startup script, service, boot configuration, or a corrupted drive?
Is there a known way to restore the original Baxter startup behaviour without reinstalling the system?
If there are no way to restore it then is there an image of the system available? I tried checking in with Cothinks Robotics (The ones who took over the license and manufacturing from Rethinks Robotics.) with no response.
Additional Notes
I would prefer not to wipe the system, since the original Baxter image is difficult to obtain
Hardware appears to be functioning correctly
This seems like a boot/runtime configuration issue rather than a hardware failure
Goal
Restore normal behaviour where:
Baxter boots into the RSDK GUI
The robot runtime starts automatically
No manual login or intervention is required
Any help or pointers (especially from others maintaining older Baxter systems) would be greatly appreciated.
Thanks in advance.
