Why we did not extend /diagnostics?
Can /diagnostics carry a fault, or only a status?
We spent a year building a diagnostic layer for ROS 2 (ros2_medkit, earlier thread: What's missing from ROS 2 diagnostics (and what we built) ) and the question we get most (including from a ROSCon reviewer) is why we did not extend diagnostic_msgs, diagnostic_updater and the aggregator instead.
Here is the reasoning with the message definitions side by side, so the specifics can be argued with.
TL;DR: a status is information, a fault is a model you can query and act on, and the second does not fall out of the first by adding fields or more context.
What /diagnostics is, and does well
REP 107 (Tully Foote, November 2010) wrote down the diagnostics system Willow Garage had already built: a /diagnostics topic carrying DiagnosticArray of DiagnosticStatus, and an aggregator with analyzers. It names three things the system is for:
  • a quick look at normal operation
  • detailed debug information
  • and long-term logs for history.
Its best practices are robot_monitor on screen while the robot runs, and a rosbag record of /diagnostics in the bringup launch. The REP defined three levels, OK, Warn and Error. The message today:
byte OK=0
byte WARN=1
byte ERROR=2
byte STALE=3
byte level
string name          # "a description of the test/component reporting"
string message       # "a description of the status"
string hardware_id   # "a hardware unique string"
KeyValue[] values
diagnostic_updater publishes on a period (1s by default)
diagnostic_aggregator groups statuses by name rules (prefix, substring, regex) into /diagnostics_agg, publishes the worst level on /diagnostics_toplevel_state, and marks an item STALE when it stops updating within the analyzer timeout.
rqt_robot_monitor keeps the last 30 arrays in memory.
diagnostic_remote_logging sends statuses to InfluxDB.
diagnostic_analysis, the ROS 1 tool for recorded diagnostics, is “Not ported to ROS2 yet” in the ros2 README.
That is a live status stream. It works well for a person watching a screen, and we did NOT change any of it.
Where a status stream is not enough
Identity. A status is keyed by who reports it (name, “LiDAR scan0”). It can say what broke in message, hardware_id or a key-value, and people use those fields that way, but that is text. Nothing in the stack reads it as a fault identity. The aggregator keeps one status per name, the latest, and overwrites it with the next one. So the stack has no thing called “the fault”. I mean nothing knows when it started, how many times it came back, whether it is still active, or whether anyone acknowledged it.
rqt keeps the last 30 arrays, so a blip at night is gone by morning. People have asked for this before. In January 2018 someone on ROS Answers wanted a latched log of warnings and errors (“high level system log, latching diagnostic warnings/error”, question 280273). Nobody answered, and the asker wrote that they would probably build their own collector node.
Address. Say you have the rosbag from the three seconds around the failure. Where do you put it? hardware_id is just a free text. The aggregator tree is for display in rqt and a tag for the InfluxDB exporter, not a place where you can attach a recording.
Also, much of what breaks in a robot is not a ROS node: the MCU in a motor driver, a sensor with its own firmware. These appear in /diagnostics only if the driver author wrote a diagnostic task for them, and when the driver goes quiet the aggregator can only say STALE.
Operations and state. You cannot ask the stream about a fault. Is it still active? acknowledge it, change the configuration behind it, give me the recording. What the aggregator holds in RAM dies with the process. A bag of /diagnostics or the InfluxDB export survives a restart, but those are stored samples, not state. To know what is active now, you read the samples and work it out yourself. Whatever answers those questions has to be a separate service beside the ROS graph, one that holds fault records with an address and verbs. At that point you are no longer extending a message. Extending the aggregator ends in the same place. The aggregator does one thing: statuses in, one combined status out, with a fast path for watchdogs. Add fault ids, a database and an API and it is no longer an aggregator. It is a fault manager.
What we built beside it
ros2_medkit_msgs/Fault:
string fault_code               # e.g. MOTOR_OVERHEAT
uint8 severity                  # INFO WARN ERROR CRITICAL
string description              # the third argument of report()
builtin_interfaces/Time first_occurred
builtin_interfaces/Time last_occurred
builtin_interfaces/Time last_passed
uint32 occurrence_count         # counted on edges: a cleared fault that comes back adds one
string status                   # PREFAILED PREPASSED CONFIRMED HEALED CLEARED
string[] reporting_sources
The lifecycle is an AUTOSAR DEM-style debounce counter. FAILED events move it towards CONFIRMED, PASSED events move it towards HEALED. HEALED means the counter reached the healing threshold. CLEARED means a human acknowledged the fault through the clear service. Both kinds of record stay in the database.
