While setting up the YDLIDAR on ROS2, I ran into many issues with deprecated functions and broken packages. It was quite challenging after installing the SDK from the official repo, especially configuring the client and driver nodes properly.
To help others facing similar issues, I created a working version of the ydlidar_ros2_driver package that supports custom configuration and launch files. The goal is to make it easier to integrate and test YDLIDAR sensors on ROS2 (specifically for X3, but extensible).
This is an ongoing project and Iβm actively working to make it better and more efficient.
Iβm open to collaborations and contributions.
GitHub Repo: GitHub - Oyefusi-Samuel/ydlidar_ros2_driver-master
Features:
- Easy integration with ROS2 (tested on Humble)
- Custom YAML-based configuration
- Launch files for testing with RViz
- Basic scan topic and services (
start_scan,stop_scan)
If youβd like to join or contribute, feel free to reach me at samueloyefusi@gmail.com
Looking forward to collaborating with the community to improve this further!
YDLIDAR ROS2 Driver
ydlidar_ros2_driver is a new ros package, which is designed to gradually become the standard driver package for ydlidar devices in the ros2 environment.
How to install ROS2
How to Create a ROS2 workspace
Compile & Install YDLidar SDK
ydlidar_ros2_driver depends on YDLidar-SDK library. If you have never installed YDLidar-SDK library or it is out of date, you must first install YDLidar-SDK library. If you have installed the latest version of YDLidar-SDK, skip this step and go to the next step.
- Download or clone the YDLIDAR/YDLidar-SDK repository on GitHub.
- Compile and install the YDLidar-SDK under the build directory following
README.mdof YDLIDAR/YDLidar-SDK.
Clone ydlidar_ros2_driver
Clone ydlidar_ros2_driver package from this repo :
https://github.com/Oyefusi-Samuel/ydlidar_ros2_driver-master.git -
Build ydlidar_ros2_driver package :
cd ydlidar_ros2_ws colcon build --symlink-installNote: install colcon see
>Note: If the following error occurs, Please install YDLIDAR/YDLidar-SDK first.
Package environment setup :
source ./install/setup.bashNote: Add permanent workspace environment variables.
Itβs convenientif the ROS2 environment variables are automatically added to your bash session every time a new shell is launched:echo "source ~/ydlidar_ros2_ws/install/setup.bash" >> ~/.bashrc source ~/.bashrc -
Confirmation
To confirm that your package path has been set, printenv thegrep -i ROSvariable.printenv | grep -i ROSYou should see something similar to:
OLDPWD=/home/tony/ydlidar_ros2_ws/install -
Create serial port Alias [optional]
chmod 0777 src/ydlidar_ros2_driver/startup/* sudo sh src/ydlidar_ros2_driver/startup/initenv.shNote: After completing the previous operation, replug the LiDAR again.
Configure LiDAR paramters
ydlidar_ros2_driver_node:
ros__parameters:
port: /dev/ttyUSB0
frame_id: laser_frame
ignore_array: ""
baudrate: 230400
lidar_type: 1
device_type: 0
sample_rate: 9
abnormal_check_count: 4
resolution_fixed: true
reversion: true
inverted: true
auto_reconnect: true
isSingleChannel: false
intensity: false
support_motor_dtr: false
angle_max: 180.0
angle_min: -180.0
range_max: 64.0
range_min: 0.01
frequency: 10.0
invalid_range_is_inf: false
Run ydlidar_ros2_driver
Run ydlidar_ros2_driver using launch file
The command format is :
ros2 launch ydlidar_ros2_driver [launch file].py`
- Connect LiDAR uint(s).
ros2 launch ydlidar_ros2_driver ydlidar_launch.py
since mine is the x3lidar
ros2 launch ydlidar_ros2_driver x3_ydlidar_launch.py
- RVIZ
ros2 launch ydlidar_ros2_driver ydlidar_launch_view.py
ros2 launch ydlidar_ros2_driver ydlidar_x3_view_launch.py
- echo scan topic
ros2 topic echo /scan
Launch file introduction
The driver offers users a wealth of options when using different launch file. The launch file directory
is "ydlidar_ros2_ws/src/ydlidar_ros2_driver/launch". All launch files are listed as below :
| launch file | features |
| ydlidar.py | Connect to defualt paramters Publish LaserScan message on scan topic |
| ydlidar_launch.py | Connect ydlidar.yaml Lidar specified by configuration parameters Publish LaserScan message on scan topic |
| ydlidar_launch_view.py | Connect ydlidar.yaml Lidar specified by configuration parameters and setup RVIZ Publish LaserScan message on scan topic |
Publish Topic
| Topic | Type | Description |
scan |
sensor_msgs/LaserScan | 2D laser scan of the 0-angle ring |
Subscribe Service
| Service | Type | Description |
stop_scan |
std_srvs::Empty | turn off lidar |
start_scan |
std_srvs::Empty | turn on lidar |
Configure ydlidar_ros_driver internal parameter
The ydlidar_ros2_driver internal parameters are in the launch file, they are listed as below :
| Parameter name | Data Type | detail |
| port | string | Set Lidar the serial port or IP address it can be set to /dev/ttyUSB0, 192.168.1.11, etc. default: /dev/ydlidar |
| frame_id | string | Lidar TF coordinate system name. default: laser_frame |
| ignore_array | string | LiDAR filtering angle area eg: -90, -80, 30, 40 |
| baudrate | int | Lidar baudrate or network port. default: 230400 |
| lidar_type | int | Set lidar type 0 β TYPE_TOF 1 β TYPE_TRIANGLE 2 β TYPE_TOF_NET default: 1 |
| device_type | int | Set device type 0 β YDLIDAR_TYPE_SERIAL 1 β YDLIDAR_TYPE_TCP 2 β YDLIDAR_TYPE_UDP default: 0 |
| sample_rate | int | Set Lidar Sample Rate. default: 9 |
| abnormal_check_count | int | Set the number of abnormal startup data attempts. default: 4 |
| fixed_resolution | bool | Fixed angluar resolution. default: true |
| reversion | bool | Reversion LiDAR. default: true |
| inverted | bool | Inverted LiDAR. false β ClockWise. true β CounterClockWise default: true |
| auto_reconnect | bool | Automatically reconnect the LiDAR. true β hot plug. default: true |
| isSingleChannel | bool | Whether LiDAR is a single-channel. default: false |
| intensity | bool | Whether LiDAR has intensity. true β G2 LiDAR. default: false |
| support_motor_dtr | bool | Whether the Lidar can be started and stopped by Serial DTR. default: false |
| angle_min | float | Minimum Valid Angle. default: -180 |
| angle_max | float | Maximum Valid Angle. default: 180 |
| range_min | float | Minimum Valid range. default: 0.1 |
| range_max | float | Maximum Valid range. default: 16.0 |
| frequency | float | Set Scanning Frequency. default: 10.0 |
| invalid_range_is_inf | bool | Invalid Range is inf. true β inf. false β 0.0. default: false |
| More paramters details, see here |
