`runtime_integrity`: execution-integrity evidence for Nav2 AMRs under EU AI Act logging / oversight pressure
Hi ROS community,
I have refactored my previous ros2_kinematic_guard work into a broader package called runtime_integrity. The motivation is still very concrete on the engineering side:
/cmd_vel is still being published,
but the robot’s physical motion no longer matches the command stream.
Why the audit angle matters
As EU AI Act logging and human-oversight obligations approach for high-risk AI systems, runtime evidence is becoming more important. I do not claim this package “makes a robot compliant”, and it does not replace safety-rated PLCs, safety scanners, or hardware E-stops.
The narrower goal is to provide machine-readable execution-integrity evidence that can support:
  • engineering diagnostics,
  • incident reconstruction,
  • operator dashboards,
  • audit logs,
  • and human-oversight workflows.
Integration model
The current ROS 2 implementation remains non-invasive:
Controller Server / planner / teleop
      /cmd_vel
runtime_integrity
  /safe_cmd_vel
base driver
It can start in observe mode, so it does not require changes to Nav2 controllers, BT XML, or base-driver code.
The README now focuses less on “wheel slip detection” and more on runtime accountability, execution-integrity evidence, and audit/HMI integration hooks.
Repository:
https://github.com/ZC502/runtime_integrity
Looking forward to your feedback regarding the planned enterprise audit event schema and integration hooks!
Great evolution of your initial work.
Please consider adding a license declaration file to your repo.
Hi @lyle,
Apologies for the delayed response—I just saw your message!
Thank you for the kind words on the project’s evolution and for the helpful reminder. I have just added the LICENSE file to the repository.
@zc_Liu why do you presume that robots using AI fall under the high risk category of EU AI Act? When I read the categories, I think most robots would fall under the limited risk category.
Draft Commission guidelines on the classification of high-risk AI systems | Shaping Europe’s digital future
2.If the system falls into one of the use cases listed under the areas in Annex III AI Act, it will be classified as high-risk pursuant to Article 6(2) AI Act.