Defaults worth knowing before you compare
  • Bare fault manager: confirmation_threshold: -1 (the first FAILED report confirms, set -N to require N) and healing_enabled: false. The bringup launch turns healing on with healing_threshold: 3 and switches black-box recording on.
  • CRITICAL skips a configured confirmation threshold.
  • FaultReporter (one include, report(code, severity, description)) has a client-side filter: a WARN is held until three reports in ten seconds, ERROR goes through at once, and PASSED is held the same way. The bridge reports through it, so three OK samples reach the manager as one PASSED.
  • What survives a clear: the compact freeze frame does. Ordinary snapshot rows and the default single rosbag per fault code do not, unless you set snapshots.retain_on_clear and raise the bag retention.
  • Freeze frame (entity-default capture): up to 16 topics published by the reporting ROS node, sampled after confirmation, /rosout and /parameter_events excluded, best effort.
  • Rosbag: our own RAM ring buffer, written through the rosbag2 writer to MCAP, 5 s before and 1 s after by default. It records the entity’s topics plus /tf when the source maps to a live node, otherwise the full buffer.
  • Storage: SQLite at /var/lib/ros2_medkit/faults.db. Faults, freeze frames and the near-miss series (FAILED reports that moved the counter without confirming) are still there after a restart.
On CONFIRMED the fault manager takes a freeze frame of the reporting node’s topics and with recording on, it writes its ring buffer to an MCAP bag. Each fault is linked by its reporting sources to an entity in a SOVD (ISO 17978) tree: Areas, Components, Apps, Functions. A function carries its own /faults, so “obstacle avoidance is degraded” maps to the app that is containing the fault. A device that never speaks DDS becomes an external component from the manifest, and a protocol plugin (OPC UA in the open repo) turns its alarms into faults on it. All of it is served over REST: list and stream faults (SSE), read one, clear it, read the entity’s data, PUT a configuration, download the bag from bulk-data, etc. A laptop, a fleet server or a tool can do that without joining the DDS graph.
And /diagnostics stays an input
ros2_medkit_diagnostic_bridge subscribes to /diagnostics and feeds the fault manager:
DiagnosticStatus level Fault event
OK PASSED, moves the fault towards HEALED when healing is enabled
WARN fault, severity WARN
ERROR fault, severity ERROR
STALE fault, severity CRITICAL (see caveats)
An existing diagnostic_updater gains a fault code, a lifecycle and a history. The node does not change.
Bridge details and caveats
  • Codes: taken from the name (motor: Temperature becomes MOTOR_TEMPERATURE) or mapped by hand.
  • Who owns the fault: by default the bridge itself is the reporting source, so a bridged fault hangs on the bridge node and gets no entity freeze frame of its own. Set use_hardware_id_as_source_id and put the driver’s full node name (with slashes) in hardware_id, or configure snapshots.default_topics. The log and action bridges point at the real node.
  • STALE is produced by the aggregator, so the STALE row only fires when the bridge listens to /diagnostics_agg.
  • Action servers: ros2_medkit_action_status_bridge turns an action with an ABORTED goal into one fault, healed on the next success, CANCELED ignored unless configured. /rosout comes in through ros2_medkit_log_bridge.
How the existing tools fit
diagnostic_updater and the aggregator stay the live status stream. We read it as input and change nothing. Grafana and the Canonical observability stack plot whatever you feed them, host metrics or /diagnostics levels through diagnostic_remote_logging. A dashboard plots samples. The fault, its owner, its evidence and the next action still need to live somewhere else. rosbag2 is the writer and the format we record into. Its snapshot mode has the same “buffer then write” shape, but its only trigger is a manual service call, so the fault manager keeps its own ring buffer and writes it when a fault confirms.
The question to diagnostics users
Where should the line be? Our answer: DiagnosticStatus stays the health stream, and the fault record, its entity and the REST API get agreed on separately. That is what we built. Should the fault record become a shared ROS message one day? That is the question for this group. The ROSCon talk goes through the trade-offs.
Repo: ros2_medkit
Sources
Honestly this matches what I keep running into, so here’s the field version of your argument.
I maintain a sensor fusion filter that publishes per-sensor health on /diagnostics. Three times this year it’s been badly broken while every single status sat at OK. GPS gates quietly throwing away 100% of good fixes (messages arrive fine, they just all get discarded after arrival). A weighting bug where position drifted backwards while velocity read 1.000 and yaw read 0.00. And my covariance being so underconfident that NIS sits at 0.03 instead of 3, which means the outlier gate can’t fire on anything at all.
