SpaceMouse teleop + MuJoCo visual twin & data collection for AgileX PiPER
Hey everyone! :waving_hand:
Wanted to share a project I’ve been hacking on: a SpaceMouse-driven teleoperation and data collection pipeline for the AgileX PiPER 6-DOF arm on ROS 2.
The main idea was to make teleoperation feel natural instead of clunky. You just grab a 6-axis SpaceMouse, steer the gripper through Cartesian space, and collect clean demonstration datasets (packaged for LeRobot / ACT imitation learning).
A few quick details on how it’s set up:
  • Controller: SpaceMouse 6-DOF inputs mapped to Cartesian velocities with joint-space smoothing filters so the arm doesn’t jerk around.
  • The Sim Twin: I hooked up a live MuJoCo digital twin alongside the hardware. Right now, honestly, it’s mostly there for visuals and nice rendering (you could just as easily use RViz for the basic joint transforms!).
  • What’s next: The real reason to keep MuJoCo around is the next step—adding synthetic camera views in the sim that mirror my physical camera setup. That way, I can test and benchmark trained vision policies in simulation before letting the model loose on the physical robot table.
The repo is public, and I’d love any thoughts, feedback, or ideas on this project.
Github :GitHub - sriharshakunda/piper_ros2: Production ROS 2 Driver & 6-DOF SpaceMouse Teleoperation for AgileX PiPER Arm · GitHub
this is really cool! quick question: how are you screening recorded demos before training? (always looking to learn more about this!)
I actually discard bad episodes right at data collection time (e.g., hitting a reset if it fails), so I don’t have to filter a huge pile of data later. Once uploaded to HF, I just spot-check a few episodes using the visualizer to make sure joint angles and camera streams look normal before training.
nice project, the smoothing filter idea is solid. one thing to watch is wrist singularities, thats where cartesian teleop usually gets jerky first so a joint velocity limit there helps. also worth logging joint current in the demos, its a cheap way to flag bad grasps before training. fyi im with Tolerance Labs, we work on actuators and grippers, happy to chat if you ever want to compare hardware.
