ROS PMC Business
- Proposal: @emersonknapp proposes to start a new working group focused on topics around the ROS Graph
- Charter: ROSGraph Working Group
- @christophebedard Seconds
- Passes by Consensus
- Proposal from @mjcarroll: Push meeting back 1 hour
- PSA: 2026 Funding Proposal Round is coming up, be thinking about what we would like to propose here.
Regular Business
Buildfarm update
- PTAL Buildfarm Issues Triage Sheet
- ROS Greenness:
Issues
- test_allocator_memory_strategy failing in Rolling Connext CI (Michael will take a look)
Priorities
- rmw_connextdds support message making ROS2 CLI tests fail (Michael assigned)
- sros2.test.sros2.commands.security.verbs.test_generate_policy_no_nodes.test_generate_policy_no_nodes failing consistently in Kilted CI (Michael assigned)
- ros2service.ros2service.test.test_cli.test_cli failing consistently in Kilted (Scott assigned)
Waffle note-taker
- Nov 20 - @Katherine_Scott
- Nov 27 - Thanksgiving Holiday (US)
Rosdistro assignments
- Nov 18 - Nov 25 - @wjwwood + @methylDragon
- Outgoing rosdistro
- Only holds for Jazzy Sync
Release Management
- ROS Boss Duties and Guidelines
- Audrow (Humble)
- No updates.
- Yadu (Rolling)
- No updates.
- Marco (Jazzy)
- Scott (Kilted)
Agenda
- [Michael Carlstrom] rosidl_generator_py: Deprecate using set for container based input
- [@MiguelCompany] Clarify on permissions in rclc:
- Fix REP url locations by Timple · Pull Request #436 · ros2/rclc · GitHub
- Does not appear in ros2.repos: ros2/ros2.repos at rolling · ros2/ros2 · GitHub
- @mjcarroll to address permissions here
- [zulip] @rkent would like some additional review here, as it has stagnated: Add tests for ament_python_install_package by rkent · Pull Request #598 · ament/ament_cmake · GitHub
- @cottsay doesn’t have time to review, going to let someone else step in to get it over the line.
- [emerson] RMW implementation library wrapper/shim by emersonknapp · Pull Request #266 · ros2/rmw_implementation · GitHub - RMW Implementation Wrapper needs reviewers
- Were there any performance implications
- RMW_IMPLEMENTATION can statically link if there is only a single implementation. Will the wrapper break that.
- [emerson] First (unofficial) working group meeting successful. New contributions!
- [mjcarroll] ROSCon debrief (cont’d)