Every one of those needed a number crossing a threshold to catch, not a level. I ended up bolting outlier counts onto every status as key-values, which is basically me admitting the level wasn’t doing the job.
One bit of your bridge table I’d push back on though. You map STALE to CRITICAL. On an outdoor robot stale is often just normal. My IMU publishes orientation covariance -1 permanently and on purpose, and GPS goes stale in every blackout by design. That would fire CRITICAL nonstop on my rover, so I map STALE to WARN deliberately.
I also needed a third state you don’t have a row for: NOT_INIT, meaning I’ve never heard from this sensor at all. That’s a different problem from “it stopped”, config versus runtime. I squash both to WARN right now and I don’t love it.
So, question back at you. Is a fault code plus a debounce counter enough, or does the fault record want to carry a measured quantity too? None of my three would’ve produced a FAILED event for you to debounce in the first place.
Thanks, your three cases show really interesting problem. The level said OK while the filter was wrong, and no level would have caught that.
To your question: a code + a debounce counter is not enough for detection, and it was never meant to be. Detection is a monitor, a check of a number over a window, plus a rule for when the check is active. Your three cases are exactly that: rejected fixes over a window, position against velocity, NIS out of band for N seconds.
Neither stack gives you that today. diagnostic_updater has windows for rate and timestamp delay only. medkit has threshold rules only for plugin data, and its debounce counts reports, not time. So today the test is your code either way.
And no, the measured quantity does not become a field of the fault record. It goes into the monitor as input and into the freeze frame as evidence.
The split is observation, monitor, fault manager. medkit already has it for graph state: the graph watchdog plugin raises faults for things that never produce a FAILED event on their own,
QoS mismatch, orphan topics, parameter drift, node death, lifecycle expectations. Your cases need the same layer for values over time, and it does not exist yet. The fault manager should not learn what a healthy NIS looks like, any more than it knows what a healthy graph looks like. The monitor knows that. The fault manager knows that MODEL_INCONSISTENCY failed, when, whether it is still active, and what evidence was captured when it did.
Automotive splits it the same way. The DTC is the code, the status bits and the counters, the measurement sits in the freeze frame, and monitors have windows, time debounce and enable conditions. A GPS check does not count during a blackout, which is your STALE problem handled in the monitor instead of by mapping STALE to a softer level. And “never heard from this sensor” is not a fault there, it is a status bit of the test, testNotCompletedThisOperationCycle, which needs a declared list of expected sources. medkit does not have that state yet.
Two issues go into ros2_medkit from this thread:
  1. The bridge keeps the DiagnosticStatus key-values as evidence in the freeze frame, and STALE severity becomes configurable per name.
  2. Value detectors in the graph watchdog: a number out of band for a duration, a rate of events over a window, a cross-check of two signals, with enable conditions and time debounce, reading topic fields and /diagnostics key-values. Your outlier counts become faults without new code in the filter. The “test not completed” state for NOT_INIT is fault manager work and comes after.
If you want to help build either of them, you are welcome. Your filter can be the test case :slight_smile:
Yeah, fair on STALE. You’re right, and honestly I was just working around something.
Mapping it to WARN was me not having enable conditions. “Don’t run the GPS check during a blackout” is obviously the right answer and it just never occurred to me. I softened the level so it would stop shouting at me. Same thing with NOT_INIT, a declared list of expected sources is clearly better than what I do now, which is squash it into WARN and feel bad about it.
On the measured quantity going into the monitor and the freeze frame instead of into the fault record, yeah I agree. But I think I’ve got a small bit of evidence for why the monitor part is harder than it looks.
So I actually shipped one of these this week, inside the filter. The IMU and the wheel encoders should agree about which way the robot is turning. On my rover they disagreed for months, because the gyro yaw sign was inverted. Both sensors totally healthy, every status OK the whole time. It got blamed on the wheels twice before anyone looked at the gyro.
The detector has exactly the enable condition you’re describing:
only count a sample when BOTH sensors say the robot is turning
faster than 0.08 rad/s (4.6 deg/s)
Below that the sign doesn’t mean anything. Gyro noise crosses zero constantly, and a differential robot driving straight makes up small amounts of yaw from wheel scale mismatch anyway.
Anyway, the bit I got wrong first is the window shape. My first version wanted the disagreement to last 3 continuous seconds, which is kind of the obvious reading of “debounce”. It never fired. Not even on a log where I’d inverted the gyro on purpose to test it. Turns out a hand-driven rover corrects all the time, so the yaw rate is crossing zero constantly. On a real log the longest unbroken stretch with both sensors above even 0.05 rad/s was 0.9 seconds. So a rule that needs 3 continuous seconds was never going to fire on real driving, which is exactly the case it was written to catch.
