Hey everyone,
I’ve been working with the Baxter robot recently and ran into a lot of common issues that come up when dealing with an older platform with limited support. Since official Rethink Robotics docs are gone, I compiled this troubleshooting guide from my experience and archived resources. Hopefully, this saves someone hours of frustration!
Finding Documentation
- Use the Wayback Machine to access old docs:
Archived SDK Wiki
Startup & Boot Issues
1. Baxter not powering on / unresponsive screen
- Power cycle at least 3 times, waiting 30 sec each time.
- If it still doesn’t work, go into FSD (Field Service Menu):
PressAlt + F→ reboot from there.
2. BIOS password lockout
- Use BIOS Password Recovery
- Enter system number shown when opening BIOS.
- Generated password is admin → confirm with
Ctrl+Enter.
3. Real-time clock shows wrong date (e.g., 2016)
- Sync Baxter’s time with your computer.
- Set in Baxter FSM or use NTP from your computer via command line.
Networking & Communication
4. IP mismatch between Baxter and workstation
- Set Baxter to Manual IP in FSM.
5. Static IP configuration on Linux (example: 192.168.42.1)
- First 3 numbers must match between workstation and Baxter.
- Ensure Baxter knows your IP in
intera.sh.
6. Ping test: can’t reach baxter.local
- Make sure Baxter’s hostname is set correctly in FSM.
- Disable firewall on your computer.
- Try pinging Baxter’s static IP.
7. ROS Master URI not resolving
export ROS_MASTER_URI=http://baxter.local:11311
8. SSH into Baxter fails
- Verify SSH installed, firewall off, IP correct.
ROS & Intera SDK Issues
9. Wrong catkin workspace sourcing
source ~/ros_ws/devel/setup.bash
10. enable_robot.py or joint_trajectory_action_server.py missing
- Run
catkin_makeorcatkin_buildafter troubleshooting.
11. intera.sh script error
- Ensure file is in root of catkin workspace:
~/ros_ws/intera.sh
12. MoveIt integration not working
- Ensure robot is enabled and joint trajectory server is active in a second terminal.
Hardware & Motion Problems
13. Arms not enabled or unresponsive
rosrun baxter_tools enable_robot.py -e
- Test by gripping cuffs (zero-g mode should enable).
14. Joint calibration errors
- Restart robot. Happens if you hit
CTRL+Zmid-script.
Software/Configuration Mismatches
15. Time sync errors causing ROS disconnect
- Sync Baxter’s time in FSM or use
chronyorntp.
Testing, Debugging, & Logging
16. Check robot state:
rostopic echo /robot/state
17. Helpful debug commands:
rostopic list
rosnode list
rosservice list
18. Reading logs:
- Robot:
~/.ros/log/latest/ - Workstation:
/var/log/roslaunch.log
19. Confirm joint angles:
rostopic echo /robot/joint_states
If you have more tips or fixes, add them in the comments. Let’s keep these robots running.