Counting votes instead of needing a streak works fine. Every sample where both sensors agree the robot is turning casts a vote, and it latches at 200 votes with 80 percent disagreement. Same log: correct sign gives 6 percent disagreement, inverted gives 80. That’s a nice wide margin, and it’s on real driving rather than something I made up.
So I guess my point for your value detectors is that time debounce and count debounce aren’t interchangeable. Which one you want depends on whether the enable condition is continuously true, and mine isn’t. I’d bet that’s normal for anything a human is driving.
One more for the pile, since it’s the same shape as my other three. My GPS outlier gate compares each fix against the filter, so the threshold scales with the filter’s own covariance. Last week it sat 39 times below firing for an entire run. Largest Mahalanobis distance across 222 fixes was 0.42, against a threshold of 16.27. Every single fix reported ACCEPTED, which honestly just reads like clean GPS when you look at it. I only caught it by injecting a fake spike into the log and replaying: 15 metres got accepted and moved position 4.5 metres, and it took a 30 metre jump before anything got rejected at all. No level catches that, and a fault code doesn’t either. You need something watching a number against a threshold that can say “this gate can’t actually fire”.
Are you presenting at ROSCon in person? I’ve got a BoF on the Tuesday, Outdoor Localization in ROS 2. If you’re around, the test case thing is probably a twenty minute conversation rather than a thread. Would like to catch your talk either way.
I’ll be in Toronto pretty much all week. Talk is Thursday 24 Sept, 16:50, Production diagnostics for ROS. Tuesday BoF works for me, or just grab a slot here: calendar.
Quick pass through your cases, how automotive does it and where medkit is.
Votes instead of a time window.
Here automotive does the same thing, count up on failed, down on passed, timer only for checks that stay on, and an enable condition in front of both. Our medkit has the counter in the fault manager already. What’s missing is a detector that runs a check on a number with that window and that enable condition, and that’s #669: three window shapes, time, counter and ratio. Your 200 votes at 80 percent is the ratio one.
The gate that can’t fire.
Automotive knows a monitor can fail too, but it only tracks whether the monitor ran, not whether it could still fire. That bit I’m adding myself in the same issue, a second check that compares the gate’s statistic with its threshold and raises its own code when the largest value stays 39 times below the threshold for a whole run. Your spike replay is the on-demand version of it. medkit has operations on apps already, storing the result with the fault doesn’t exist yet, that’s a separate issue once the detectors are in.
STALE in a blackout and the sensor you never heard from.
Automotive doesn’t soften the level, it switches the check off while the enable condition is false and keeps a separate “test not completed” bit for a sensor that never reported. Enable condition is in #669. STALE per name is in #668, together with keeping your key-values in the freeze frame instead of throwing them away. The “never heard from” state comes later, it needs a declared list of expected sources.
See you in Toronto!
Grabbing a slot on your calendar for later in the week. BoF is Tuesday, Outdoor Localization in ROS 2, and I’ll be at your talk Thursday either way.
Thanks for mapping those onto #668 and #669. The ratio window being the one that matches my case makes sense, and I only got there by failing with the time window first.
One more failure shape for #669, if it’s still open enough to take one. It’s the same family as “the gate can’t fire” but it isn’t the same bug, and I only found it yesterday.
I added a second GPS gate that doesn’t touch the filter’s covariance at all. It just checks whether a fix agrees with where the last few put it. Then I injected spikes into a real log to see what each gate did, measuring how far the trajectory moved compared to the clean run:
spike     chi2 only    with the new gate
 2 m        0.17 m          1.53 m
60 m       15.73 m          1.34 m
The 60 m row is the one I expected. chi2 misses it completely, the new gate catches it. The 2 m row is the problem: the gate made things worse.
What was happening is that it predicted from a two-point extrapolation, so an error in the most recent reference fix landed in the prediction roughly doubled. A 1.5 m spike passed the 3 m limit itself, and then threw the NEXT good fix over it. So the gate accepted the bad sample and rejected the good one. The rejection count was 1, which is exactly what you’d expect to see on a log with one spike in it, and the rate looked fine too.
So that’s a third thing worth watching alongside “did it run” and “can it still fire”: did it fire on the right sample. A gate with a perfectly sane rejection rate can be systematically rejecting the wrong ones, and nothing in the count or the rate tells you. The only reason I caught it is that I injected spikes at a range of sizes instead of one big obvious one, and watched where the trajectory went rather than what the gate reported. That might be worth building into whatever on-demand test you end up with, because a single large spike would have passed.
The fix was a least squares line over five points instead of two, which drops the weight on the newest fix from about 2.0 to 0.8, so a spike that passes the limit can no longer push the next prediction over it at any threshold. That part is just arithmetic. But I wouldn’t have gone looking at gate behaviour this way without your framing.
See you in Toronto.
Yeah, your 2 m case needs a custom fault monitor, written by whoever knows the filter. The rejection count was 1 and looked fine. Nothing outside the filter could tell you it rejected the wrong fix.
AUTOSAR does the same split, by the way. The monitor (can be customized) does the maths. DiagnosticEventManager does the fault lifecycle, debounce, enable conditions, freeze frame and clearing, so you can send raw pass/fail and let DEM debounce it or… the monitor debounces itself and sends a final PASSED or FAILED. That’s your 200 votes at 80 percent, with an enable condition in front. You’ve already built it, it just needs somewhere to plug in :slight_smile:
so I think I’d make graph_watchdog: value detectors with a window and an enable condition · Issue #669 · selfpatch/ros2_medkit · GitHub a monitor interface in the client library. The time, counter and ratio windows we discussed become the built-in options. Simple checks on a topic stay config only, for people who don’t code. Anything that needs the filter’s own state goes in a custom monitor. We’ve heard the same thing from other medkit users, so it’s not just you :sweat_smile:
The headroom check I said I’d add goes in that monitor too. Spike replay is a routine you run on demand, an operation on the app. Try a few spike sizes, compare the track with the clean run, and it catches the 2 m case as well.
I’ll take this to our next medkit sync and then update graph_watchdog: value detectors with a window and an enable condition · Issue #669 · selfpatch/ros2_medkit · GitHub
Thanks and see you in Toronto!
Slot is booked, Thursday 6pm. I’ll be at your talk right before it.
One more failure shape for the pile, and I think it’s a different one from the three we’ve been talking about. Found it yesterday and it cost me most of a weekend, which is usually a sign it’s worth writing down.
Short version: the monitor ran, it could fire, and it fired on the right samples. The number it was reasoning about was garbage.
I have a gate that checks whether a GPS fix agrees with where the last few put it. It keeps a short history of accepted fixes and fits a line through them. That history is also where it works out the fix cadence, and the cadence is used elsewhere to answer a different question: has the receiver just come back from an outage, in which case the filter may have drifted blind and should re-admit GPS.
If the history is allowed to span an outage, the cadence comes out as the average of the hole. On one of my logs that was 115 seconds instead of 0.2. Everything downstream then inherits it. The “have we just had an outage” test became “was the gap longer than 231 seconds”, so every outage shorter than that stopped being recognised as an outage at all, and the recovery path never armed for them.
Measured on a log with gaps of 275, 129, 65 and 55 seconds. Only the 275 one ever armed. Error 300 seconds after the 129 second gap:
before    746 m
after      78 m
The reason I nearly missed it is that I checked the biggest gap first, which was the one case that already worked, so the fix looked like it did nothing.
I don’t think a generic detector can catch that, which I guess is more support for your custom monitor split rather than an argument against it. But it might be worth the interface being able to say “my inputs are invalid right now” as distinct from pass or fail, because during that window the honest answer was neither. It wasn’t passing and it wasn’t failing, it was answering a question it
had no business answering.
See you in Toronto.
Yeah, that’s a nasty 4th shape with right sample, wrong number and no, a generic detector won’t see that.
so, automotive’s got a name for your “neither”. Basically every monitor sits behind an enable condition, which is just “am I allowed to judge right now” e.g. conditions: engine running, voltage in range, sensor initialized, that kind of thing and while it’s false, the fault manager throws the votes away. The counter freezes or resets, it can be your choice in config and the fault doesn’t go green. It says “test not done” until a real pass or fail lands. That’s the UDS bit I mentioned earlier.
The nice part… when the condition comes back, the monitor gets a “start over” call so it can drop its old state. Which is your fix in one line. After an outage, flush the history. Don’t fit a line across the hole.
So for graph_watchdog: value detectors with a window and an enable condition · Issue #669 · selfpatch/ros2_medkit · GitHub I’d do this:
a monitor returns PASS, FAIL or NOT_EVALUATED with a reason. NOT_EVALUATED doesn’t touch the counter. Never green for a check that didn’t run. And the simple config only detectors do the same when there’s a hole in their window, instead of averaging across it.
